Lightbringer, blood sucking insects look for places where blood vessels are close to the surface and the skin is thinner.
Try using repellent that has Icaridina or Icaridin, here in Brazil we deal with mosquitoes every day, and it’s not just itchy the bite can give you Dengue, Zika, chikungunya, malaria.
It’s not as bad as you think CRC, I know you’re kidding, I personally never caught any of those virus, neither did my family, I love my country
Here’s a link to Google images (I’d like you to know the place I live, just a short ride from home I have waterfalls and hills that are breathtaking.
Those are amazing photos. We had an exchange student from São Paulo with us for a school year about 20 some years ago. We are still in touch and he sends pictures of his travels. There are many places I would like to see but have never made it there.
That is the most miserable isn't it. Can't pee or eat in peace and twenty get into the tent with you every time you unzip. lol. Have you ever tried picaridin? It's excellent. Sawyer seems to be the best brand still, 20% and it's actually truly odor free, no oily residue (and safe for plastics...watches, sunglasses, gear). I don't think it lasts quite as long as deet but I can usually get half a day or more before needing to reapply. The Sawyer is kind of pricey but it's worth it. Natrapel sells it a little cheaper but it has a pretty strong floral/powdery fragrance that drives me nuts and it lasts a long time on gear (maybe not so great for bear country). There are some backyard formulations like 10% and such but you don't want those for real outdoor time. Does ok with flies but I think deet is better there, but of course flies will ignore deet a lot of times anyway....and about the same with ticks. I probably won't use deet again but I still have a couple little bottles and a can of it (bottles I have are the old 100% and 85%...truly does last forever....). Headnets are lifesavers, too, if they don't make you dizzy or feel claustrophobic. Treated clothing helps a little but not when they're super thick like that.
MtnDon just let COVID-19 give us a break, you’d love it here, it’s about 2 and a half hours drive from Sao Paulo, I’ll go camping this weekend and send some pictures for you
i’m glad you mentioned that—reminded me to go check the AA alkaleaks in my Racket Zapper, which has 3 grid screens, and an Elucto racket which has only a single plane of grid wires across the head spaced about 4-5mm. Only ever used them indoors for big houseflys, but think i’ll go do a mahsqwito test outdoors to see how they do.
i just use a cheap little 20” square box fan and set it up close to where i will be sitting or working outside. i like his big fan and use one to ventilate my attic, my bug problem is not as bad as his.
Haven’t used that stuff before that I can remember. However some Coleman non Deet spray had that in it I think and it didn’t work either. This was the worst I’ve seen and no campfire because it was so hot out for the smoke. Kind of a bummer to drive almost 4 hours only to leave the next day. Next time we will go later in the summer when they’re died down and avoid that particular campground since it’s well-known for the mosquitos.
Didn’t kill any mosquitoes; their body weight is so low and size such that they just don’t get past the outer grid to touch the middle one, and the other one just never fired a spark or caught a bug. i used fresh AA cells and i was able to test them to cause zapping. So these were worthless for me, ymmv.
None needed, but he does show using a bottle of selzter water in one video to emit CO2.
My little box fan catches about 50 in an hour. i have noticed that those big stripe-leg variety are strong enough to sometimes escape, but most can’t fly off the screen once caught. The rubbing alcohol spray kills them so they can’t leave when you turn off the fan.
thanks, i almost ordered one. works on regular flies though, right? lots of farms around here…somehow, a couple a day get in my house, i think through AC units, or letting dogs in and out.
I’ve been using the electric USB chargeable Thermacell Radius and it actually works pretty well if there’s no wind.
The internal battery should last about 6 hours, and it uses liquid cartridges that lasts 40 hours, but it comes with a 12h one in the box.
With an added power bank it could last all evening + night.
The only downsides with this electric one is that the button easily turns on in your backpack, so I’ve taped a stiff cardboard over the button, and the cartrdige tends to leak if placed on its side for longer periods. So I’ve put my cartridge in a small zip-lock bag with a paper towel around it and make sure to keep my backpack upright when I can.
Yeah, they came up with that stoopit design to keep people from electromocuting themselves by grabbing both sides of the racquet. So it’s like 3 layers of chicken-wire (–/+/–) that the beastie has to short out to get zapped.
My old one (fiik where it went) was just 2 layers of hardware-cloth, offset to each other. Anything from a big fat horsefly to little gnats could get trapped and zapped.
Think one of the cats stepped on the one I have now, or something fell on it, because all 3 layers of chicken-wire are smooshed together and bowed out on one side, so I gotta try prying ’em away from each other without making the distance too far.
Lightbringer, you’ve got me thinking about making a dangerous one.
Nismo, sounds like the radius is electric OR butane? Haven’t seen that one, I’ll definitely check it out. With no wind, the thermacell effect is impressive, you can see the mosquitoes staying away from you. It paralyzes them if they get too much. I guess they sense it because I’ve not seen one drop…
