I’m running H10 in both of my FWAA and the only issue i had was their poor soldering on conntact wires to the MCPCB. Once resdered and cleaned it works perfect.
Another (default) safety feature is double clicking going to top of the ramp instead of max, unless the light is already adjusted to top of ramp. But I’m one of few (if not the only one) loving this feature. Likey being removed in customized versions. How’s the FW* firmware working?
I find the 2C command inconsistent
In Advanced, from ON it does not produce the same result, depending when it is used, as you described.
I do like that 2C gives ceiling, in Advanced, in other circumstances.
And 2C from Off, and also from ON, in Simple mode, gives ceiling, not Turbo.
I like that consistency, in Simple mode.
also, 2H is an inconsistent command
In Advanced, from Off 2H produces 150/150 (“Turbo”), but from ON it produces down ramping.
Awesome, thanks for all the potential fixes. Still love the light; A2 is incredible and I truly understand why TK made it “essentially” muggle mode from factory. The lights just not trustworthy at the moment.
Before I started fiddling with inner sleeve and retaining rings. I decided to put efest button top back in, and she works flawless again.
But still pulled apart to give everything a good crank. I didn’t turn GREEN. Still everything is tight and centered. It makes me wonder if cell length and pressure on the driver board is playing a sneaky part. In why Flat top H10 isn’t tolerated in my sample
So far that is the case for one user. It does not appear that anyone else has reproduced these results, and I would wager the majority of FWAA owners are using the H10 cells in question.
Edit: If I were you and you want one, I would purchase from Killzone since you appear to be in the US. In the case that you do receive a bad light, their customer service is excellent. I haven’t looked at their stock recently but I know they carry the FWAA.
My solution for my dangerous as hell fw3a was to take the battery out and never put another in there, although I don’t think heat is an issue anymore since it did get hot enough to give me second degree burns and desolder 2/3 LEDs.
yes, there is a battery length limit
the H10 is not too long
I have had the same issue as the OP, that sometimes when I assemble the light, it goes into Automatic ramp up, and the only way to turn it off is to remove the battery, and reassemble in the correct order, tighten the tail over the clip first. Tighten the head last.
Im dont think the issue the OP had is battery related. As I said, Ive had the same issue, and imo it is an assembly problem…
imo, the FWAA is entertaining, finnicky, and dangerous. I dont recommend it as an edc due to the button being too sensitive, and Im not a fan of 4 clicks every time I want to use a light… works fine unlocked, on my desk.
for EDC, I still vastly prefer the Jetbeam RRT-01. It has none of the dangers of the FWAA, wont turn on in pocket, no need to lock out, always starts at a safe level, and dead simple to dial in the right amount of light, intuitively.
The FWAA otoh, requires ramping up and down to find the sweet spot, and ramping down is not a consistent commant, sometimes it just requires 1H, other times it requires 2H…
the mental overhead to use a FWxx is quite demanding… having to remember what memory mode was set to, whether to turn on with a click or with a hold… reading the manual to change settings… worrying about burns… none of that comes into play with an RRT-01
oh and the clip on the FWAA is imo, not very secure… the RRT-01 pocket clip is far superior…
I like the RRT-01 too. Specifically, the 2014 edition. I find the 2019 and 2020 versions just a bit too heavy. If only they used an aluminum instead of brass pill.
However, the 2014 RRT-01 isn’t perfect:
The ring takes space. While not large, the RRT-01 certainly isn’t the smallest light around for its battery type.
I thought the ring was intuitive too. But when I handed my RRT-01 to someone she tried to press on the lanyard ring on the back and wondered why the switch didn’t work.
While the ring isn’t likely to accidentally turn on in the pocket, I have had it happen. The ring is loose enough and the knurling grippy enough that just shifting around in my pocket did cause an accidental turn-on. This is disturbing since the 2014 RRT-01 has no low-voltage protection. Still… this only happened to me once, so the chances are very low.
Low output. Even when updated with a 2020 RRT-01 driver, the output on an RRT-01 isn’t going to blow your socks off. I wish they had a driver that provided as much output as the RRT-03, but with the UI of the RRT-01.
Overall, I still rate the 2014 RRT-01’s UI as probably the fastest to use and most intuitive out there.
