when head and tail are off, and head gets assembled first
the black inner tube can get pushed from the head end, and moves towards the tail
now if the tail is screwed down against the overly protruding inner sleeve, the switch gets pressed into constant ON position?
the ring around the top of the black tube must seat against the lip in the body, the O ring should not lift the black tube above the edge of the body too far.
Push the black sleeve into the body until the O ring is pressed to move below the lip on the inside of the body. The metal ridge around the top of the black sleeve, should press against the ledge inside the body tube, not just the O ring.
the black sleeve needs to be fully seated into the tail end of the body, tighten the tail first, accomplishes this.
or another explanation
when assembling the light, if the head wobbles a bit while screwing it down, the switch might get a double tap command… to go to ceiling… not sure
I have slapped and tapped my light in all directions, trying to cause the problem, and I cannot duplicate it yet. Once the light is assembled and working properly, it has not spontaneously shorted out. Only during assembly… particularly when installing the clip and using the tailcap to pressure the clip ring down past the O ring. This could be wiggling the contact of the black sleeve against the switch, on the inside… maybe?
I also fear hot anduril lights
simple mode eliminates turbo
and sets a more moderate ceiling
the danger of the FW design is the FET output
and the Hair Trigger Switch
it is for the people that want more than 1000 lumens, and are willing to carry it locked out. The switch was chosen because it is very flat, making the light suprisingly small.
But it is not a save switch to carry unlocked. For that we would need a mechanical clicky.
fwiw
Novatac and HDS use signal springs and wires too, They also use electronic switches, but with MUCH higher activation pressures…
A signal tube is not much different than a spring or a wire, they just have to make proper contact at both ends, and not get jiggled into fooling the switch into thinking it was double tapped while closing the tailcap
this is the primary design advantage of sideswitch lights, which are all electronic switch designs,
most tailswitches are mechanical not electronic
exceptions being Novatac, HDS, FWxx and Noctigon Kxx
eSwitch on the tail makes them fatter
:student:
this sounds like the best explanation, mine did ramp up and simply ignored the switch… it has happened at least 3 separate times, after I had both head and tail off… and was trying the clip at both ends and screwing around with the body orientation too.
definitely check that the retaining rings are not loose. mine had a loose retainign ring in the head… but it is tight, and Ive still had the assembly short, with ramping… its just a thing that happens after having both ends off, such as when installing and removing the clip, or such…
I have had an aluminum with 219c since release and also have a copper with SST20 that I’ve been using daily this past week. Both have H10s in them and no issues at all so far. Just sharing my experience, hopefully it stays that way.
However on the FW3A, I notice that the switch actually works better when the retaining ring in the tailcap is very slightly loose. My theory is when it is too tight, the switch pcb is held flush with the tailcap. If this is even a minute fraction out of alignment with the inner tube, the tube won’t make firm contact with the entire contact surface on pcb.
It works better if the tailswitch can free float slightly.
I mostly leave the FWAA unlocked on my desk
have not pocket carried it mutch, dont trust the clip, nor the switch
I dont lock, but I set the ceiling to 400 lumens and use in simple mode, which prevents Turbo
fwiw, troubleshooting tips
another potential way to short the body tube to the black sleeve is accumulated lubricant… if a problem appears, a wipe out with a bit of alcohol can restore proper function. This issue was also present with Novatacs, that would become unreliable as they aged. sometimes they just need a good cleaning…
With Anduril-2 being newer than Anduril-1, I would hope that all versions would incorporate the "stuck switch safety feature" of Anduril-1 to protect against the behavior described in this thread, but I do not have a Lumintop FWAA or any light with Anduril-2 to test this feature. I am also assuming that an "inner control tube short circuit" or a "stuck switch" would be treated the same by Anduril since it would probably not be able to tell the difference between the two.
Newer versions of Anduril-1 incorporated a "stuck switch safety feature" where if the switch is held down continuously, the light will ramp up to maximum brightness, but after the light reaches maximum brightness it will only stay at maximum brightness for a few seconds and then automatically ramp down to minimum brightness and if the switch is still being held down, then after another few seconds the light will blink and enter lockout mode.
