Wurkkos should answer these but may not. I do know the color temp is 6500K, definitely. It's the only color temp of the SFT-40 available to anyone now.
Regarding the regulated driver and how it compares, it's brand new so no one received one yet, as far as I know. But the claim of 2000 lumens output sounds unregulated but can't say for sure.
For the comparison, well, lots of ways to compare. We do know it's an SFT-40 LED however and we got experience with them. Expect some green in the beam tint. What I'm seeing it's more noticeable at low output levels. A green treated AR lens would help but don't think the manufacturers are shipping it that way -- really wish they would use a green treated AR lens though, not purple!!
Other than that I haven't seen much of tint shift in the beam, like you see with XHP50.2 3V's, etc., and it will throw better at or almost twice the kcd of a SST-40 but same or better lumens of an SST-40.
Yes, the newest luminus LED SFT40 only 6500k now
Regulated drivers yes
Compare to SC31 PRO. SP35, same output lumens 2000lm, but much more throwing, max 345 meters, and this with a tactical tail switch
My Wurrkos FC-12 arrived today, the main reason I bought it was the bright purple color! When you have 40-50 lights standing upright on a shelf it gets very hard to find a certain light when most of them are black so having a bright color really helps you find ‘that light’! Even the dark greens, browns, greys kinda don’t stand out but bright purple certainly does. Anyway about the light, machining, fit and finish are really nice, square threads and decent beam profile for a small diameter light. I wish Wurkkos included an 18350, tube that would be awesome and add a heap of value. I did however fit my SP31-PRO short tube onto the FC-12 and it fit perfectly, only problem is that as it has no tail switch it is constantly ON with no way to turn it OFF unless you unscrew the tail cap. You have full control of functions like ramping etc, just no off button as the front main control button is not and OFF/ON button on the FC-12. Its fairly long for a single cell 18650 light much longer than any of my other single cell lights. This is obviously due too 3 things, onboard charging, a much deeper reflector for the dedomed throwy SFC-40 emitter and the tail cap switch. Overall I like the new emitter and light in general I just wish it had a short tube as it’s a bit too long for EDC carry. The Wurkkos 3000mah cell appears to be a different cell to the Sofirn 3000mah. Whether it’s of better quality or worse I don’t know. You don’t get any current specs on Wurkkos or Sofirn cells, just the cells capacity and safety sign telling you not to eat the cell or put in in a fire etc.
yes, the EC03 Green! Top 3 favorite flashlight colors of all I have owned! Sofirn nailed that color!
please try that one wurkkos!
also, FireFlies e07x red is unquestionably the nicest anodization color I have ever laid eyes on. That's a standard for color and finish (slight metallic red).
It works well apart from not having a switch on tail switch so the light just remains on. But If you made a short tube with switch I think folks would appreciate it.
