most bike lights have about a 25 degree light angle at best
the trouble with flood is 2 things:
- it is hard to get a wide area to be very bright
- it may blind cars
head mounted light is great
most bike lights ( at least the $30 cheap ones that also have 4 x 18650 battery pack and charger ) come with free head mount
if you have head mount you do not need wide angle of lighting
you can just turn your head to see things off center
Consider one of these:
Lights that are dedicated for bicycle use are designed for this, with certain beam patterns. A regular hand-held light mounted onto a bike will cause undo glare. I’m considering the Lumintop B01, as I like the fact that by design it seeks to prevent glare for oncoming traffic.
Lastly, you can always augment with a headlamp. I would not use a headlamp alone, as that can confuse oncoming traffic—a steady bike mounted light makes it clear what you’re looking at, a small vehicle, likely a bicycle.
Did anyone not catch the word “Onewheel” in the OP?
yeah
it is not a bike
has no handlebars
so would be good candidate for head mounted light or helmet mounted
wle
I’ve never ridden a onewheel. I used to ride a unicycle but not at night. And not too much off-road. With these onewheels your head and hands are doing a lot of moving around. And your head is not really fully pointed straight. Having said that I do think that a headlamp and a handheld light used in combination is probably the way to go. You going to want both of them to have a wide beam pattern without a distinct hotspot so that all of the movement is not disconcerting. The new Armytek wizard C2 MAX in warm would seem ideally suited mounted on the head even if you’ve got to mount it slightly crooked. The handheld part I’m not sure. But again something without a hotspot that still has some reach.
A right angle light like most headlamps might actually be more comfortable to hold in the hand out in front of you than a regular flashlight. Unlike walking where your hand is kind of down by your side I assume on a one wheel you’re keeping your hand and arm somewhat out in front of you.
I think a Zebralight H600w MkIV would be a good choice. Handheld or even mounted on your helmet (if you choose to wear one, no judgement implied). The 875 lumen level is temp controlled but I’ve generally found the airflow of moving at 10-12 MPH is enough to keep it from stepping down. Has a reasonable combo of flood/throw and good runtime.
Wow, lots of activity on this thread since this morning. I’m sorry I got tied up on phone calls and couldn’t respond as quickly as I’d like, even though I’m seeing the posts.
As Oli mentioned, with a Onewheel, you are moving your body around to turn and even just to balance or ‘carve’ as you go down the road / trail. Also as Oli said, your body is somewhat sideways and therefore not pointed perfectly forward. Additionally, your head is higher up than it might be on a bike, and the higher the light is, the less it is able to identify undulations in the terrain. I do wear a helmet by the way, no judgement taken, but this also has an implication on the feasibility of a head mounted light. All of this is to say that despite the initial obviousness of a head mounted solution, the freedom of movement that you have with your arms, actually makes holding a traditional non-right angle flashlight pretty much ideal.
One light that might be appropriate, is the Sofirn IF25A @ 4000K. This is a quad SST20 TIR optics traditional flashlight with a 21700 cell that also happens to have internal charging (a nice to have feature, but not essential). The 4,000K emitters are high CRI so should be a good form of light for riding. Thermal throttling seems to have this flashlight running at ~500 lm max over an extended period of time, giving a run-time of 2 hours 40 mins according to the charts from 1lumen.com.
I’ve also thought about the Convoy S21A (or S2) with TIR optics. The S2 is a lovely form factor, and seems to be more customisable, but I might be left wanting in run-time. The S21A appears to have TIR optics available to buy, and again according to 1lumen.com, the similar S21B with a single Osram Boost HX emitter was able to run at ~700 lumens for over 2 hours with a 4,000 max 21700.
To be honest, 2 hours is more than enough run-time. There is no way I’d ride continuously for an hour, and I have no issue carrying spare batteries, so even an S2+ could work if it can hold up the luminance.
I think the most critical points of consideration are going to be beam shape, and ability to maintain a steady high lumen output without getting too hot to hold.
I don’t think 80% of them did, no Though the thread would sure benefit if Nezil put “Onewheel” in the title.
Thanks, that should be done now.
Yep, it’s there :+1:
I had to goggle what it was.
Thought it’s the wheel without the board, like one guy on my block rides. Reminds me of the BC car2n…
An Electric Unicycle (EUC) looks more like the BC Cartoons. A Onewheel does have a board, and you ride it sideways rather than in-line BC style…. not that that makes it any less geeky!
It feels almost exactly like Snowboarding.
