RD6018 RD6018W 60V 18A power supply is published
RD6018W feedback
The seller sent the goods quickly, delivery lasted a little over three weeks. This DC-DC converter itself is very cool, great. S800 case does not include a cooler and a dotny controller(because use PSU fan is enough)
https://www.aliexpress.com/item/1005001488070904.html
please do remember to use the green battery charging terminal as positive output to charge a battery, it has many protection method for battery charging including wrong connection, battery detection and auto cut off
hello, for our products, we all have instructions for them, the link is placed at the description page , or you can send us message to get them, just do not assemble or use the products in the way you like, it may caused product damage
https://rdtech.aliexpress.com/store/923042?spm=a2g0o.detail.1000061.1.79b87737SkQp4h
if you want to charge the battery with RD6018, just use the Green and Black terminals to do that, the red positive terminal is not suitable for battery charging because it does not have protection method inside, and when you are using the battery charging terminal, it does not matter even you connect the battery in the wrong way, and it will cut off the charging when the current is decreased to 100mA
RD6018 feedback
the accuracy is good and operation way is convenient, ripple can be accepted and most important thing is the price for the quality(for the next 3 days you can use a 70-4USD coupon, quantity 1000 only)
after 6 hours. we will release some 6 USD coupons, please wait
hello, today we talk about our RD6006P, it is 5 digit display and it has much lower ripple than normal RD power supplies, we combine the structure of switching power supply and linear power supplyand there is a 80-6 USD coupon, you can use it
https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMYJ97LybOJ1MU%2F4CjWwsbbi
if you have good design based our power supply, just send us, thank you for your sharing
RD6018 feedback
good, assembled easily, the seller's guidance is very attentive
RD6018 customer feedback
it is convenient to operate and the output is stable even if I connect high power load, ripple is acceptable and the best quality I can get with this price
It comes super fast to me. great company
https://aliexpress.com/item/1005001488070904.html
it is easy to assemble them together, and the device is user friendly
RD6012W feedback
have a look at my Super DIY power supply
https://www.aliexpress.com/item/4001053200176.html
RD6018W feedback
the product is good, need prepare the AC power cable by yourself
RD6018W order suggestion
when making order, you can click the coupon option to get more discount, for example, you order RD6018W, you can use 6 USD coupon, if you order whole set, you can get 10 USD off at least
https://www.aliexpress.com/item/1005002058172206.html
Is “RD6018WS800 1000W68V” here the same as the other link in the thread but with the 1000W power supply? Will the 1000W supply provide the full 18A maximum of the RD6018 (at 55.5V obviously)?
if AC is 220V , it can let RD6018 output 60v/18a
good power supply, still need a AC power cable
RD6018W feedback
order suggestion assembled , works
RD6018W feedback
after checking the accuracy in volts and amps, it exceeds my expectations. very precise measured with 5 1/2 digit multimeter
