I already modded Cochise334ever's carrier. Yea, don't have easy access for beamshots local here. I could use a park but technically it's closed after dark.
I'm close to thinking to mod one with a SFT-40: 8-9 amps looks like the sweet spot and should be able to out throw a SBT90.2.
Thank you TA, I will re-read everything and see where I stand. I like the idea of keeping the charging. But if solutions for the light have been worked towards, I will def weigh the overall benefit to the light.
Will removing charging address some parasitic drain and the glowing LED, or just the residual drains?
WildTrail sent me these pics to share with you. I was also given a short video clip that shows the deep heat fins of WT90. Texas_Ace, maybe you like to put them into the OP, too?
Here’s the new link to the WT90 manual, please click >>> here <<<. The old links do not work anymore. :(
I’m super excited for the group buy and everyone able to get one even though I’m not buying one (already have a silver).
Everyone’s gonna love this thing. It’s like a really pretty piston with a lightsaber coming out the top. It’s also got huge Art Deco swag with a bit of a retro museum-piece/trophy-vibe, let’s just say it’s an absolute classic.
So, i couldn't get any beam shots at the beach because of the flashlight paradox that happens at CT state parks where the sun goes down at 8:20pm, it gets DARK at 9pm, and the parks close at 8:30pm.. So these are from outside my house, distances measured with google maps. Unfortunately not a good amount of range, but WT90 looks like Daylight at 350 meters.
I remember I bought 2 Lumintop SD75 that featured inboard re-chargeability AND power bank functions, though it had a much simpler design as the carrier was the usual 3-cell carrier with the charging circuit situated at the bottom of the battery tube.
Both SD75s had horrendous parasitic drain that it ruined two sets of 18650s. Perhaps more design research is needed to mitigate this problem, at least for me.
Personally, I will have to wait for the WT90 to iron-out this parasitic problem before I dive for this light as I am really a fan for this light’s design, performance and powerbank versatility, but a phobia for lights that has parasitic drain issues.
i was saving $$ to buy the new Lumintop top SD90 like 2 weeks before TA dropped this group buy! I wished the head was larger on that light because it looks pretty awesome otherwise. While I was trying to dig for info on it because it was new, I found 5+ year old YouTube reviews of the SD75, which seemed like it's predecessor but with the xhp70.2 . I haven't seen much about the sd90 since the WT90 came out. Interesting lol (it is $40-$50 more than the WT90 with a 10mm smaller head, which I equate to less throw).
Disabling the charging on the carrier should remove all parasitic drain from the carrier leaving only yhe normal parasitic drain from the driver itself which generally takes 2 years+ to drain a set of batteries.
Sadly I do not see the charging parasitic drain being fixed while keeping the charging working. This is why I don’t care for internal charging. It can be done but takes a lot of extra work to make it work properly.
Thank you. My Google Drive links were unfortunately messed up by some update, so I had to restore some information, e.g. manuals. If you want to update the link to the manual once again, here’s the new link:
