In flashlights, I’m really not a fan of the warmer tones. I like them as white as possible. That beam on the Thrunite is pretty darn white, pretty much right on the money.
Agreed on the green tints, they’re absolutely disgusting. I’ve never had it on a light myself, but I’ve seen some pretty ugly beams online. This new light I got from Lumintop is the worst colored beam out of all my lights, but it really isn’t terrible. It looks a lot greener on the picture than it does in person, as it’s more yellow than it is green, at least to my eyes. I didn’t even notice it much until you mentioned it and made me inspect it further lol. All in all, the beam’s alright, and when you’re shining these things at a distance, it’s not nearly as perceivable as when white wall hunting.
Nearly all my lights are Nitecore, so I’ve never had any tint issues, since they tend to use pretty white emitters, and drive them really hard. Take the XP-L HI V3 for example. They’re both in my P12GT and TM26GT, and I guess you could call it cool white at lower levels, but it gets whiter the higher you drive em. The XHP50 on my EC4S is pretty white as well, though I do remember it having that ring around the hotspot where you can see a little bit of the color of the phosphor coating on the die. Their color temps have always been satisfactory to me. What I really don’t like are lights that are blue. THAT looks disgusting to me, and a ton of people actually like that. It’s definitely not as bad as a green tint but I’ve never actually run into one in person, while I definitely have run into a lot of blue lights in person. I’m talking 6500k+.
I remember back in the pnp HID days, everybody would chase the higher kelvin rating cheap kit lights for their cars thinking they were brighter, and they’d end up with the most horrible, blue as the sky (and dim) pair of lights of all time. And they’d show up with a big grin on their faces too showing them off to me only to hear me tell them they had a blue mess that wasn’t lighting the road any better than 4200k, to which they obviously replied I knew nothing and that the higher kelvin rating, bluer ones were OBVIOUSLY the brightest. It blew my mind how even after I explained to them how lighting actually works and how they’d see better if they stuck to 4200k-5500k (MAX if they really MUST have a bit of blue in it), that they’d be better off and they still insisted on going blue and kept showing up with 8000k HID kits and I just had to shake my head in disappointment lol. I remember they’d tell me look, this one’s white! And I’d tell em no, that’s blue as hell, can’t you see it? Then they told me they asked the guy to give them the brightest, whitest one and that even the box said somewhere between 4500-6000k, the light was clearly around 7000-8000k. Then I’d ask em how much they paid for it and they’d tell me anywhere from $30-$50 and then I’d say “exactly, there’s your problem”. Get what you pay for lol. I quickly learned and then went into retrofitting proper HID projectors in my cars with high quality components. Sorry for the tangent, went on a bit of an unrelated rant there hehe.
Mine charges fine from a PD charger with USB-C to USB-C cable and from a non PD charger with USB-A to USB-C cable.
My wife will like this one. Simple click to change modes and long press for off.
Wow you got that thing fast! The beauty of living in the states! Mine literally took over 20 days to get here from my date of purchase.
What LED will you be dropping in? I also found the contact from the head (where the positive side of the battery contacts) to be suboptimal. I would have much rather had a flat surface where my button top batteries could have better contact from more surface area. Any idea why they put springs on that side instead of a flat contact? Is it perhaps to accommodate a range of lengths of cells? Being that it can use both 18650, plus 21700, plus factoring in whether they’re button or flat-tops and whether they’re protected or unprotected. I’d think the tail-cap spring would suffice for the variances but I might be wrong. Anyway, that spring contact seems to favor flat-tops vs button tops. The flat tops will simply have much more surface area contacting.
Ahh, I see, going for that foglight look. Should be a similar brightness I believe. Keeping the dome on it I assume? Looked the LED up online and it seems like the silicone dome and the phosphor are all mixed together and there wouldn’t be a way to dedome it without destroying it in the process. Anyway, what would be another good option to throw into this light if all I wanted was to make it throw even further? Maybe an SST40? Though, that might require extensive modding such as replacing the driver etc… I’m a newbie to mods btw, never modded a light before, but if I was to mod a light, it’d definitely be this one since it’s so cheap… and it seems worth modding too!
