WildTrail WT90 - SBT90.2 1800m+ throw 90mm 3x 21700 With Texas_Ace driver
Quite surprised to see the slow sale of the WT90. The Black version hardly moves on Ali Express’s web page for days, still 51 pieces available.
I have grabbed one Silver. Will wait to get one Black if the price drops later this year.
BTW, what happens to those large and expensive flashlights (each costing over US$200) which have been left unsold over the years? Just saw on Olight’s website, soon the new X9R will be on sale for about US$500. What will happen to the older Marauder 2, which is priced over US$200?
X9R has been around for a while. Marauder 2 came after it. The only thing that’s new is that it’s blue now. I imagine they will continue to carry both models. The X9R will go back up to $600 when the sale ends.
The same thing that happens to anything that does does not sell. Flashlights are no different.
Hi TA, It is possible for a "mere mortal" without too much experience to be able to disable the charging on the carrier ... I wish I could do it because I always use a spare pair of batteries and I prefer to recharge the batteries with my charger.
Excuse me how do I tell the lamp 18 °? I can calibrate the external temperature or the temperature of the room or you are telling me that after heating the lamp with the Turbo for a few minutes I tell him that the room is at 18 ° so that it who is hot thinks that all that heat is only 18 °, is that correct? Thank you.
Easiest way would be to simply replace the charging PCB with a pass-thru board. Should be cheap but Int'l shipping is always a problem. We do need the PCB board designed, then anyone could order it through a PCB service like OSHPark or a China based low cost PCB house like https://www.pcbway.com/. Not sure of the cost, but probably over $10 shipped.
This is about Anduril, not the WT90 flashlight as shipped.
With Anduril, to calibrate temperature, you tell it what the current light's temperature is by clicking "nn" times, like 18 times for 18C. So what he's saying is to calibrate the light way under what the true temperature is, therefore it effectively disables thermal regulation because if it's set to trip at 50C and the real temperature of the light is 50C, the processor thinks the temperature is only 5C, for example, and won't drop the output via thermal regulation.
Btw, I just quoted a 50x50 mm PCB at PCBWay.com and it came to $5 for qty 5, plus shipping. USPS shipping for US is $10 but there might be a cheaper option with them.
Qty 5 is minimum, but qty 10 costs no more. I'm not sure this board can be made and quoted that cheap though - might depend on other options, for example, if the thickness is greater than 1.6 mm, the price goes to $53!
In the end, I believe that paying VAT and shipping from China is not worth it. I am waiting for an already modified carrier that I believe will arrive sooner or later and I will buy that directly, by the way why don't you propose it to us TOM E, it would be a pleasure to buy it from you.
Unfortunately I haven't had the time to spend to teach myself PCB design. Not sure if TA was thinking of doing it, or how easy/difficult, etc.
I'm not well experienced with Int'l shipping, either, but from past experiences it's not cheap.
I asked if they have the PCB design files for the charging PCB. If so I should be able to modify them pretty easiely and could order a batch.
If not then it becomes much harder simply due to the precision that the mounting holes have to be and it being hard to properly align said holes. It can be done just a lot more work to start from scratch.
If you have a hot air gun it is not hard, just remove everything and bypass the FET’s.
I am going to try testing if you can only remove the charging IC as well when I get mine.
Id be interested in buying a pcb if cost with shipping is under $20.
Easiest maybe is if a pcb design is uploaded to Oshpark , even with the newest tax rules my guess is that it is around 10 dollar shipped worldwide. The only downside that you get 3 pieces instead of one.
Can anyone measure the thickness of the board? I can't right now. OSHPark only does 1.6 mm boards, least at reasonable prices.
Mine reads 1.5mm…
Sounds close enough - if 1.6 mm works, price will depend on board diameter, though I'm not sure about the cutout requirements (recessed screws, etc.).
1.6mm should be fine, the end cap on the carrier supports the load so no need for a thicker one.
Wildfire said they are going to try to send me the PCB files next week, assuming they are in a format I can use I should be able to edit them to delete the charging circuit pretty easily.
It could then be uploaded to oshpark although they can be expensive for larger PCB’s like this.
Can’t hurt to have it on Oshpark, even if a cheaper way can be found to have them built.
