Since when are you an electrical expert to judge others, especially with all the nonsense that you post?
This looks like a first-time poster asking a question about how could this be possible. If english is not his first language it could be difficult and the grammar might not be correct.
Here’s what it could be:
Someone (not the OP) is claiming that a silicone coated wire inside the lamp would allow full light with less heat and with reduced power input—and the OP is wondering how could this be true, since lightbulbs make heat (radiant light)?
Think outside the box sometime.
Do you know where the Matheson corporation is located and who was a founder? Maybe somebody works there. James Matheson
Yes he was. Old Taras died of the bulbonic plague. When people tried to revive him, by going back in time through a worm hole, someone stepped on the worm. The parts they could retrive are known as Light Bulba.
I get it. I think everybody is confused because this is in the wrong forum. It should make perfect sense to those people that want to continue to play with 1.5 volt batteries.