Should definitely just pull the trigger, since it’s so dang cheap, you really won’t be disappointed. The quality is excellent. Good machining, good anodizing, the knurling feels and looks very good, the light feels nice and balanced in your hand, has a good feeling weight to it. Also, the included lanyard is of impressively high quality, very thick and plush on the part that goes around your wrist, the Lumintop lettering looks nice on it as well and it has a very good locking piece with a button on it for adjusting how taut you want the lanyard, as opposed to the usual piece of plastic that just goes up and down without a locking mechanism. MUCH better than Nitecore’s lanyards that tend to wear pretty easily at the attachment point. A great part of how they designed this light is that the lanyard hole doesn’t interfere much with the light’s tailstanding, so long as you just push the thread out to the side as opposed to under the tailcap. Also, Rusty Joe. would you mind sharing the link here in this thread once you do your review? Is there a way to actually tag people in this forum? Usually in other forums the brings up a list of members from which you can type in to narrow it down and then click on the host you wanna tag, but it doesn’t seem to be the case here. Hmmm, the “at” symbol seems to just be either making the font change or and just disappearing into thin air as well.
Nice review - reading it convinced me to get a D2 - but I have a question for you emitter experts….
If I spend the extra $10 (and wait) to get one from Lumintop that has the Nichia 219CT emitter, will the throw be a lot less, or just a little less than with the Osram emitter? And do I really want to drive a 219CT emitter as hard as it is driven in a light like this? I might go with the Osram, just because the Nichia’s really aren’t meant to be pushed that hard.
Form factor on this is near spot on for me though the head is a little too big for easy pocketing… but it throws! The emitter is not too ugly. It’s shorter than the M1 but has similar head diameter. M1 has a wonderful head to body transition which I prefer. (I am looking for an M1 mini with a side switch design FYI ). If Tom E (?) mods it to a 4000K Anduril version I will have to PM them
Thank you, sir. Maybe the one with the Nichia comes with a different board? I would say you’d DEFINITELY be giving up a fair amount of throw if you go with the Nichia as opposed to the Osram. This reflector is actually pretty small, that’s why the throw I got from it caught me off guard. Osram has been making some pretty amazing emitters when it comes to throw. Just take a look at Fireflies’ T9R. It’s a single cell (21700) light, with a pretty beefy reflector but just a medium sized flashlight overall, nothing crazy. If you get it with the Osram CULNM1 10W emitter, you get over 1.5km of throw…. that’s SBT-90.2 territory in lights that are MUCH larger than it. You can actually get it with the SBT, but it throws much less than the Osram emitter, while also being more expensive. It IS a lot brighter though, I think the Osram only does about 900 lumens, but booy does it throw. Going back to the wanting the Nichia emitter in such a hard hitter, I honestly don’t know how hard they’re driving the LED’s, it might not really be that much. I’d speculate it’s doing like 6 amps max. The light does get pretty hot with extended turbo time but it handles it like a champ. I know this because I gave one to my mom and she left it in turbo, IN THE DAY under the hot baking sun! I quickly turned it off and scolded her and she said she was “testing it out”, and I told her testing what out?! We’re in broad daylight in a VERY hot day and you’re leaving the light on in turbo under the sun. Trying to make it fail prematurely? She was off her face so I’ll attribute it to that and let it slide but dang, it definitely shows the light can take abuse and still work like a champ (and that was with the included 18650 battery). The light was VERY hot to the touch, including the tube. Anyway, I would not worry about the Nichia, as if you’re really worried about overdriving it, you can just avoid the turbo setting or only use it for short bursts.
Thank you sir, glad the information was valuable to you :+1: You definitely won’t regret getting one of these, it’s been really fun and unexpectedly so since it exceeded my expectations.
Honestly, the pictures do it no justice. It looks bigger in pictures than it is in real life, this thing is SUPER pocketable, even in my tight jeans pockets it fits just fine. I’ve started using a fanny pack now again since I got a VERY nice looking one recently (got two actually, the same one in 2 different colors) and now I’m just throwing my lights in there along with my keys etc. I had forgotten how great it was carrying a fanny pack around, it’s so convenient.
My D2 arrived yesterday. Lumintop quality build. I really like the format of this little light. Even the half knurling on the tube is effective and comfortable in hand. I swapped out the stock 18650 cell for a Molicel 21700 P42A. Although this domed Osram is not as intense as it’s flat white siblings, it still emits a fairly defined hotspot, and excellent spill in med/hi modes. Hideous corona tint shift while white wall hunting, but unnoticeable in outdoor use. Hate the “hold for off” UI, but it’s not a big deal. Definitely worth the $21. I like it.
Mine got a driver and LED upgrade. Now running Anduril 2 with a Luxeon V2 4000K. Not too pleased with the V2 though, but it's ok.
On a 50G cell I got 7.8 amps, 1110 lumens (at 30 secs, mauuka calibrated), 44kcd. The stock LED is an oddball size between a 3535 and 4040, so couldn't use the centering piece. Fortunately I had a 3535 centering pieces that fits the reflector. I probably should have gone with a SST-20 5000K to get some throw, but with a FET based driver, I would have to be careful with the high amps. I'm using long 24 AWG LED wires now to keep the amps somewhat down.
