New Products: TrustFire T21R Tactical Flashlight
Trustfire T21R is a rechargeable tactical flashlight with high performance.
T21R has extremely high reliability and operability, up to 2600 lumens, with intelligent temperature control and low voltage warning, powered by a (2170zero) rechargeable lithium ion battery; adopting USB Type-C charging technology, IP68 level dust-proof and waterproof, can be used in complex and changeable outdoor environments; tactical switch on the tail cap,change modes switch on the neck, and anti-drop height up to 1 meter, let you use it in outdoor and work environment with confidence.
T21R flashlight : https://www.ebay.com/itm/194258511729
EXTRA 5% OFF WITH CODE :TFEBAY50
eBay TrustFire US store: | eBay
eBay TrustFire DE store: | eBay
eBay TrustFire UK store: | eBay
Amazon Manchest US store: https://amzn.to/3kNiAfX
what is LED? what are modes? would be cool to give more info, please
I see you have it mounted on a rifle / long gun, are you going to include / offer a pressure switch pad to replace the tailcap for “Tacticool” situations?
228 meters is not long range in pretty much anyone’s book. Would like to know the emitter.
Could be sst70 or xhp50.2. Fenix is exclusively using the sst70 in their newest high end tac lights. It’s an amazing emitter, but CW only.
https://www.aliexpress.com/item/1005003038398634.html
Sst40 can’t do 2600 lumems in that host. No way. From the picture, looks like xhp50.2 maybe.
Yup, it seems more an XHP50.2 and not Luminus!
Seems a nice light, good for people liking the Nitefox UT20, but with more power on this TF T21R :+1:
I th8nk an sst70 would be better. Throws farther, nicer beam. I hope to see it in more lights.
I have no knowledge about that led, but it seems to be used by some brands (Klarus, Jetbeam, EagTac, Pioneman, …) found in AliExpress.
I wish those have different tints, though! CW only is a “poor option” :zipper_mouth_face:
In the description “Using the international patent latest generation of LUMINUS SST-40 LED, life of 50000 hours”. I like little lights 228 meters, 2600 lumens. Perfect for little throw, lots of spill. The biggest problem here is it only has a 24.6mm body for a 21+mm battery. This helps bring the weight down to 71.8 Grams giving turbo run of just seconds. This is more a 18650 light since 21700 capacity is not going to get used here.
Hello,
the LED is CREE,and it has five modes,moonlight,Middle mode,High mode,Extreme high mode,strobe mode.
it’s use 21700 battery,ip68 level of protection,Type-c charging.
please visit our product:
Hello, yes,you are right, we will include a pressure switch pad .
It’s use Cree XHP50
yes,you are right,the LED is Cree XHP50.You’re very professional
Yes,the T21R has 2600Lumen,and use 21700 battery.
Thanks for your advice.
hello,
the T21R flashlight use 21700 battery.
It’s the bigger brother of the T11R. I like it :+1: .
Yes,Right, you can visit our link:https://www.ebay.com/itm/194258511729
