Strange S2+ problem
13 posts / 0 new
zoulas
zoulas's picture
Last seen: 1 hour 29 min ago
Strange S2+ problem
I have an S2+ with the following problem. The light has 5 modes. When turning it on, it always comes on in the next mode from when you turned it off. I normally run it on high. When I turn it on it comes on in strobe (which is the one after high.)
Any idea? This one only has about 1n hour of use.
Thanks
raccoon city
raccoon city's picture
Last seen: 19 hours 24 min ago
Location: Palm Desert CA ~ West Coast is the best coast
Wow, next mode memory when it's not supposed to be...
That sucks.
I hope someone smarter than me can help you out!  :BEER:
-ROYCE-
Last seen: 12 hours 50 min ago
It should remember your last mode if you had it in that mode for at least 3 seconds. If you have it on or in a certain mode for less than 3 seconds, it won’t work. I’m not sure if that’s your problem, but I had some confusion with a light with a similar Memory function when I first got it and was just testing it out.
chops728
Last seen: 21 hours 23 min ago
Maybe the switch or driver retaining rings are loose causing a simulated double click when you turn it on —- try taking off the tail cap and using a screwdiver or something to turn the light on and then off —then turn it back on again and see what happens
raccoon city
My mom has a flashlight that she has dropped one too many times.
It was the typical five mode, but with proper memory.
Now it's one mode--high or off.
I told her, "I don't know how to fix flashlights, so it's just a one mode flashlight now."  :))
(She actually doesn't mind so much because she usually used it on high.)
stephenk
stephenk's picture
Last seen: 4 hours 52 min ago
If it is the older 3/5 mode UI then there is a 3 second mode memory timer i.e. a mode is only memorised when it has been on for more than 3 seconds.
max
max's picture
Last seen: 2 days 13 hours ago
This ^^^^^^^^^
The trick is to be patient and wait the 3 seconds.
 max
zoulas
zoulas's picture
I am talking about turning it on after not using it for a day or a week.
Henk4U2
Henk4U2's picture
Last seen: 32 min 19 sec ago
It is not a matter of how long it is turned off before you use it again.
The question is how long it was on, before it was turned off.
Walking with your light on high all the time, then turn it off, the light will restart in high.
A lot of people (unconsciously) fiddle before turning it of. Then it restarts at the next level of whatever mode you turned it off
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
zoulas
zoulas's picture
To be clear, even if I have it on for an hour, when I turn it off then on it goes into the next mode .This happens regardless of how long I have it off or on and regardless of what mode its in. It will start on the next mode 90% of the time. 10% of the time , it works fine.
Mike C
Mike C's picture
Not heard of this issue on those lights before. Switch bouncing? When you turn it on, see if you can click it a little differently? I don’t think you can with those clicky switches. Otherwise test without the switch by removing tail-cap and short battery minus with the tube. If you still have the issue when doing this, then switch bounce isn’t the issue.
Bort
Bort's picture
Last seen: 1 min 20 sec ago
It could be the 3 second bit, since i got my first light i trained myself to use a mode at least a few seconds except when i want to skip modes intentionally to get to the one i want.
That said i would not want a procedure for just one light so the tap just this light 4 times would not work for me. A few secs on all lights i own works fine becasue its uniform.
Now it’s one mode—high or off.
I told her, “I don’t know how to fix flashlights, so it’s just a one mode flashlight now.”  alt=))" />
(She actually doesn’t mind so much because she usually used it on high.)
While this is a good solution i would be curious to see a teardown to determine what caused this to happen.
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
ShyOne
ShyOne's picture
Last seen: 11 months 1 week ago
chops728 wrote:
~~~ snip ~~~~ try taking off the tail cap and using a screwdiver or something to turn the light on and then off —then turn it back on again and see what happens
Mike C wrote:
~~~ snip ~~~~ ….. test without the switch by removing tail-cap and short battery minus with the tube. If you still have the issue when doing this, then switch bounce isn’t the issue.
Have you tried what is mentioned above???
