Thanks for the update. I hope you are feeling much better these days and life has returned (more or less) to normal.
It looks like the 8 x 18650 LT1 adapter never got off the ground. Its too bad that such a cost effective, simple and useful add-on made it through the prototype stage but never went into production. Id have purchased several. I always wondered what the LT1 and possible upcoming variants and accessories might have been if they had been produced by Astrolux or Convoy. Ah well… Im still very pleased with my collection of LT1’s and they see a great deal of use. Thanks again to all who were involved. :+1:
In Anduril 2, there is a Simple Mode feature… Still by using 1 button as opposed to your 3 button request, but more in line with the usual kind of UI found in most lights.
That is planned, for the LT2. four 21700 capability, with power bank, 3rd red LED channel.
[/quote]
That sounds awesome! I’m using my LT1 right now, I use it pretty much everyday. Would love a bigger LT2 but I am thinking big getting the new orange LT1 just because. They are such good value.
I liked that 8 x 18650 adapter as well, i was thinking of designing a larger ” wider” battery tube, to hold up to 8 - 18650s in parallel, and would ad stability to the LT1 lantern head. ( and look much like how the base/tank of a Coleman gas lantern is. * Hey Barry! are you listening to these ideas? make it a reality!
So possibly a large 8 x 18650 base that would screw onto the existing 4 x 18650 LT1 (for a total of 12 x 18650). That is ingenious and I like the way you think. And of course, Id buy several! That would also make for a great high capacity power bank.
Admittedly, my vintage Coleman lantern collecting obsession has reached new heights. All attributable to my inability to restrain myself from acquiring these finger burning photon emitters.
Could anyone please help me out, my lantern’s light output gradually decreases in time? I factory reset by unscrewing and holding the button for 4 seconds while rescrewing the body back. Then I double checked by doing 13H for the factory reset in Andruil 2.0. I then changed the tint to bright white by 3H, but the issue that when the light is on the lamp decreases the brightness until the lamp is off after 2 second increments!
That is odd… never seen that happen before. Maybe Toykeeper or Barry can chime in on that… if the driver is defective, contact Sofirn i’m sure they will help! - DB
This sounds like a weak battery (getting “low-batt” or “empty”), but if the batteries are not “low-batt” (can check using the triple-click from Off for “Battery Voltage Check” function).
If batteries are not “low-batt” (not nearing 3.0v), then it could be some poor contact issue (fully-charged batteries might be detected as “weak” due to poor contact somewhere — sometimes it could be due to an o-ring that’s entangled and interfering with the contacts).
Finally managed to figure out how to reset the lamp. I fully charged it, then had to unscrew it and hold the button down for 4 seconds. The manual had this kinda hidden and not well marked out on how to reset the lamp.
I hear a lot of people like to set the light to 4000k. How do you all set it to a specific color temp? Do you just ramp up to 5000k, release then hold it back down for 1 second and approximate that as 4000k? It would be nice if it ‘clicked’ at 500k increments.
Approximate it. See how long it takes to go from one end of the ramp to the other, and do half that.
Or better yet, don’t worry about the exact temperature. Just set it for what looks right in the current context. During the early evening when the sun has set but there is still a fair amount of glow from scattered light in the sky, I might set it all the way at the 5000K end of the ramp. As the ambient fade, especially if I have a campfire going, I adjust it progressively warmer.
I have the one with the version 5.0 driver. The firmware was updated from Andril to Anduril 2.0.
The flashing key/pogo pins did not work. I had to remove the driver and use the SOIC clip. It was successful. It is all good. The flashing kit with this flashing key/pogo pins works on other lights, so the problem seems to be in the light itself. Other than that, there is no problem. Everything works.
I am curious what I did wrong. The error showed the connections were not good. Has anybody had the similar experience?
I just received a version 5.0 from Amazon. Am I missing any functionality / feature by not having the latest driver? Perhaps I should order from Sofirn instead? Thanks!
I really hope that project comes together. Having a 3rd red channel is the one thing I’d really love to see. It makes it useful for so many additional applications where red is required: stargazing, sailing, avoiding bugs, etc. (Yes, I know that requiring red is a hotly debated topic, but lots of groups still require it, and it’s easier just to go with the flow and have a red light.)
The power bank feature would also be nice with 21700s, you could get a nice 20 Ah (~72 Wh) capacity with that. I don’t find I’m ever lacking for run time on the LT1, but including a power bank would make that extra capacity really nice.
