Test/review of Vapcell S4+ fast charger
106 posts / 0 new
TimMc
TimMc's picture
Last seen: 4 hours 47 min ago
Vapcell S4 plus upgraded version (July 2020):
NiMH Cap test in auto mode #1:
Slot 1: AAA eneloop 750mAh finished with 1.51V 0000mAh (08:31h)
Slot 2: AAA eneloop 750mAh finished with 1.52V 0709mAh (03:51h)
Slot 3: AAA eneloop 750mAh finished with 1.53V 0685mAh (04:21h)
Slot 4: AAA eneloop 750mAh finished with 1.52V 0684mAh (03:53h)
Slot 1 and 3 had cells that started off at around 1.35V.
Slot 2 and 4 had cells that started off at around 1.45V.
Slot 1 took a while to begin the discharge step. When it did start to discharge, it just switched between ~500mA and 0000mAh. Eventually it finished discharge and charged back up to 1.52V. 0000mAh displayed for capacity.
NiMH Cap test in auto mode #2:
Slot 1: AAA eneloop 750mAh finished with 1.53V 0729mAh (04:19h)
Slot 2: AAA eneloop 750mAh finished with 1.52V 0700mAh (04:01h)
Slot 3: AAA eneloop 750mAh finished with 1.53V 0704mAh (04:02h)
Slot 4: AAA eneloop 750mAh finished with 1.52V 0674mAh (03:14h)
ChibiM
ChibiM's picture
Last seen: 1 day 8 hours ago
These messages don't give me much hope. I will wait till they fix these issues.
It's literally been on my wishlist for a month or so, but since the new one was announced I kept postponing, and I feel like it was released a little prematurely.
gchart
gchart's picture
Last seen: 3 hours 5 min ago
Yeah I bought one many months ago and generally like it, but it’s not without it’s faults. If testing would have identified these problems before production, this would be an amazing charger.
ChibiM
ChibiM's picture
Maybe I'll just wait for the BLF UC4 charger to be produced.. I just want a charger that can take my 21700 protected cells.
Havok
Last seen: 3 months 4 weeks ago
TimMc wrote:
Sometimes the voltage displayed while charging in Charge mode is 4.20V when it’s actually 4.07V when measured on a UT210E. Even though it might show 4.20V, it also displays >90% and keeps charging. If I take the cell out and put it back in, it then shows 4.07V and gradually goes up as it charges.
I just bought the original, and I have a 21700 cell that does something like this.
I put my cell in slot #4, charged it at 1000mAh.. and it would charge up to what it claimed was 4.20V, but my meter always read 4.07V.
So, just for laughs, I took that cell, put it in Slot #1 and set it to 1500mAh. Oddly, it seemed to realize it wasn’t full. Screen displayed 4.20V, 99% the whole time. I terminated the charge early after 25mins…. was too worried the cell would grenade.
Off the charge.. with my meter it now states 4.11V
Not sure if it’s a slot, or charging current issue (on my part). I’ll have to try it again in slot #4 at 1500mAh next time.
TimMc
TimMc's picture
Is the S4+ meant to be able to automatically select 250mA when charging 10440 cells?
I noticed the S4+ charging my Vapcell INR10440 cell at 500mA in auto Charge mode. It was around 4.07V. I quickly took the cell out and switched the S4+ to manual mode and charged the cell at 250mA until full.
To see whether it would automatically select 250mA to charge 10440 cells, I discharged two Vapcell INR10440 cells to around 3.96V (measured with DMM). I then put them in slot 1 and 4 using auto Charge mode. They started charging at 1000mA.
It seems like 230-270mA is selected automatically when the 10440 cell is near 4.20V in auto Charge mode. But a higher current is used if the cell voltage is less than or near 4.00V. The current is reduced when the cell is nearly full.
d_t_a
Last seen: 1 day 5 hours ago
Per my observation, the S4+ uses the battery resistance measurement to determine charge current when set to Auto mode.
This would mean a low-resistance small battery may be charged at possibly too high current.. although I’m not sure how this would look like in actual (eg. what are the cut-off resistance values versus the automatic charge current applied.)
contactcr
Last seen: 54 min 44 sec ago
Can confirm. Put in two vapcell 10440s. Resistance was in the mid or high 80s. Both at 500 on auto. I changed it by long pressing in auto mode.
TimMc
TimMc's picture
IR was about 67mOhm for the 10440s when they started charging at 1000mA and started with 3.96V.
GDF
Last seen: 3 hours 10 min ago
I bought this a few months ago and I generally like it. I noticed that it will charge smaller batteries like a 10440 at a higher charge rate than expected in auto. It also displays voltage at 4.20 when the battery is at 90% and charging. It would nice if the firmware could be updated somehow.
TimMc
TimMc's picture
I removed the piezo speaker from my S4+ with some insight from oweban.
While removing the speaker, I noticed a date 2020-5-28 printed on the PCB.
It would be nice if Vapcell added a switch to turn the speaker on/off.
gchart
gchart's picture
It would make a nice on/off slide switch
niajef
Last seen: 2 weeks 1 day ago
contactcr wrote:
I’m guessing this only applies to the “upgraded” model since no one mentioned this before now. Here’s slot 1-3 which never complete Cap Test and slot 4 still discharging. Shows 100% on first three slots but all are below 3V
and here’s a video of what happens. It “beeps” indicating it’s done then just counts up to 100% and stops:
does anybody know if vapcell updated the firmware version to fix this issue reported by contactcr? and also is there a way we can check firmware versions?
Garageboy
Last seen: 1 week 1 day ago
Also, if you had an older one, can you get the FW updated?
