Maybe it is a good time to update the host too.
I just upgraded an already modded "vintage" FandyFire/Solarstorm SP03. It's a triple SMO reflector, 85 mm head diam sitting on a quad battery tube, like an SRK's battery tube. It's running a BLF Q8 style driver (FET+1).
Upgraded it to triple SFT-40's - it had 6500K SST-40's, back when the 5000K's weren't available yet. The lumens stayed about the same, but the throw little more than doubled, once I got the LED's properly centered. With just one of the 3 LED's off center, after aligning it better the throw jumped by 13%. These SFT-40's seem very sensitive to centering - something to keep in mind if you don't think your FT03 SFT-40 is throwing as good as it should.
The #'s on triple SFT-40's:
- lumens: 7730 at start, 6180 at 30s (maukka calibrated)
- throw: 540 kcd, 1470 meters (it was 264 kcd w/SST-40's)
Stock, this light was 75 kcd, about 2200 lumens, back in the day, 8 years ago...
Interested FT03 SFT40
Interested.
Interested
Interested. Thanks freeme
Interested in FT03 with SFT40
Interested. Will this come with Narsil or will it be Anduril? Green and blue, or just black? Stainless ring?
Also… if you have a current coupon on the SBT90.2 version of the FT03, I may get another (mine walked away with a friend).
Yes, please include the Blue colour with a stainless steel bezel. The regular Blue FT03 with SS bezel is difficult to find on Banggood now. Maybe I have to look for it elsewhere.
Buying a SS bezel separately costs about US$10, which is expensive!
Interested in SFT40 version of the FT03
Thank you!
Interested in FT03 SFT40 version.
Interested if firmware is Anduril 2!
As far as I know, the FT03 can be run with Anduril or A2, but not sure if there's anyone that can get the Anduril 2 build for the FT03 to Mateminco.
I could build and test it with the latest, but I have no method of contacting Mateminco, the manufacturer of the FT03 for BG/Astrolux.
Then of course there's the manual, UI chart, etc., but L-P probably has it it all, or minor edits for name changes, etc.
Waiting for codes!
Thank you!
Will this be available with the 26800 tube?
It was actually this light which Mateminco sell with an SFN55.2, not the FT03 mini as I previously had thought. Do you know if Astrolux also plan on having this emitter option in the future?
Interested
