The Charge circuit IC’s are simply not designed to have the low parasitic drain that we need. They are designed for items that are used regularly or need constant monitoring.
It can be made better but takes more expensive components and R&D that most flashlight manufactures are not even aware are necessary. Parasitic drain is something that manufactures seem to completely ignore for some reason. I have a few lights that from the factory would drain the cells in a few months.
Quite surprised to see the slow sale of the WT90. The Black version hardly moves on Ali Express’s web page for days, still 51 pieces available.
I have grabbed one Silver. Will wait to get one Black if the price drops later this year.
BTW, what happens to those large and expensive flashlights (each costing over US$200) which have been left unsold over the years? Just saw on Olight’s website, soon the new X9R will be on sale for about US$500. What will happen to the older Marauder 2, which is priced over US$200?
X9R has been around for a while. Marauder 2 came after it. The only thing that’s new is that it’s blue now. I imagine they will continue to carry both models. The X9R will go back up to $600 when the sale ends.
Hi TA, It is possible for a "mere mortal" without too much experience to be able to disable the charging on the carrier ... I wish I could do it because I always use a spare pair of batteries and I prefer to recharge the batteries with my charger.
Excuse me how do I tell the lamp 18 °? I can calibrate the external temperature or the temperature of the room or you are telling me that after heating the lamp with the Turbo for a few minutes I tell him that the room is at 18 ° so that it who is hot thinks that all that heat is only 18 °, is that correct? Thank you.
Easiest way would be to simply replace the charging PCB with a pass-thru board. Should be cheap but Int'l shipping is always a problem. We do need the PCB board designed, then anyone could order it through a PCB service like OSHPark or a China based low cost PCB house like https://www.pcbway.com/. Not sure of the cost, but probably over $10 shipped.
This is about Anduril, not the WT90 flashlight as shipped.
With Anduril, to calibrate temperature, you tell it what the current light's temperature is by clicking "nn" times, like 18 times for 18C. So what he's saying is to calibrate the light way under what the true temperature is, therefore it effectively disables thermal regulation because if it's set to trip at 50C and the real temperature of the light is 50C, the processor thinks the temperature is only 5C, for example, and won't drop the output via thermal regulation.
Btw, I just quoted a 50x50 mm PCB at PCBWay.com and it came to $5 for qty 5, plus shipping. USPS shipping for US is $10 but there might be a cheaper option with them.
Qty 5 is minimum, but qty 10 costs no more. I'm not sure this board can be made and quoted that cheap though - might depend on other options, for example, if the thickness is greater than 1.6 mm, the price goes to $53!
In the end, I believe that paying VAT and shipping from China is not worth it. I am waiting for an already modified carrier that I believe will arrive sooner or later and I will buy that directly, by the way why don't you propose it to us TOM E, it would be a pleasure to buy it from you.
I asked if they have the PCB design files for the charging PCB. If so I should be able to modify them pretty easiely and could order a batch.
If not then it becomes much harder simply due to the precision that the mounting holes have to be and it being hard to properly align said holes. It can be done just a lot more work to start from scratch.
