please do remember to use the green battery charging terminal as positive output to charge a battery, it has many protection method for battery charging including wrong connection, battery detection and auto cut off
if you want to charge the battery with RD6018, just use the Green and Black terminals to do that, the red positive terminal is not suitable for battery charging because it does not have protection method inside, and when you are using the battery charging terminal, it does not matter even you connect the battery in the wrong way, and it will cut off the charging when the current is decreased to 100mA
after 6 hours. we will release some 6 USD coupons, please wait
if you have good design based our power supply, just send us, thank you for your sharing
RD6018W order suggestion
when making order, you can click the coupon option to get more discount, for example, you order RD6018W, you can use 6 USD coupon, if you order whole set, you can get 10 USD off at least
https://www.aliexpress.com/item/1005002058172206.html
Is “RD6018WS800 1000W68V” here the same as the other link in the thread but with the 1000W power supply? Will the 1000W supply provide the full 18A maximum of the RD6018 (at 55.5V obviously)?
if AC is 220V , it can let RD6018 output 60v/18a
RD6018W feedback
order suggestion assembled , works
https://aliexpress.com/item/1005001488070904.html
