Simon, if possible I’d like to request you to make a special run of 2-26800 tubes for your L series. Maybe a sample run? I now you’ve stated that you’ll be making extensions, however a few may prefer solid one piece tubes. Part of the Convoy success is you make a very solid product.
I would have to agree with others… an S21 with this LED would be awesome… Besides… who runs on turbo?
Simon
Are you planning on a GT-FC40 version of the 4x18A?
I would love to upgrade mine, but unfortunately the XHP70.2 is 6V instead of the 12V the GT FC40 LED needs.
When a 12V driver is available, please let us know.
I agree, an S21 with the gt fc40 would be awesome. Those wanting prolonged use with fewer heat concerns could easily use one of the mode groups with a 50% max mode.
I have build one with Tamagotchi driver. Amazing high cri pop can!
The only thing i need is 25mm MCPCB for FC40 :)
Tamagotchi driver? Do you have more info?
26800 extension tube will be available in one week
ok ,i will produce suitable driver
Thank you!
If you don’t feed it when it demands, it dies?
Yokiamy:Tamagotchi driver? Do you have more info?
That made me grin
I have striped 4x18 driver and used it to piggyback this one.
30mm 12V/5A
From OFF:
1Click – ON
2C – turbo on/off
3C – strobe. hold to change strobes.
4C – soft lock on/off.
5C – soft lock with beacon. 4C off.
HOLD – moonlight.
Click + hold – battery check 1-5
6C - enable or disable a backlight button.
2C + hold – beacon on/off
From ON:
1C – off.
2C – turbo on/off.
hold – 4 modes loop.
Click + hold – reverse to low mode.
I have striped 4x18 driver and used it to piggyback this one.30mm 12V/5A
From OFF:
1Click – ON
2C – turbo on/off
HOLD – moonlight.
From ON:
1C – off.
2C – turbo on/off.
Interesting, did you loose the USB charging function?
Yes. But i never use it anyway…
Simon does is possible ask at GT FC40 manufacture to produce Leds such as 5050,3535 and smaller size
from 2000k to 4500k CCT range. CRI >90, R9 >80 with tint below BBL?
They would be nice for next variable temperature light
yes, it has .
but it’s 12V LED, it needs special driver .I have to prepare customized drivers for them, which will increase costs.
i will get 219B R9080 in one week sw30,sw35 sw45,how about this
You are full of surprises!
Does Convoy have a U.S. store or vender?
Sari33:Simon does is possible ask at GT FC40 manufacture to produce Leds such as 5050,3535 and smaller size
They would be nice for next variable temperature lightyes, it has .
Wished these Leds <2500k on 5050 sizes and less at 3V
There is anything like that
Thanks anyway
Quad e21a or e17a in 2000K are the best option currently
