If a lithium ion battery exploded in a flashlight would it blow the light apart?
84 posts / 0 new
arow55
Last seen: 2 hours 56 min ago
Funtastic wrote:
It’s extremely unlikely IF
- You care for your batteries and know all the safety precautions
- Don’t use budget, cheap, old batteries
- Don’t be an idiot
That last requirement is why I stick to eneloop.
raccoon city
raccoon city's picture
Last seen: 3 min 33 sec ago
Bort wrote:
and get some 21700s as well i plan to go with name brand again.
I did research on 21700s, and I like these the most:
https://liionwholesale.com/collections/batteries/products/molicel-npe-inr-21700-p42a-45a-4200mah-flat-top-21700-battery-authorized-distributor
They're very nice, and fairly cheap, but the wrappers on the cells break easily so you have to be careful not to damage the wrappers.
Bort
Bort's picture
Last seen: 29 min 19 sec ago
Funtastic wrote:
The brands I sell that have CE, ROHS certs are (I don’t sell anything else yet)
Sofirn
Not the D25S, D25L, S11C since they aren’t made by Sofirn
Wurkkos (Sofirn build them)
Convoy
Guess what, I just found out Astrolux/Mateminco refuse to carry out any testing anymore. I’m ditching the brand. They print CE, ROHS on the flashlights, but have no such testing done at all. I would strongly suggest not buying them IF your country requires these certs for your insurance.
Good to know
How can you tell if a flashlight is tested and they are not just claiming its certified?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Bort
Bort's picture
They’re very nice, and fairly cheap, but the wrappers on the cells break easily so you have to be careful not to damage the wrappers.
I’m all about capacity so i would want some 5000mAh cells.
Funtastic
Funtastic's picture
Last seen: 4 hours 59 min ago
You have to ask them for the CE certs or whatever it is you need.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Bort
Bort's picture
I’ve never seen a certification document for a flashlight. I sold some 8 year old Convoys, i wonder if they had been tested/certified.
How did you figure out that Astrolux/Mateminco refuse to test?
Funtastic
Funtastic's picture
I was a dealer for them and asked for the certs of their new models. Ben, who handles all customer service, said they no longer carry out any testing.
This is slightly concerning that they simply don’t care anymore to make sure their products are safe. Banggood is really their only buyer for the Astrolux brand, so there’s no need in their eyes. If they had a large number of dealers worldwide it would be different.
Funtastic
Funtastic's picture
Every single Convoy model has the CE testing done. They do things properly Smile
raccoon city
Bort wrote:
I'm all about capacity so i would want some 5000mAh cells.
Make sure your light doesn't require high drain cells then.  :-)
Bort
Bort's picture
Impressive honesty Big Smile
Ridiculous business decision Facepalm
Nice! I am curious what is tested, are there any publicly available certificates?
raccoon city wrote:
Make sure your light doesn’t require high drain cells then.  alt=)" />
This cell puts out 9.8A.
https://liionwholesale.com/collections/batteries/products/samsung-50e-21...
So 3.6V x 9.8A means 35W. This is good enough for the lights that i’m looking at. As the Convoy M21B i am looking at puts put 1500 lumen i don’t expect any problems. If it takes over 35W to do that then there is a bigger problem at hand.
That said you have inspired me to look up its wattage vs output graph Smile
Funtastic
Funtastic's picture
That’s not how you choose a battery though. You need to understand that most drivers rely on a battery’s voltage for outputting the highest possible lumens. When you apply 9.8A on the Samsung 50E the voltage will sag on load thus reducing the lumens.
In my opinion, if a torch requires up to 10A I’ll recommend a 15A+ battery. For my Osram 5A builds I’ll bundle a 10A battery, for 10A I’ll bundle a 20A etc. You’ll get longer runtime off a battery if it’s not pushed to its max rating
Bort
Bort's picture
It seems its run at 6A and is likely a linear driver as its likely a 3V chip
So no problems Smile
https://www.mouser.ca/new/luminus-devices/luminus-sst-40-w-white-leds/
Since i don’t know much about Luminous LED chips and didn’t think look at the one i was considering i appreciate the unintentional nudge Smile
Funtastic
Funtastic's picture
A battery’s capacity rating is measured at 0.2C (0.2 X capacity) discharge current. You’ll get less capacity the higher amp load you run the battery at
A Molicel P42A and Samsung 40T may achieve longer runtime than a 50E
Bort
Bort's picture
Fair enough, i just replied to RC that it needs 6A out so 9.8A should be reasonable.
Funtastic
Funtastic's picture
Nevermind, I missed that it’s only for the Convoy M21B
Bort
Bort's picture
Interesting.
I hope you don’t mind if i ask you about that in the future if i do end up buying that light.
Bort
Bort's picture
Which lights do you recommend those cells for?
Funtastic
Funtastic's picture
Interesting.
I meant if the 50E is driven hard, but that doesn’t really happen in a flashlight I think, it only delivers what it’s capable of. Someone else might know a bit more about that.
Looks like the 50E would still provide higher capacity anyway, so the above does apply in this case.
At 10A the 50E still gets 4,750mAh and the Molicel 3,900mAh ish. At 20A+ is where you’d see the Molicel shine.
Best place to compare models cells is here
Bort
Bort's picture
Funtastic wrote:
Interesting.
Which Chinese battery brands do you consider high quality?
Oli
Last seen: 2 days 16 hours ago
A pressure buildup inside of a flashlight is entirely different than a battery explosion. Unless I’m missing something I don’t think we have evidence of batteries exploding in flashlights. Yes there is evidence of flashlights “exploding” from internal pressure. Mostly out of the ends not the barrel itself. Always point your flashlight down range. Just say no to 123s.
ShyOne
ShyOne's picture
Last seen: 3 days 18 hours ago
Bort… try these Tesla 21700’s from Tech-Direct
chops728 posted about these a while back. I got several & they are great cells.
$11.99 for 3 of them.
No tax & FREE shipping.
You will not be sorry. ✅
You are in the USA aren’t you??
Bort
Bort's picture
ShyOne
ShyOne's picture
Canada… that “might” sink the deal Bort. Sad
