Tom_E
(Tom E)
July 31, 2021, 9:45pm
5377
AlexGT:
Ok, I was able to use the 3X21A SFT40 last night… The light throws! The led tint is not bad as some of the pictures might make you believe, my MAJOR complaint is that if you long press the button and go to “moonlight” it cannot ramp up from there you can click and hold and nothing happens, your only options are to double click and go to turbo then ramp down from there, or turn the light off and do a click to go to saved last brightness level and ramp from there. WHY??? or better yet, WHY DID YOU NOT USE ANDURIL??? Astrolux uses it in their USB C rechargeable drivers, it can be done! I like the light design, really do! But the UI could have been perfect if you had used Anduril!
Wait! Mine ramps up from moon fine.
Oops, might be because of this minor Anduril 2 mod:
Wish I could have saved the charging but there were like 3 I/O pins interconnected between the main driver MCU and the charging circuitry , probably partially or fully because of controlling the LED's.
dthrckt
(dthrckt)
August 1, 2021, 1:08am
5378
Link in OP for gt-fc40 doesn’t work (but easy enough to search led name).
I think an S12 with 219b would work very well. With the 6A driver that’d be 2A per emitter. The 219b is great for triples. I built an S2+ triple with the 5A driver and 3 SW45k emitters.
Techno
(Techno)
August 2, 2021, 1:15pm
5380
For the S2+, is it possible to just purchase the tail end of a host?
I’ve dropped and banged my S2+ so many times on its tail end that the magnet no longer fits
Simon_Mao
(Simon Mao)
August 2, 2021, 3:23pm
5381
Suitable copper MCPCB in production
Simon_Mao
(Simon Mao)
August 2, 2021, 3:24pm
5382
available now ,i got them today ,i will add links in two days
Simon_Mao
(Simon Mao)
August 2, 2021, 3:26pm
5383
Techno:
no seperate tail , maybe you have to buy a host
Any news about a link to order S16 with SFT40 and 8A CC driver yet? I would also love to see FC40 3000K in the S16 or M21B. :LOVE:
Any news on 26800 tube l7?
Tater_Tot
(Tater Tot)
August 2, 2021, 4:22pm
5386
Great news, thank you :+1:
Great thank you. Are the new 3X21A flat top adapters (molding not CNC-made) ready for shipping yet? I would like to order two more flat top adapters each for 4X18A and 3X21A along with my next order (S16 with SFT40).
How do you think about FC40 in S16? If it works in S11 I feel confident it would work very nicely in S16, too. :)
Thanks Simon they look great
Simon_Mao
(Simon Mao)
August 3, 2021, 4:50am
5391
Lux-Perpetua:
yes ,new adapter now ,
i dont have reflector for S16 FC40 ,
M21B FC40 will available in two days
Great. I will wait for M21B FC40 to become available and then get back to you via PM.
You got me, I just ordered 5 of them 26800 extensions. Those 26mm PCB board for series connection, please consider 21mm and 18mm sizes.
Di_Joker
(Di_Joker)
August 3, 2021, 6:55am
5395
when to expect 26800 extensions for S11?
id30209
(id30209)
August 3, 2021, 9:59am
5396
So i’ve got Nichia B35AM 5000K R9080 and installed iz in S21B.
AMAZING BEAM!
But it get’s realy hot on 100% so i’ll go with 3A driver instead of 4A (22mm single cell boost)