The button on my FW3A was too sensitive for my liking. I had gotten into the habit of doing a hard lockout by twisting the head slightly. But then I saw a tip about removing the nubbin from the switch (under the metal cover) and installing a small O-ring in place of it. That worked! My FW3A has a nice firm click that I like. No accidental activations. I’m wondering if the same kind of mod is possible with the smaller switch of the FWAA…
I agree that the control ring on the RRT-01 is often too loose from factory.
I take pains to remedy that, so the ring cannot turn unless I do it deliberately
also agree the RRT-01 is a bit Phat, but I forgive that, for the ability to use 18350.
I also prefer the earlier model, it is not as large in diameter, and not as heavy as the 2019 and 2020 models, but beggars cant be choosers, and imo, any RRT-01 is worth the experience of the Rotary UI.
output is the only reason to choose an Anduril light over a Rotary, imo
for my needs a single LED with a focused hotspot is much more efficient, AND has higher LUX on target, than a FWAA
my FWAA set to 200 lumens, has almost 3 times more output than my 80 lumen Novatac,
but the Novatac hotspot is 3x brighter on target (much more efficient power consumption)
I also find the ring of my RRT-01 just a bit too easy to turn. There is a notable detent for on/off, but with the right swipe pressure against my wrist or something in passing and the ring can turn. So for me, I always do a hard lockout. But… I don’t EDC this light because the FW3A isn’t painfully much larger and it’s totally workable for my needs (plus an 18650 is more versatile than CR123 or 18350). Better tint as well (XP-L HI 3D). I really do appreciate the low light adjustability of the magnetic ring RRT-01. Seriously useful. I really wish Jetbeam had done the Sunwayman design of having a separate on/off switch.
The FWAA looks to be about RRT-01 sized. I’m expecting it’ll be nicer to pocket. I’m just hoping the switch mod is possible to reduce accidental activation… but I’ve been so accustomed to the small twist for lockout, I really won’t mind if I have to resort to that again.
Thanks for the comparison shots, Jonathan. I guess for your needs you use your EDC for more longer range tasks, hence the desire for a focused hotspot?
One thing I do enjoy about the NovaTac 120P is that it has reasonable spill. I just don’t care for the tint… That FWAA tint looks wonderful in comparison. I seems to be just a weaker version of the FW3A. For close range tasks, I enjoy a good rich spill. But if I’m needing to focus on something small and for detail, a concentrated hotspot is certainly preferable. The Lumintop Tool AA should suffice for that, I think.
To ShyOne, The FWAA is a noteworthy light and if Freeme had a C3PO version aka brass I would’ve been willing to purchase. Even with this experience in my sample. Hopefully that explains how much I like it.
But that being said I wouldn’t trust my sample being in the glove box of my vehicle.
I do want to show my appreciation for all the constructive advice
The FWAA is much smaller than any version RRT-01. It’s smaller than a Sofirn SP10b. It’s about the same size as an Eagletac D25c! It’s downright tiny. It just vanishes inside a pocket.
The o-ring mod that worked for the FW3A also works on the FWAA, using the same size o-rings.
yes, there are excellent high CRI LED choices for the FWAA
I agree that the stock LED in the RRT-01 is no match (I tend to forget all mine have High CRI LED swaps)
and the FWAA also costs less… a lot of bang for the buck
The FWAA is indeed quite small and cute… it has a lot going for it
notwhitstanding that I find the clip and switch, and Turbo heat, problematic for EDC
I wish the clip were a bit better on the FWAA. I don’t like the bi-directly clip. It sticks out more, and the reverse lip sometimes gets caught when I fish the light out of my pocket. I’d much rather have a good single-direction clip like the FW3A, Eagletac D25 or RRT-01.
Fantastic! Thanks for the confirmation. That switch mod made for a nice adjustment to the FW3A. Nice knowing I won’t have to do a twist lockout on the FWAA (although 4 clicks to put into momentary mode can work as well).
Switch mod should fix the touchiness. As for Turbo, haven’t you said in other posts about never really needing full turbo mode, that you tend to use medium & lower modes? If anything, at least you can programmatically set a lower limit. I’ve used full turbo on my FW3A on occasion. Yeah, it can get rather hot. It’s just fine for a momentary use. Having “bigger gun” lights for major throw can serve that purpose for longer sustained beam. The FW3A is a very small size for an 18650… same as a ZL SC64. And while it can work in a front pocket location, it’s nicer to have something smaller there. It’s of course terrific for a jacket pocket.
There’s bound to be a clip floating around out there by another maker that could work, given this size… do you think?
