So… no Killer Boaz?
What a letdown…
So… no Killer Boaz?
What a letdown…
that's a very nice comment ...
Sent you a PM ... maybe my pm works :)
Just found my DC-fix from my last order. Cut out a piece for my H32w.
Did the trick, like I new it would.
Now the H32w is very comparable to the Manker E03II TIR (without difuser).
Has anyone figure out an easy way to cut a doughnut ? And just cover about a 1/4 inch of the outer ring?
Results?
I might see about some sockets, I have various sizes.
Got some DC fix and 1/8 minus green, thanks.
Sent pm, need few filter.
Need a little help please
I’m wanting to make a removable filter cap to give the Osram CSLNM1 Red a bit more flood for closer range, what d-c-fix type would work? The Convoy L21B has a very tight beam, so it would be great if I could spread it out for use at 80 - 200m. This L21B achieves a range of 850m ANSI and it’s fairly tight for anything under 300m.
Still need that hotspot with just a bit more spread to it, if possible.
Thinking of getting a red filter and remove the red lens and replace it with a spare L21B lens with the d-c-fix.
Thanks
Try some dc fix but cut it smaller than the full diameter. Leaving 1/8” or so around the circumference uncovered will give you more flood but still keep your throw. I used the original dc fix.
Order incoming! Glad to be able to still get these!
yeah that's kind of a nifty trick to diffuse the spill but not the hot spot .
the #3 is becoming one of the better sellers these days because it has about half of the overall diffusion of the original #1 Dc-Fix
Boaz, is it possible to get 1 sheet that is 12” in length instead of two that are 6”? I’m looking at applying this for an LED desk lamp. Thanks!
Sure .. But I don't subscribe to my own thread so the best way to get a hold of me is to PM me .
I sell 15 different diffuser materials at this point and about 10 different filters. I'll send you my famous cut copy and paste reply to requests .
I just received mine today. This is incredible and it gives new life to all lights.
I managed to convert my rarely used FW3A 6500k to 4500k with a layer of F4 and 2 layer of minusgreen Z3. It’s comparable to my D4V2 SW4500.
The #2 diffuser has a very slight warm tint compare to the MacBook diffuser film I’ve been using. I have a D40A with 50.2 and it sucks. The beam, hotspot, tint and I managed to make it smooth and rosy with layer of #2 and 2 layers of minusgreen 1/4.
I lose lumens but I have a “new” lights
The F4 is not heat resistant and it will melt.
Just received my dc-fix from Boaz! Great service and quick shipping to me.
Nice first post :)
Thanks Again Frank
sent one sheet of each:
#3, #7, #10, #F2 and #F4
Hi Boaz, I want to buy some dc-fix and zircon filters, already sent you a PM yesterday. Thanks.
