tactical mode just means that whatever mode you were in when you do 5C, that mode becomes momentary ON only
so yes, to get out of momentary, you cannot give a 5C command, or any other command, ONLY momentary on works… that is True Tactical… being able to click out of tactical is not tactical… See what I did there? LOL
fwiw, HDS Tactical mode also requires removing the tail to break battery contact. And an HDS, same as Anduril lights, gives a sigle flash during reassembly, to inform that contact is achieved.
Does anyone know the simplest way to tell Anduril from Anduril 2 running Adv UI? There's so much overlap, it's hard to tell, at least in the simplest way.
I’m probably not understanding your question, but if trying to determine which version is on a particular light your handling, 2C to turbo from off isn’t viable with AN-2 (without programming it as ramp ceiling).
Ok, I got 200+ lights. So managing 200+ PDF's is not an option, specially when the manufacturer's PDF's don't help on a modded light.
So picking one up, how do I know what it's running? I can't remember... So, one way I think is 15C for the rev #'s. The method has to be not effected by config setting changes.
I got NarsilM, Anduril, and Anduril2 - NarsilM is easy to tell, but telling Anduril from Anduril 2 is more subtle.
there are a few details in the Anduril 2 flow chart, that are not quite the same in the FWAA… for example, in the mode menu, there are three separate single flashes, not single, double, triple
here is my version of the FWAA flow chart:
fwiw, the Anduril 2 Manual instructions are also slightly different than the FWAA version of Anduril 2. For example, in the FWAA the thermal config comes after the beacon, not after the batt check… the flow chart Im posting has that corrected. I hid the 2C to Turbo command, under a blue box. That command does not work in the Anduril 2 FWAA (with an exception, that IF I first ramp to ceiling in advanced, then 2C will give 150/150… this is all very inconsistent)
I have a love hate relationship with Andruil. I think it gave our light features that were otherwise not possible. This all come at the cost of a steep learning curve. Personally, if I like a light (like most convoy’s,) I don’t care of it has a proprietary UI. One of the most highly regarded lights is the Zebralight and the interface is proprietary. Its also kind of weird.
I've been staying away from Convoys lately - most are power switches which I think are outdated, but do have a simple UI. For e-switches, I did buy the 3X21A w/SFT-40's but his ramping is linear: too fast on the low end, too slow on the high end, and doesn't allow you to ramp up from the lowest setting, so if your last used level is max, and you want to come on lower, your only choices is get blasted by max or go in a limited lowest moon level. It's almost there but not quite. He also amp limited this light to about 17 amps - ok for novices but I would want 20-24 amp capability on short bursts with these LED's.
I'm working on an Anduril 2 mod for this light now, but he's got the charging circuit intermingled with the LED driver circuit, so not sure I can keep the charging in tact.
Arguably, the best UI is one that you can figure out without a manual. When you sit down with Microsoft Word, if you need a function you have never used, most likely you can figure it out in a few minutes, even without Google. Microsoft spends millions of dollars in usability labs to do things like this.
Andrul missed the mark big time when it comes to this goal.
This is one of my issues with Anduril, in that there are significant differences between lights (such as ramp floor/ceiling levels, turbo on/off in Simple UI, differences to strobe options), yet manufacturers who sell lights with Anduril don’t document these changes with specific instructions or flow charts.
I agree, but, were being too rational
Anduril caught on like wildfire because its got FET Powa!
and blinkies
and aux lights
and lighted buttons
and fancy metals
and high CRI LEDs…
and multi click command manuals
Even Microsoft can't perform miracles w/1000 software engineers for a UI that has one button. Let's be reasonable. I'd love to have 3-4 buttons or so, and a LED display panel, that's about the best we can do with controls, and using a phone or desktop app to display and configure settings would be a big plus.
