interested in ft03 sft 40 thanks freeme
Interested FT03 SFT40
@Everydaysurvivalgear - Nice review !
I think your review is worthy of having it's own thread....having it in here might be lost to heaps of others who might be interested in this light.
Interested in SFT40 version of the FT03.
Thanks FREEME
Very interested in a new Astrolux FT03 with SFT40, especially if it also comes in Blue.
I already have one Green and one Black FT03. I want another FT03 in Blue.
Do you have the kcd #'s of before the mod and what LED?
The SFT-40 is a beast, yes, it's binned the same, I believe, as the SST-40 even though there's no dome (usually you drop 10-15% or so), and it can take more amps, so you get higher #'s with an unregulated driver.
Actually it's a re-designed LED from the SST-40. Wondering if they will come out with a domed version to replace/upgrade the SST-40.
I got the same numbers from my original FT03 as you, around 230kcd and like 2300 lumens. The light i modded a bought a few months back i still have another FT03 with a sliced XHP50.2 in it. I did have a CSLPM1.TG in there but i could not get it focused on the 20mm MCPCB.
Wait and see if Cree release a 3v XHP50.3 HI.
interested.
Maybe it is a good time to update the host too.
I just upgraded an already modded "vintage" FandyFire/Solarstorm SP03. It's a triple SMO reflector, 85 mm head diam sitting on a quad battery tube, like an SRK's battery tube. It's running a BLF Q8 style driver (FET+1).
Upgraded it to triple SFT-40's - it had 6500K SST-40's, back when the 5000K's weren't available yet. The lumens stayed about the same, but the throw little more than doubled, once I got the LED's properly centered. With just one of the 3 LED's off center, after aligning it better the throw jumped by 13%. These SFT-40's seem very sensitive to centering - something to keep in mind if you don't think your FT03 SFT-40 is throwing as good as it should.
The #'s on triple SFT-40's:
- lumens: 7730 at start, 6180 at 30s (maukka calibrated)
- throw: 540 kcd, 1470 meters (it was 264 kcd w/SST-40's)
Stock, this light was 75 kcd, about 2200 lumens, back in the day, 8 years ago...
Interested.
Interested
Interested. Thanks freeme
Interested in FT03 with SFT40
Interested. Will this come with Narsil or will it be Anduril? Green and blue, or just black? Stainless ring?
Also… if you have a current coupon on the SBT90.2 version of the FT03, I may get another (mine walked away with a friend).
Yes, please include the Blue colour with a stainless steel bezel. The regular Blue FT03 with SS bezel is difficult to find on Banggood now. Maybe I have to look for it elsewhere.
Buying a SS bezel separately costs about US$10, which is expensive!
Thank you!
Interested in FT03 SFT40 version.
