i was saving $$ to buy the new Lumintop top SD90 like 2 weeks before TA dropped this group buy! I wished the head was larger on that light because it looks pretty awesome otherwise. While I was trying to dig for info on it because it was new, I found 5+ year old YouTube reviews of the SD75, which seemed like it's predecessor but with the xhp70.2 . I haven't seen much about the sd90 since the WT90 came out. Interesting lol (it is $40-$50 more than the WT90 with a 10mm smaller head, which I equate to less throw).
Disabling the charging on the carrier should remove all parasitic drain from the carrier leaving only yhe normal parasitic drain from the driver itself which generally takes 2 years+ to drain a set of batteries.
Sadly I do not see the charging parasitic drain being fixed while keeping the charging working. This is why I don’t care for internal charging. It can be done but takes a lot of extra work to make it work properly.
Thank you. My Google Drive links were unfortunately messed up by some update, so I had to restore some information, e.g. manuals. If you want to update the link to the manual once again, here’s the new link:
The Charge circuit IC’s are simply not designed to have the low parasitic drain that we need. They are designed for items that are used regularly or need constant monitoring.
It can be made better but takes more expensive components and R&D that most flashlight manufactures are not even aware are necessary. Parasitic drain is something that manufactures seem to completely ignore for some reason. I have a few lights that from the factory would drain the cells in a few months.
Quite surprised to see the slow sale of the WT90. The Black version hardly moves on Ali Express’s web page for days, still 51 pieces available.
I have grabbed one Silver. Will wait to get one Black if the price drops later this year.
BTW, what happens to those large and expensive flashlights (each costing over US$200) which have been left unsold over the years? Just saw on Olight’s website, soon the new X9R will be on sale for about US$500. What will happen to the older Marauder 2, which is priced over US$200?
X9R has been around for a while. Marauder 2 came after it. The only thing that’s new is that it’s blue now. I imagine they will continue to carry both models. The X9R will go back up to $600 when the sale ends.
Hi TA, It is possible for a "mere mortal" without too much experience to be able to disable the charging on the carrier ... I wish I could do it because I always use a spare pair of batteries and I prefer to recharge the batteries with my charger.
Excuse me how do I tell the lamp 18 °? I can calibrate the external temperature or the temperature of the room or you are telling me that after heating the lamp with the Turbo for a few minutes I tell him that the room is at 18 ° so that it who is hot thinks that all that heat is only 18 °, is that correct? Thank you.
Easiest way would be to simply replace the charging PCB with a pass-thru board. Should be cheap but Int'l shipping is always a problem. We do need the PCB board designed, then anyone could order it through a PCB service like OSHPark or a China based low cost PCB house like https://www.pcbway.com/. Not sure of the cost, but probably over $10 shipped.