Both my Sofirn SC31 Pro with Anduril-1 version 2020-03-18 and my Sofirn LT1 with Anduril-1 version 2019-11-29 have the "stuck switch safety feature". I believe Anduril-1 version 2019-09-24 added an automatic ramp to minimum brightness if the switch was held down continuously (this version also added the "15+ clicks from off" version check function) and Anduril-1 version 2019-09-28 added the "stuck switch safety feature" (automatic lockout if the switch remains held down long enough).
I have Lumintop FW3A lights with old versions of Anduril-1 that do not have the "stuck switch safety feature" (or the version check function) and I do notice on these type of lights with the "inner control tube" that if I loosen the light's head enough, I will lose the "inner control tube signal" even though battery power can still be supplied to the LED through the outer tube, so if I do this while the light is at maximum brightness it will stay at maximum brightness and I cannot control the light with the switch to turn it off so the "stuck switch safety feature" would not work in this case even if the version of Anduril supported it.
thanks for sharing your experience, it has helped me take the leap
mine seems fine overall, I came prepared to check for loose retaining rings… not a big deal… and the light has been reliable, once successfully assembled…
it definitely gets bright, and hot, but I was able to adjust settings to suit my modest preferences
its a fun little light
wow, thats cool
my FWAA does that too
starting from off, unlocked,
IF I hold the button down it ramps up and back down
Biggest issue I had with an FWAA was a driver wire desoldering itself from the star of my FWAA Ti.
… but it wasn’t the light’s fault.
I had used the shortcut to turbo from off of “click + click-hold”.
That mode gives instant access to turbo and overrides the thermal protection as long as you hold the button down. After all, if you’re holding the button down, you shouldn’t need thermal protection…. you’ll release the button when your hand starts to burn long before the light is damaged.
Well that’s probably true for the aluminum and copper versions. Not so much for the all-titanium version where the head can be burning hot while the back of the light remains cool to the touch.
Fortunately, it was fairly easy to resolder the bondwire back on.
I’m running H10 in both of my FWAA and the only issue i had was their poor soldering on conntact wires to the MCPCB. Once resdered and cleaned it works perfect.
Another (default) safety feature is double clicking going to top of the ramp instead of max, unless the light is already adjusted to top of ramp. But I’m one of few (if not the only one) loving this feature. Likey being removed in customized versions. How’s the FW* firmware working?
I find the 2C command inconsistent
In Advanced, from ON it does not produce the same result, depending when it is used, as you described.
I do like that 2C gives ceiling, in Advanced, in other circumstances.
And 2C from Off, and also from ON, in Simple mode, gives ceiling, not Turbo.
I like that consistency, in Simple mode.
also, 2H is an inconsistent command
In Advanced, from Off 2H produces 150/150 (“Turbo”), but from ON it produces down ramping.
Awesome, thanks for all the potential fixes. Still love the light; A2 is incredible and I truly understand why TK made it “essentially” muggle mode from factory. The lights just not trustworthy at the moment.
Before I started fiddling with inner sleeve and retaining rings. I decided to put efest button top back in, and she works flawless again.
But still pulled apart to give everything a good crank. I didn’t turn GREEN. Still everything is tight and centered. It makes me wonder if cell length and pressure on the driver board is playing a sneaky part. In why Flat top H10 isn’t tolerated in my sample
So far that is the case for one user. It does not appear that anyone else has reproduced these results, and I would wager the majority of FWAA owners are using the H10 cells in question.
Edit: If I were you and you want one, I would purchase from Killzone since you appear to be in the US. In the case that you do receive a bad light, their customer service is excellent. I haven’t looked at their stock recently but I know they carry the FWAA.
My solution for my dangerous as hell fw3a was to take the battery out and never put another in there, although I don’t think heat is an issue anymore since it did get hot enough to give me second degree burns and desolder 2/3 LEDs.
