Couple of really old school 1XAA lights got some love this weekend.
First off the Balder BD1p got a shinny new 219b sw-45k, little less output but ohhh that tint. I is running a 3x7135 ak-47 driver and works fine with a 14500 and 1xAA. I am not sure how it works at that low voltage, but the CPU is booted and modes work. I really would like to find the extension tube for this little guy.
Then a Deerelight EDC C2H got a pretty nice 219b sw-40 on a noctigon to correct the headspace that was off a tiny bit and required a solder wire shim to always make contact, now she is really reliable.
I also got in the Convoy T2, second version with the LH351D at 4000k. Along with it was a stash of it’s drivers I ordered. I think one of the drivers may end up in the Balder soon. One of the others will end up in a lego 1xAA/14500 P60 dropin or in my Javelin.
Looks awesome. What are your thoughts on the S16 as a host compared to the M21B? I’m thinking S16 will be my next Convoy purchase, but as I’m not in the modding phase of this hobby yet I’d need to go stock. I did confirm with Simon they are not the same size reflector.
S16 is more compact and feels more refined. M21B is little rough. I have M21B also and I was surprised how much this host feels better in your hand. It also looks better in my opinion.
M21B has a slighty bigger reflector. At least its outer dimensions are bigger, and it is available in orange peel. This could also be a nice light with XHP50.2 with a 5A driver. Then you don’t need to modify the reflector. It would have more throw and at least 3000 lumens.
I was handling my fwaa the other day and i thought “Gee it really is a light weight isn’t it” So i added some extra useless weight to it so it won’t get blown away in the wind.
EDIT: the missus reckons it’ll look better if I de-anodize the body
This an OLD mod. DRY 3xXml. I used a metal checkering file on the body (which could use a little finishing/polishing) and relieved the tailcap for easier access.
Time to upgrade. LED suggestions? I want ~5000k. I’m not up on what would be best, XPL or SST-40? Maybe efficiency would be better than raw output for this host.
Also, the battery carrier is too short for many 18650s. At one point I bought a bunch of small brass spacers that could go in between the rods and plates, but apparently I didn’t do it and they’re long gone. Anyone have a suggestion for making it a couple mm longer?
They are brass, and not sure they are the right size, right #'s, but cheap enough. I bought them more for making battery pads or using in wood or plastic for battery fillers, etc. Forgot who posted here, might be a little eralier in this thread or the Amazon deals thread.
I’ve been reading through a few pages of this thread and seen so much talk of MEK. Man, I hated that solvent. I used to work at a Lufthansa MRO as a structural technician (the sheetmetal guys or riveters as some called us). MEK was AMAZING at removing paint and ACT, as well as softening up uncured 2 part polysulfide sealant to remove the excess mess you made when installing fasteners such as hi-loks or rivets. We used that sealant on friggin’ everything to seal stuff from the elements as well as to keep repairs such as doublers airtight. Also used for corrosion prevention, of course. Anyway, the point is, MEK is a NASTY solvent. I remember I’d double and sometimes triple up on gloves when using the solvent, and even then when I took them off, I could smell it on my skin, so MEK can make its way through nitrile gloves and many other gloves, and also pretty quickly eat them up in the process. The smell is also very strong and you needed the VERY fine cartridges for your facemasks if you wanted it to actually filter out the smell. Just by smelling it, you can tell that that substance is the kind that can cause permanent damage in your brain and CNS. Some people handled that stuff inside the cabin with nothing on, and sometimes with just a paper mask on. We’d get it in 5 gal jugs and go through tons of it pretty regularly. I’d recommend to anyone in here handling that stuff to do it in a WELL ventilated area and use adequate PPE. This is not IPA we’re talking about. It IS exremely strong and effective though, I’ve read several posts in this forum where users fully de-dome emitters just by letting it soak in MEK and then just blowing out the emitter when removed from the solution. Where do you guys even get this stuff? They don’t sell it in any hardware store here, except as a component in a mix of compounds such as paint removers and lacquer thinners. Certainly not the 100% pure MEK I got at the material store counter at the MRO. That’s the only part I miss about working in aviation, having access to so many amazing chemicals, materials and tools all day. Plus the massive discount on FedEx and and air-travel lol.
You can get 100% mek at hardware stores, even Lowes, etc. Not to be confused with mek peroxide.
Very nasty.
To me, xylene might be worse. Got that on my hands once and my entire arms started to tingle like they were asleep, but painfully, and I nearly passed out.
Jeez, that sounds horrible. We don’t have any Lowes here in Puerto Rico, or Harbor Freight. I really wish we did. You guys get so many affordable tools, power generators, etc. That Predator 9500 inverter generator that replaces the Honda model (it’s like a Honda EU7000iS but even more powerful, even if it’s not as quiet) is 2 grand at harbor freight. That same unit is being sold here for 4-5 grand.