Well, I thought it was the brand the way it was written, “Onewheel”. Didn’t say “unicycle” or “single wheel.” A single wheel design has always been referred to as a unicycle in my experience. But I’ve had enough snark today. Outta here.
Headlamp.
You’ll thank me later.
Here’s one: [review] Sofirn D25L high-CRI headlamp, nice revision! .
+1… agreed :+1:
And the headlamp suggested is a good one & very reasonably priced.
IMO… to get range you will need a decent hotspot. However, for things like walking, running, bicycling, and skateboarding, you might appreciate a wide spill that will illuminate whats by your feet/wheel.
I might suggest an Acebeam L35 (Cree XHP70.2 version) for a 21700 size, or an Acebeam TK18 (Nichia 219C version) for an 18650 size. Both have WIDE hotspots with a decent reach, and the spill is wide enough to illuminate things close to your feet/wheel. The downsides that come to mind are: the Acebeam has a larger bezel so it’s not pocketable, and the TK18 is discontinued (although some dealers are still selling them)… also both require the battery to be removed to charge, and the Acebeam requires 20 Amp continuous 21700 (mine came with an Acebeam battery); the TK18 doesn’t come with a battery.
I don’t have any Zebralights, Lumintop, Sofirn, Convoy, etc. brands so I can’t attest to their beam patterns. I would assume the “floody” Zebralights would do well, and that the Lumitop FW3A should have a similar beam profile as the AB TK18 mentioned above if using similar LED emitters.
Edit: I might still lean towards a headlamp as suggested above.
I wanted to give everyone on here an update about this.
I didn’t get any feedback about the Sofirn IF25A, so I bought a 4,000K version and I’ve used it for a couple of nights now.
The 4,000K light is nice, with a high CRI, but it doesn’t feel bright compared to 6,500K lights if that’s what you’re used to. The high CRI does illuminate things in a very natural way though, and that’s nice.
Turbo mode is fun, but it doesn’t last for very long because of heat. I had to calibrate the temp sensor out of the box, and I’ve set the limit to 65 currently. Turbo works, but it’s pretty pointless for my application because I care more about a sustained high luminance flood of light than a temporary shot.
The beam shape is fine. I’ve read that there is no hot-spot and it’s a flood, but that’s not true. It is a fairly broad hot-spot though, and the spill is weak to the point of being irrelevant. Overall I’m happy with the beam shape; any wider and it would need more lumens output to be useful, and any narrower would not light up enough of the surface ahead.
A good test of the performance is if I feel confident to ride at the same speed as in the day, and I cannot say that it’s the same… but it’s close, and that’s a win I think.
I’m finding myself running the light at ~60% of the ramp, and at that point it gets warm to the touch, but not hot. Run time would probably be about 2 hours at this output.
Another finding, which is to be expected, is that if the ambient lighting is higher (due to street lights etc.), you need a higher light output from the flashlight. This is because the human visual system is adapting to the brightest objects in your field of view, and we can only see so much range. The flashlight needs to bring the foreground in to this visible range and more light is required to do that. I’m confident that if I were riding on a non-street-lit trail, this flashlight as way more than enough output to be effective.
Finally, the ergonomics… I’m hand holding this flashlight, and that’s proving to be very good; far better than a headlamp, for many reasons I’ve covered in earlier posts. The problem I have with the IF25A is that it is quite short. I wear wrist guards which are slippery plastic on the outside, and the short build of the IF25A makes it feel slightly insecure in my hand.
Given the ergonomics, I would love to have something that takes two 21700 cells in series, with a similar light output (beam shape, colour and lumens), and has a buck converter for continuous steady drive as the battery drains. I don’t think such a flashlight exists… but we can dream.
Short summary is that I’m reasonably happy with the IF25A for my application. It’s not perfect, but it’s a very good solution…. I’ll keep looking for something with better ergonomics, but I’m liking it so far.
I and I’m sure many others assumed you were riding in total darkness. Yeah a headlight is not going to help if you already have street lights somewhat lighting up what you’re doing. I also assumed these were real trails but it sounds like you’re on fairly well groomed hard surfaces. That changes things quite a bit. What is this surface and what color is it?
Eh, Nezil good to see another PEV rider out and about. I almost got a EUC but went for an E-Scooter instead! Yeah, those One Wheels are for sure fun as heck. I know because I tried one out a few times already. Fun as heck and a lot safer than a EUC.
About lights when you’re out and about one wheeling, I would use a headlamp and a handheld EDC. This way, you always have light wherever you look plus you can use the handheld EDC for quick scanning outside of your headlamp zone. For tint, I usually have a 5000K and 4000K light happening when I go ride.
