Vapcell INR18650 3000mAh V2.0 (Purple) 2021
Official specifications:
Model: V2.0 INR18650 3000mah 20A
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2900mAh (0.2C discharge)
Nominal voltage: 3.60V
Max Continuous Discharge Current: 20A
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Weight: 48g
Internal resistance: 12mOhm
Standard Charge: 1500mA,CCCV 100mA cut-off
Quick Charge Current: 4000mA
A unprotected 3000mAh 18650 with fairly high current.
The two cells tracks nicely and capacity do not vary much with load.
Conclusion
This looks like a good battery that can deliver a lot of current and it has a low internal resistance.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
