I have had an aluminum with 219c since release and also have a copper with SST20 that I’ve been using daily this past week. Both have H10s in them and no issues at all so far. Just sharing my experience, hopefully it stays that way.
However on the FW3A, I notice that the switch actually works better when the retaining ring in the tailcap is very slightly loose. My theory is when it is too tight, the switch pcb is held flush with the tailcap. If this is even a minute fraction out of alignment with the inner tube, the tube won’t make firm contact with the entire contact surface on pcb.
It works better if the tailswitch can free float slightly.
I mostly leave the FWAA unlocked on my desk
have not pocket carried it mutch, dont trust the clip, nor the switch
I dont lock, but I set the ceiling to 400 lumens and use in simple mode, which prevents Turbo
fwiw, troubleshooting tips
another potential way to short the body tube to the black sleeve is accumulated lubricant… if a problem appears, a wipe out with a bit of alcohol can restore proper function. This issue was also present with Novatacs, that would become unreliable as they aged. sometimes they just need a good cleaning…
With Anduril-2 being newer than Anduril-1, I would hope that all versions would incorporate the "stuck switch safety feature" of Anduril-1 to protect against the behavior described in this thread, but I do not have a Lumintop FWAA or any light with Anduril-2 to test this feature. I am also assuming that an "inner control tube short circuit" or a "stuck switch" would be treated the same by Anduril since it would probably not be able to tell the difference between the two.
Newer versions of Anduril-1 incorporated a "stuck switch safety feature" where if the switch is held down continuously, the light will ramp up to maximum brightness, but after the light reaches maximum brightness it will only stay at maximum brightness for a few seconds and then automatically ramp down to minimum brightness and if the switch is still being held down, then after another few seconds the light will blink and enter lockout mode.
Both my Sofirn SC31 Pro with Anduril-1 version 2020-03-18 and my Sofirn LT1 with Anduril-1 version 2019-11-29 have the "stuck switch safety feature". I believe Anduril-1 version 2019-09-24 added an automatic ramp to minimum brightness if the switch was held down continuously (this version also added the "15+ clicks from off" version check function) and Anduril-1 version 2019-09-28 added the "stuck switch safety feature" (automatic lockout if the switch remains held down long enough).
I have Lumintop FW3A lights with old versions of Anduril-1 that do not have the "stuck switch safety feature" (or the version check function) and I do notice on these type of lights with the "inner control tube" that if I loosen the light's head enough, I will lose the "inner control tube signal" even though battery power can still be supplied to the LED through the outer tube, so if I do this while the light is at maximum brightness it will stay at maximum brightness and I cannot control the light with the switch to turn it off so the "stuck switch safety feature" would not work in this case even if the version of Anduril supported it.
thanks for sharing your experience, it has helped me take the leap
mine seems fine overall, I came prepared to check for loose retaining rings… not a big deal… and the light has been reliable, once successfully assembled…
it definitely gets bright, and hot, but I was able to adjust settings to suit my modest preferences
its a fun little light
wow, thats cool
my FWAA does that too
starting from off, unlocked,
IF I hold the button down it ramps up and back down
Biggest issue I had with an FWAA was a driver wire desoldering itself from the star of my FWAA Ti.
… but it wasn’t the light’s fault.
I had used the shortcut to turbo from off of “click + click-hold”.
That mode gives instant access to turbo and overrides the thermal protection as long as you hold the button down. After all, if you’re holding the button down, you shouldn’t need thermal protection…. you’ll release the button when your hand starts to burn long before the light is damaged.
Well that’s probably true for the aluminum and copper versions. Not so much for the all-titanium version where the head can be burning hot while the back of the light remains cool to the touch.
Fortunately, it was fairly easy to resolder the bondwire back on.
I’m running H10 in both of my FWAA and the only issue i had was their poor soldering on conntact wires to the MCPCB. Once resdered and cleaned it works perfect.
Another (default) safety feature is double clicking going to top of the ramp instead of max, unless the light is already adjusted to top of ramp. But I’m one of few (if not the only one) loving this feature. Likey being removed in customized versions. How’s the FW* firmware working?
I find the 2C command inconsistent
In Advanced, from ON it does not produce the same result, depending when it is used, as you described.
I do like that 2C gives ceiling, in Advanced, in other circumstances.
And 2C from Off, and also from ON, in Simple mode, gives ceiling, not Turbo.
I like that consistency, in Simple mode.
also, 2H is an inconsistent command
In Advanced, from Off 2H produces 150/150 (“Turbo”), but from ON it produces down ramping.
