Noctigon DM11 high CRI middle range thrower available
4302 posts / 0 new
@Lojik
Last seen: 6 hours 29 min ago
Hank Wang wrote:
With freshly charged 30Q 18650 cells, D18 219B vesion turbo current is 48A at turn on, that is 2.67A per LED,
which I think it’s still within safety line?
In that case, D18 219B version should be with direct drive, no current limit.
So unless I’m reading it wrong, it turns out the D18 with 219B’s, WILL in-fact surpass 10,000 lumen at turn-on? Roger that. Love Love Love
Thanks Hank
Berserker26
Berserker26's picture
Last seen: 7 hours 7 min ago
Hank Wang wrote:
We have one D4V2 in Australia, 219B 4500K LED, with flat retaining ring, extra flood optic, 18350 tube, and magnetic tailcap, original price is $60.17, now, 30% off, which is $42, shipping included, for Australian customers only, PM me if you are interested.
PM’d
D4V2 - XP-L HI V2 5D 4000K
D4SV2 - SW35 & W2
D18 - 2700K/4000K outer and W2 inner
Oveready Future Boss 35
@Lojik
I just did some admittedly ass-backwards math. But at 2.67A per LED, I’m getting about 645 lumen per emitter and over 11,000 lumen at turn-on.
Am I pretty far off, or at least in the correct neighborhood?
iamlucky13
Last seen: 3 hours 5 min ago
Here is some community data that should be pretty accurate, as an alternative to trying to read the tiny relative output graph from the Nichia datasheet:
https://budgetlightforum.com/node/53065
Rather than just settle for the closest reported current, I did the math to interpolate and got 605 lumens per emitter. You also have to consider losses from the optics. I don’t know what optic the D18 is using, but a Carclo 10mm TIR is supposed to be 92% efficient with similar sized LED’s, so that makes it 557 lumens per emitter.
That would suggest right at 10,000 lumens, if it really is able to pass 48A at turn on.
@Lojik
That makes perfect sense iamlucky13. That would line up exactly with why Hank said 10,000 Lumen. He obviously knows to account for those things too, unlike me. But I understand this a bit more now. Sure almost 11,000 technically, but impossible for the light to actually put that out.
Reminds me of the the difference between what horsepower a car is rated for vs what horsepower the car can actually put out at the wheels. Thanks.
battery
Last seen: 2 weeks 14 hours ago
I noticed in one of the other posts that the 5000K E21A tested out to be a few hundred K cooler than the rated when driven in these torches. Does this hold true for the 4500K E21A?
lazerEagle
lazerEagle's picture
Last seen: 5 hours 32 min ago
Woah! is there an Australia warehouse?!??!? Grad
- the best way to predict the future is to create it -
RamBull
Last seen: 8 min 37 sec ago
Just got my Hank UV mule. Just want to say he shipped it with ZWB2 filter installed. Great service and wonderful surprise.
I also got the 16x E21a 2000/5000k mule black body with copper head and warm light switch. It’s just so beautiful. Thank you, Hank!
It also came with two D18s. The first being the D18 sw35. I don’t know how bright it is but I all I can say is that it’s just beautiful.
The D18 SST20 Far Red (730nm)/ SST20 Deep Red (660nm) is just super red. I’m glad I got the deep red because the far red is way to dim.
mattlward
mattlward's picture
Last seen: 3 min 55 sec ago
Is this Hank’s new FET driver? This is from my latest 219b D4V2.
!d4v2-219b!
This driver does not seem to have a ML mode that is as low as the ML on my SST20 4000k unit with the older driver. Is that expected? I think I have set the minimum floor at 1.
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
ArtieT59
ArtieT59's picture
Last seen: 16 hours 43 min ago
that looks like the new 9amp driver. ML is set at 3/150 i believe. you need to manually set it at 1/150..
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
mattlward
mattlward's picture
I did drop it to 1 if I did it correctly. I think the light is anduril 2 and I do have it in advanced mode.
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
mattlward
mattlward's picture
I found the setting… I had started with the light on, not off. It now has an amazing ML mode!
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
Hank Wang
Last seen: 1 hour 49 min ago
We have one K9.3 with the configuration below in the EU warehouse, original price is $124.68, now 30% off, which is $87.2
for EU customers only.
