It really would’ve been nice if the color control was made as a menu shunt off of the main Anduril UI menu. Anduril is so rich… and sacrificing that for temperature control is too much of a disappointment. If it doesn’t sell well, maybe Lumintop will reconsider this for a replacement.
Well, with primary Anduril 2, you get a light in Simple UI mode and the user can simply stay in Simple. It’s actually quite nice. But it would be nice to then add the 2 separate emitter cluster controls as another menu item. And also make that available in Advanced. So if a light is equipped with 3 emitters, it’ll be 2 groups where one has emitters #1 & #2, and second has just emitter #3. And with 4 emitters, two sets of 2 emitters. Doesn’t matter what tint. But if a light is designed with 2 sets of different temperature emitters, they’d be mounted in the predefined groups for independent control.
So it would probably need its own version of Anduril, if it can run it. We would need to see the other side of the driver too, to see if it has an ATTiny85 chip or not. Would you be able to show that?
Yeah, I take back my earlier comment. Leds can be swapped but this ui and heavy thermal step-down are big issues. A shame, as lumintop finally got 900lm sustained in the fw3x not long ago.
900 sustained in an ice bath maybe. Take from the review below “Without any cooling or heatsinking (air, hand) the maximum sustained output is below 300 lumens if you want to keep the surface temperature below 50°C.”
Is that just your impression or have you tested it in an integrating sphere?
My recollection from reading reviews of people who did test their lights for runtime and output was that the FW3A sustains around 300 lumens (and that’s the cool white XPL HI version) and the Emisar D4 (also XPL HI version) only sustains around 500 lumens.
Sustaining high output is actually quite difficult for small single cell lights. Even a Zebralight SC700, which uses a 21700 cell and is much larger than an FW3A with vastly superior heatsinking and an XHP 70.2 led barely manages to sustain 1000 lumens.
I own several FW3As and I think the estimate of around 300 lumens sustained is about right. These are tiny pocket rockets with no real heatsinking. It’s not surprising they dim fast. My Zebralight SC64w and SC64w HI stabilize at a much higher output than an FW3A… not suprising considering how good Zebralight’s heatsinking is (unibody construction with lots of heat sink fins).
