Hi everyone. We just launched a new headlamp named HS6R. It is specially built for Outdoor Searching, Rescuing, and Industrial Operations. We offer a special discount on this product for all BLF users. PM me to get a coupon if you are interested.
CYANSKY HS6R is a full metal TYPE-C rechargeable headlamp. It features triple outputs with the main light of white spotlight and auxiliary lights of white floodlight and red light. The main light and auxiliary lights can work simultaneously for free combinations with a max of 1400 lumens.
Moreover, the independent dual switch design for main and auxiliary lights allows single-hand operation extremely easily.
1. 1*LUMINUS SST 40 LED for the main white spotlight, 1* LUMINUS SST 20 LED for auxiliary floodlight, and 1*Everlight 2835 red led with a lifespan of 50,000 hours.
2. Powered by 1*18650 Li-ion battery and compatible with 2*CR123A batteries.
3. Overheat protection against high surface temperature for better user experience and longer lifespan of the light.
4. Independent dual switch design for main and auxiliary lights.
5. Aero-grade A6061-T6 aluminum alloy material shell.
6. Premium type HAIII hard-anodized anti-abrasive finish.
7. Grade 10 Super Impact-resistant PC Lens.
8. Low-voltage warning.
9. Type-C charging, 3 hours for a full charge.
10. Maximum output is 1400 lumens.
11. Maximum beam distance is 170 meters.
12. Maximum runtime on a single charge is 30 hours.
13. Intelligent memory circuit.
14. IP68 waterproof - 2 meters underwater.
15. 2 meters impact resistance.
16. Workable from –30℃ to 50℃.
17. Storage environment: –35℃ to 65℃.
18. 160 grams(battery & headlamp band included)
19. Dimension: 80mm(length)×40mm(height)×36mm(width)
Let’s see the illumination effect at night