Black
Switch back light color:Warm White
CH1 (9 inner LEDs): Neutral White – SST20, 5000K
CH2 (3 outer LEDs): SST-20 Deep Red, 660nm
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
RamBull
Black
I can’t wait for a US warehouse deal. Innocent
Hank Wang
Black
This is actually an item returned to the shipping company’s operation center, not a really “warehouse”.
For the US shipping, I kindly ask the customers from the US to make sure the shipping address is correct/valid,
even the zip code is very important, if the shipping address is invalid/incorrect, the package will be
returned to the sorting center, and will be DESTROYED there, there is no way that the package will be
returned to us, or reshipped to the customers. Please spread the words.
ArtieT59
ArtieT59's picture
Hank Wang wrote:
This is actually an item returned to the shipping company's operation center, not a really "warehouse". For the US shipping, I kindly ask the customers from the US to make sure the shipping address is correct/valid, even the zip code is very important, if the shipping address is invalid/incorrect, the package will be returned to the sorting center, and will be DESTROYED there, there is no way that the package will be returned to us, or reshipped to the customers. Please spread the words.
this is valuable information, thanks Hank! I will mention it.
ArtieT59
ArtieT59's picture
I also just wanted to mention that there is a great group of people over on Reddit dedicated to the enthusiasm Emisar and noctigon products. They invited me to join a couple weeks ago and it's a fun place to talk among like-minded enthusiasts! Here's a link https://www.reddit.com/r/Hanklights/
Hank Wang
Black
bump
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 months 2 days ago
If only this K9.3 had 219B SW35 or SW45K in CH1, I would immediately take it. Love
lionheart_2281
lionheart_2281's picture
Last seen: 13 hours 21 min ago
Black
bump
You should make a separate thread for these great deals so they don’t get lost in the chatter about your awesome lights
stephenk
stephenk's picture
Last seen: 10 hours 54 min ago
daffyh67
Last seen: 2 days 4 hours ago
Read it from link @ reddit, i posted there too..
It’s my new koala spotting light and i dig the rectangle head.
had to remap the mind a little for Anduril 2 but didn’t take long.
stephenk
stephenk's picture
Thanks. I’m surprised I didn’t knock any Koala’s out of trees with all those lumens.
I’ve also now found a compatible diffuser for the DT8 – the 22-50mm diffuser from Kaidomain, so have updated my review.
bcm00re
Last seen: 5 days 18 hours ago
What is the quantity/pricing on the Nichia 219BT-V1 3500K & 4500K LEDs? And the shipping cost/time to the US?
Kos70
Last seen: 1 week 18 hours ago
Hank Wang][quote=Hank Wang wrote:
]bump
Obviously - not the topic. But Henk; why do you stubbornly refuse to make head lamp !? It looks like you're the only decent manufacturer that doesn't have them in the lineup ... That's a decent chunk of the market. undecided
Lux-Perpetua
Members from Europe: FYI, today I have received a three pages letter from FedEx with an invoice charging me EUR 10.57 (EUR 4.62 EU Import Tax + EUR 5.00 processing fee + 19% German VAT) for my recent order from Int‘l Outdoor Flashlights. Most interesting is the fact that FedEx charged me these costs three weeks after receipt of order.
stephenk
stephenk's picture
Kos70]<p>[quote=Hank Wang wrote:
Hank Wang wrote:
]bump
Obviously – not the topic. But Henk; why do you stubbornly refuse to make head lamp !? It looks like you’re the only decent manufacturer that doesn’t have them in the lineup … That’s a decent chunk of the market. undecided
I would love to see something like a Noctigon 3.1 headlamp, 3 emitters on one channel, 1 on another.
ArtieT59
ArtieT59's picture
Ohhh that'd be nice!
ArtieT59
ArtieT59's picture
Hank-
sandblasted Titanium! (D4v2.. ) sandblasted titanium! (Kr4..) sandblasted Titanium! (Anything you want..) sandbla....
ok, I've made my point..
norve
Last seen: 3 weeks 1 day ago
Hank,
I received the KR4 mule 16 and the D4s2 Blue Swirl which looks awesome, thanks a lot for the beautiful color.
Only Hanklights
