since we are “talking” soldering iron….
code PNH269OM gets this for $13.
none of the Amazon links work.
do not know why.
please search
on Amazon.
Vastar Soldering Gun Automatic Hand-held
do not know why.
please search
on Amazon.
Pete7874, i thank you.
Tactical flashlight, 1200 lumen, with magnetic charging - $7.09
I know not many zooming fans, but received the one I got for <$12 today. Amazon Deal Alerts & Discussion Thread - #4048 by dthrckt
I suspect the led pcb is bridging a gap in the pill, pretty light Weight. Battery says icr 3800.
Case is worth a few bucks to me. Will try to remove USB charging garbage, swap lens and driver and make it 26800. I like the huge emitter when zoomed.
Zoomies are useful boat camping, and I usually end up giving the cheap mods away and stick to my FD65 (close) and HT35 (far).
Govee LED Rechargeable Flashlight, 1000 High Lumens CREE XM-L3 LED
18.99 + –40% coupon = $11.39
Another TIR zoomy.
must resist.
I put up a review of the Handskit PID soldering iron:
https://www.amazon.com/Soldering-Function-Adjustable-Temperature-Ergonomic/dp/B08NDH4Q2T?ref=deals_deals_deals-grid_slot-15_8a28_dt_dcell_vdt_334_73179620&th=1
All the Best,
Jeff
Repeat - NO MORE CHEAP ZOOMIES - NO MORE CHEAP ZOOMIES
Here’s a fantastic deal!
I just received mine and it’s probably comparable to Geek Aire’s 12” model. Phenomenal output for its size and being rechargeable.
Taotronics 12” rechargeable fan ($129 on Taotronics site) for $45 total after 40% off clickable coupon. https://www.amazon.com/dp/B0987Q2Y1K/ref=cm_sw_r_apan_glt_fabc_ZGBNGTATEPP0AMGYFAFF
I paid over $100 for my Geek Aire. Now I have a backup
Worth every penny when the power goes out.
So it has a battery pack that’s built in? So I assume it’s not replaceable?
Are the batteries removable/replaceable?
Can it run on AC power as well?
That's a nice looking fan, and TaoTronics makes some good stuff.
If I needed a floor fan, I'd be all over that.
Looks like it's an unbranded TaoTronics, but if it's really made by them, that's a good sign.
Ordered one. Maybe I can add powerbank capabilities to it.
Yeah, but judging by their marketing material it looks like six cells @ 2975 mah each. When it does get to where they need replacing, it doesn’t look like it would be too hard to pop open and find out what size cells are needed and how they’re connected to the unit.
That’s a nice looking fan, and TaoTronics makes some good stuff.
If I needed a floor fan, I’d be all over that.
Looks like it’s an unbranded TaoTronics, but if it’s really made by them, that’s a good sign.
I can confirm that it is, since I ordered mine direct from TaoTronics with a coupon code for $65, right before this listing appeared on Amazon. At the time it was listed for $65 with a 50% off coupon, so I was able to snag another one for $35 total. It just shipped today, and the label print location and package weight is the same as the one I have now. If you look at the image on Amazon full size, you can see that they erased their logo from the front of the unit. Looks like they’re using fake brand names to sneak back on.
Same. My unit was $65 with coupon direct from TaoTronics. This popped up as mine was on it’s way. At the time, the price and coupon came out $35. So, it was a no-brainer to snag another one before they upped the price/reduced the coupon or sold out. I’m going to use mine for tailgating, and working on the truck in the driveway and working on stuff around the house without needing to drag out a cord for it. I’ll probably give the other one to my dad or my brother.
I used my Geek Aire in the attic last week, pulling Ethernet cables.
just ordered the fan. thanks bigtrav261
No problemo.