Awesome, thanks for all the potential fixes. Still love the light; A2 is incredible and I truly understand why TK made it “essentially” muggle mode from factory. The lights just not trustworthy at the moment.
Before I started fiddling with inner sleeve and retaining rings. I decided to put efest button top back in, and she works flawless again.
But still pulled apart to give everything a good crank. I didn’t turn GREEN. Still everything is tight and centered. It makes me wonder if cell length and pressure on the driver board is playing a sneaky part. In why Flat top H10 isn’t tolerated in my sample
So far that is the case for one user. It does not appear that anyone else has reproduced these results, and I would wager the majority of FWAA owners are using the H10 cells in question.
Edit: If I were you and you want one, I would purchase from Killzone since you appear to be in the US. In the case that you do receive a bad light, their customer service is excellent. I haven’t looked at their stock recently but I know they carry the FWAA.
My solution for my dangerous as hell fw3a was to take the battery out and never put another in there, although I don’t think heat is an issue anymore since it did get hot enough to give me second degree burns and desolder 2/3 LEDs.
yes, there is a battery length limit
the H10 is not too long
I have had the same issue as the OP, that sometimes when I assemble the light, it goes into Automatic ramp up, and the only way to turn it off is to remove the battery, and reassemble in the correct order, tighten the tail over the clip first. Tighten the head last.
Im dont think the issue the OP had is battery related. As I said, Ive had the same issue, and imo it is an assembly problem…
imo, the FWAA is entertaining, finnicky, and dangerous. I dont recommend it as an edc due to the button being too sensitive, and Im not a fan of 4 clicks every time I want to use a light… works fine unlocked, on my desk.
for EDC, I still vastly prefer the Jetbeam RRT-01. It has none of the dangers of the FWAA, wont turn on in pocket, no need to lock out, always starts at a safe level, and dead simple to dial in the right amount of light, intuitively.
The FWAA otoh, requires ramping up and down to find the sweet spot, and ramping down is not a consistent commant, sometimes it just requires 1H, other times it requires 2H…
the mental overhead to use a FWxx is quite demanding… having to remember what memory mode was set to, whether to turn on with a click or with a hold… reading the manual to change settings… worrying about burns… none of that comes into play with an RRT-01
oh and the clip on the FWAA is imo, not very secure… the RRT-01 pocket clip is far superior…
I like the RRT-01 too. Specifically, the 2014 edition. I find the 2019 and 2020 versions just a bit too heavy. If only they used an aluminum instead of brass pill.
However, the 2014 RRT-01 isn’t perfect:
The ring takes space. While not large, the RRT-01 certainly isn’t the smallest light around for its battery type.
I thought the ring was intuitive too. But when I handed my RRT-01 to someone she tried to press on the lanyard ring on the back and wondered why the switch didn’t work.
While the ring isn’t likely to accidentally turn on in the pocket, I have had it happen. The ring is loose enough and the knurling grippy enough that just shifting around in my pocket did cause an accidental turn-on. This is disturbing since the 2014 RRT-01 has no low-voltage protection. Still… this only happened to me once, so the chances are very low.
Low output. Even when updated with a 2020 RRT-01 driver, the output on an RRT-01 isn’t going to blow your socks off. I wish they had a driver that provided as much output as the RRT-03, but with the UI of the RRT-01.
Overall, I still rate the 2014 RRT-01’s UI as probably the fastest to use and most intuitive out there.
The button on my FW3A was too sensitive for my liking. I had gotten into the habit of doing a hard lockout by twisting the head slightly. But then I saw a tip about removing the nubbin from the switch (under the metal cover) and installing a small O-ring in place of it. That worked! My FW3A has a nice firm click that I like. No accidental activations. I’m wondering if the same kind of mod is possible with the smaller switch of the FWAA…
I agree that the control ring on the RRT-01 is often too loose from factory.
I take pains to remedy that, so the ring cannot turn unless I do it deliberately
also agree the RRT-01 is a bit Phat, but I forgive that, for the ability to use 18350.
I also prefer the earlier model, it is not as large in diameter, and not as heavy as the 2019 and 2020 models, but beggars cant be choosers, and imo, any RRT-01 is worth the experience of the Rotary UI.
output is the only reason to choose an Anduril light over a Rotary, imo
for my needs a single LED with a focused hotspot is much more efficient, AND has higher LUX on target, than a FWAA
my FWAA set to 200 lumens, has almost 3 times more output than my 80 lumen Novatac,
but the Novatac hotspot is 3x brighter on target (much more efficient power consumption)
