And wouldn’t you know it, Handskit came through on my Amazon question post.
P0 is still MIA, but here are the others:
P01 [operational amplifier gain (200~350 times, the first step, the default value is 270.]
P02 [Op amplifier bias voltage (0~250mV, step 2, the default value is 100, which means that the soldering iron tip maintains the inherent output voltage of the room temperature operational amplifier. If you do not measure, please keep the default value.]
P03 [Increase the temperature, adjust the temperature 30-50℃.]
P04 [Temperature step adjustment (0, 1, 2, 5, 10 degrees optional, 0 can lock the temperature of the soldering iron)]
P05 [Sleep repair time (set time for entering sleep state) (0~60 minutes, step 1 is 0, sleep function is disabled)]
P06 [shutdown time (0~180 minutes, step 1 is in 0~30, step 10 is in 30~180, 0 is disabled)]
P07 [Temperature correction (–30~+30 degrees, the first step) (Because the NTC resistance is in the chassis, the soldering station will cause the detected NTC temperature to be higher than room temperature, resulting in high compensation for the cooling capacity) thermocouple junction Point, and the temperature of the soldering iron is not accurate (you can use this parameter to correct. For example, if the detected soldering iron temperature is 20 degrees higher than the actual value, set this parameter to –20)]
P08 [Wake-up mode during sleep (0, 1, 0 means that the encoder can be rotated in shutdown mode, and the handle can be awakened by vibrating the handle. For 1, only the rotary encoder can wake up)]
P09 [Temperature plus strength (click on the encoder to input the temperature of the solder joint suddenly needed)]
P10 [temperature enhancement time (enhancement time…)]
P11 [Automatic save time of parameter setting mode and return to the effective time of heating mode function.]
P12 [Buzzer switch (0 means off and 1 means on)]
