Convoy 3x21A SFT-40 6500K first impressions, info, mods
45 posts / 0 new
thefreeman
thefreeman's picture
Last seen: 10 min 20 sec ago
No PWM indeed.
Edit :
Quote:
Dang, a little too late for me  – driver stripped
Ah yes somehow I missed the modding part in the second post, with the components removed we can clearly see it is indeed a linear driver.
Fedtro
Last seen: 5 hours 33 sec ago
Thank you Tom E for your very detailed and comprehensive review. After reading it I realized that 4x21A SFT40 is not able to overcome the 4X18A SBT90.2 so I really believe that I will not buy it instead I am waiting for news for a 3x21A SBT90.2 that I would buy with my eyes closed.
Fedtro
Sorry...4x18A!
Fedtro
Fedtro wrote:
Sorry...4x18A!
I swapped them 3x21A SFT40 and 4X18A SBT90.2, I was writing and thinking about more ...
Tom E
Tom E's picture
Last seen: 41 min 49 sec ago
I don't know if anyone did lumens/throw measurements on the 4X18A SBT90.2, but based on his listings the SBT90.2 is probably out throwing the 3X21A SFT-40 but can't say what the lumens are, but thinking they are roughly the same. His posted specs on lumens are not accurate but thinking the throw #'s are fairly accurate. This makes sense because it's easier to measure throw. He also doesn't state what the amps draw is of the SBT90.2, so can't compare that, but I suspect the SBT90.2 is drawing more amps.
The 3X21A triple reflector could have been designed better for throw by making the cups wider and having more overlap.
But certainly the beam's tint of the SBT90.2 is better.
Ohh -  tech reviews:
https://www.reddit.com/r/flashlight/comments/obhlqm/review_convoy_4x18a_only_50_notes_for_a_1122m/
https://www.reddit.com/r/flashlight/comments/o3si19/tactical_grizzlys_convoy_4x18a_sbt902_review_the/
4920 ANSI lumens mentioned, and throw measured at 367 kcd and 337 kcd.
ArtieT59
ArtieT59's picture
Last seen: 44 min 40 sec ago
damn.. this is kind of disheartening to hear, I was looking for every reason to buy the 3x21a sft40 over the 4x18a sbt90, but looks like I would go with the 4x18a. Of course, I need to figure out how to piggy back a driver like that. I think if i can figure most of it out, except what to take off the original driver (did you remove everything?)
also if you don't mind me asking, what driver did you use for the piggyback? Or what driver is a good candidate? (Fet w Anduril and flash pad)?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
Tom E
Tom E's picture
Yes - removed all parts from the stock driver. Driver I used was designed by a BLFer Quadrupel, uploaded to OSHPark, then I reflowed the parts. It's a FET+1, forget if 20 or 22 mm in diam. Actually it's the driver he designed for use in the Amutorch E3/E3S.
For driver, 20-22 mm is a good size. FET+1's are easy to work with. Flash pad for pogo pins don't work out well unless it's exposing the pins on the top (SMD) side. I was gonna use one but on the driver PCB, only the backside pogo pin holes were conductive, on the top side they were covered over.
ArtieT59
ArtieT59's picture
awesome, thanks for the info! I have something to consider now
Forsythe P. Jones
Last seen: 5 days 12 hours ago
Very nice modding job Tom. What cpu is on the board you used? Is it pulled from another light, or something you built? Do you know what the old cpu was? It looks in your pic like they sanded off the markings!
I wonder if you’ve tried TK’s very latest ramp code, from just yesterday or so. See the current thread about it: https://budgetlightforum.com/node/78686
It is incredibly clever from my perspective.
Tom E
Tom E's picture
The MCU is a ATtiny85. The driver I used is something BLFer Quadrupel designed for the Amutorch ES3, but I think I uploaded the design files to OSHPark and bought them off of there. I reflowed the board, adding the components. It was just a driver I had laying around, but any 20 - 22 mm or so e-switch driver could be used.
TK's latest ramp tweaks I think only apply to particular designs that have issues at low output levels. The driver I used is what we call a "FET+1", meaning it uses a 7135 (0.35 amps) regulator/limiter, and then a FET for high amps. The 7135 "raptor claw" version does really well at low amps so doesn't need those tweaks. The problem with FET+1 drivers is you always get PWM flicker, though we use a high frequency, about 16 khz, and using the FET and 7135 using PWM's to control output is not power efficient or have the ability to maintain a constant level of power as the battery drains. Buck, boost, buck/boost, or CC linear regulated drivers are considered a better more efficient design. Of course they can be more costly, more complicated circuit designs, more complicated to program, require more space because of a higher chip count, and are usually max amp limited compared to FET+1's.
AlexGT
AlexGT's picture
Last seen: 54 min 41 sec ago
Hi Tom, I like your mod, I don’t know why Simon doesn’t use Anduril in his designs, Anduril is such a perfect User Interface IMHO
Anyway, I am thinking of maybe using an Astrolux EC03 Driver, to have USB-C charging dock and also the Anduril UI.
Do you think the EC03 driver can fit piggyback on the 3×21A board like you did and be able to position it in such a way to still have USB-C charging?
Thanks!
AlexGT
Tom E
Tom E's picture
This is the EC03 driver:
I don't know how you can physically get the USB-C connector in the place of the host cutout - maybe flip it over but not sure there's clearance for that. Unless some how you can add a few jumpers to the 3x21A board's USB connector. Re-using the 3x21A connector might be the best option, but dunno how, and how easy/hard that would be.
For me that would be crazy fine cut/jumper modding, but things like that have been done.
JaredM
JaredM's picture
Last seen: 42 min 2 sec ago
I’m wondering about using one or two of these in parallel for mods like this, space dependent. They are single sided. Using stock connector and jumping wires to the charging boards. Limited to 1A each, but better than nothing and having a useless port.
Tom E
Tom E's picture
Interesting, maybe possible. I think there's not much vertical spare space. Built in charging is great for an EDC, like the SP31 Pro that can run Anduril (and 2) though.