ChibiM
ChibiM's picture
Does anybody know if this will fit a Fenix ARB-L21-5000U with USB-C port without stressing anything?
the cell is about 77mm long
I know that HKJ measured 76.9mm, and I just want to hear from somebody with experience that this battery will fit normally without stressing, bending or anything.
richbuff
Last seen: 39 min 17 sec ago
 76.9 is charger length, according to Lygate information.
The cell is 76mm, according to Fenix website info. You should have almost one mm spare in the length department.
I was so happy that the Vapcell S4 Plus charger fits my 21700 protected, usb chargeable Imalent and Nitecore cells, that I bought four of them.
For me, its multiple flashlights per room, and multiple fully extra long 21700 chargers per room, too. But no S4 Plus chargers in the kitchen or bathroom, yet.
Rev 22:15
ChibiM
ChibiM's picture
lol.. not in the bathroom? That's the only place I need one Wink
I actually bought the UMS2 a while ago, which fits cells up to 80mm. But still thinking about this one...
Sirstinky
Last seen: 4 hours 23 min ago
It seems like Vapcell mostly fixed the issues with it. I’ll pick one up next month. This is about the best charger available now.
d_t_a
lol.. not in the bathroom? That’s the only place I need one Wink
I actually bought the UMS2 a while ago, which fits cells up to 80mm. But still thinking about this one…
80mm long? Does that mean it accepts long batteries like the 26800?
Fescron
Last seen: 3 hours 8 min ago
I would like to know this too Smile
Cochise334ever
Cochise334ever's picture
Last seen: 4 days 10 hours ago
gchart wrote:
I just tried 4× 26650 the other day and it was a no-go. I don’t have 4× 21700 to test with, nor am I near my S4+ ATM to try it.
I am guessing it will only be able to charge 2 × 26650? Is that correct?Would they be the outside bays only?
Not being able to charge 4 × 26650 is a disappointment .My Folomov A4 could but Two of them had Display failures after just 6 months.
To admit is to acknowledge.To Accept is to take action.
d_t_a
Vapcell S4 Plus can only fit 2× 26650s on the outer bays (bay 1 & bay 4).
Some chargers that can fit 4× 26650:
Liitokala Lii-600
SkyRC MC3000 (can fit 2× 32650 on the 2 outside bays)
Xtar VP4 Dragon (can fit 4× 32650 or 4x “D”-size batteries) = this is the widest 4-bay charger I’ve seen yet.
Cochise334ever
Liitokala Lii-600
In post # 45 Tatasol Confirms it can take 4 × 21700? Is this true? HKJ sent.me pictures disputing this.Maybe that was version 1?
I can deal without 4 × 26650.If it can not do 4 × 21700 this is a No go.
It is shame my version 2 of Folomov A4 had 2 failures due to Display completely malfunctioning.That version 2 could accommodate 4 × 26650 and 4 × 21700.
Again these questions are for Updated version 2.
Thanks
Cochise334ever
Liitokala Lii-600
Thanks.
I do not think there is a charger that exists can do the following: Especially be able to be purchased in USA.
Accomodate 4 × 26650 and 4 × 21700.
Must be able to do at Least 4 × 2Amp in each slot and preferably 2 × 3A in 1 and 4 slots.
Be able to see ALL info in 4 slots at once.
The only one I know is Folimov A4 and its version 2 has Too many issues primarily the Display Completely failing in Two.of them in less than 6 months.
I think the Mi boxer can do it but can not be bought in USA and is shipped from China by Amazon..no thanks.
EDIT- The SkyRc MC3000 may be able to do that. It’s way too expensive and I don’t need another analyzer. Not sure if you can read all four displays at once. Even so, I wouldn’t want it for $100. I want a simple charger like the Folomov A4…but it has to be relaible and not fail like 2 of the 4 I got.
Final conclusion..there is not one that will meet my requirements other than A4 which I will not get again because of issues already mentioned.
zoulas
zoulas's picture
Last seen: 4 hours 42 min ago
Mi boxer can do 4 × 26650. But I think they are out of business.
d_t_a
I forgot about the Miboxer C4-12 v2, which can also do 4× 26650 and 4x protected 21700, can charge 4× 3Amps.
They seem to still be in business..
To: Cochise334ever, the Vapcell S4 Plus can accommodate 4x protected 21700 at the same time.
Cochise334ever
Ok….Thanks.
Not sure why HKJ sent me 2 pics. One showing it can only hold 2 × 26650 and the other showing 2 × 18650 and 2 × 21700.Assuming it could not hold 4…because that was my question?
Only thing I can think of is that is version 1.
The dealer opens up in 20 minutes! Seems like I got my answers before they can tell me!
Thanks
Cochise334ever
Just got it.It can charge 3 × 26650 which is good enough.That is how many I charge after using my NI40..EACH cell lasts about 15 min.I bring a total of 3 including the one in the light.
I
Cochise334ever
The only negative I see so far is that stupid buzzer when the batteries are done. 100% and a battery icon when the grid is solid is enough for me. Especially in the summertime when I charge them while I’m sleeping. Or let’s say try to sleep. I am of millions of Americans who don’t sleep much 4 to 5 hours a night that’s it. I don’t need that stupid buzzer waking me up. I guess that means no charging overnight.
Now I am waiting for members to say..Do not charge unattended! I am attending in a state of meditation !
It charged my 3 X P42A to 4.19V…good enough.
contactcr
Buzzer is indeed annoying at night.
My only other gripe that was not listed in previous posts is that it wont revive an over discharged NiMH. I really like using this for AA Eneloops since it has the 1A charge rate and better termination than my Miboxer (for NiMH) which seems to stop early.
This charger has always had very high potential but seemingly everyone’s use finds a pretty big con with it despite the nice amount of overall features.
