You can see the archived poll results on the Wayback Machine:
https://web.archive.org/web/20221220093741/https://budgetlightforum.com/t/-/72908
We would to do a simple survey for the M300’s brother—the M400 new model. It will be use 21700 battery. We have options hard to make a choice.
(The image is M300)
GT-FC40 (best light quality), SFT-40 (most throw) or XHP 35/35.2 HI (balance of both if you can get 80+ CRI bin)
I’ll gladly trade 33%+ output for better light quality and/or significantly higher intensity/candela.
With XHP50.3 HI and other new Cree emitters coming out I’d be hard pressed to settle for the massive angular tint deviation of XHP50.2/70.2 or the only cool white and greenish hue of SST-70.
I fully agree with BurningPlayd0h.
My personal wishlist…
M400 (thrower style)
M400 (floody style)
I guess the MT-G2 :heart_eyes: is out of the question?
Quality over quantity.
If using SSTs/XHPs/etc., and if heat allowing, a nice TIR lens would avoid angular tint-shift from lots of LEDs.
I bet a common 26mm TIR might fit with a little persuasion.
The light doesn't really appeal to me, but I voted for CREE XHP70 because it's a little brighter.
Does the CREE XHP70 produce less heat than the Luminus SST70?
If so, then there's another reason.
It’s impressive to get over 400m throw from such a small reflector, but for any appreciable illumination of the target, spill is going to suffer. What voltage and amperage will the driver be capable of supporting? I take it this is a single cell flashlight?
Unless you’re going for CSLNM1, CULPM1, or SFT40 narrow beam profiles, I’d pick XHP70… but would prefer XHP50 for the temp range.
GT-FC40 and or XHP70.2 in the slightly rosy 5A (4000K) bin with a frosted lens for no ugly artifacts and rings in the beam.
Please, STOP WITH XHP70.2 in a small diameter reflector!
XHP50.3HI and XHP35.2 HI in 90CRI is what can look good in this size.
And Skilhunt USE ORANGE PEEL REFLECTOR!
I had M200 and M300 and sold both because of ugly as hell beam.
Now this could be a amazing.
NO sst70 or sft40, at least if they are CW. light is damn green. i perspnally would havent been intereted in them as tint is hell green. especially in sft40
xhp70.2 4000-5000K is great choice as well as xhp35hi with the same color trmperature.
i suppose that TIR optic version with some HI CRI leds would also be interesting
LOL, give them a choice of just two on BLF and you get twenty
Of the two choices in the OP, assumed that it will be cool white anyway, SST-70 is far superior: still great output for the size of the flashlight, not the extreme flooder that a XHP70 would make it, and super clean beam without tint shifts.
Btw, Skilhunt could make a prototype of both and see for themselves which is better. But I guess that for selling it, which one is better is less important than what people think is better.
well, our opinion about tint of sst70 is totally different -)
I do not like cool white tints, but the SST70 that I tested (a sample that I got via LuckySun) had a straightforward cool white tint, not green or anything.
Most important question. Is this M400 driver 6V or 12V?
Short answer. Offer BOTH.
7070 footprint emitters are pure flood in this size optic.Pair the XHP70 (better yet Getian GT-FC40 hi-cri) with a Frosted or Pebbled TIR.
5050 would ideally be a Cree XHP50.3 HI. Range of tint and CRI options. Luminus SST70 is only CW and won’t gain as much interest here in my opinion. Future SFT-70 would yield best lumens*throw numbers
The LED that I think would sell this light to me is the Nichia B35AM in 9080 bins. But I’m guessing this driver is 12V…
[quote=SKILHUNT] Faremmo un semplice sondaggio per il fratello dell'M300, il nuovo modello M400. Verrà utilizzata la batteria 21700. Abbiamo opzioni difficili da fare una scelta. 1. Usa LED CREE XHP70, 4000 lumen 2. Usa Luminus SST70 LED, 3000 lumen o altre buone opzioni che potresti suggerire. Fascio più diffuso o fascio più focalizzato? Hai davvero bisogno del tuo aiuto e facci sapere come ne pensi? (L'immagine è M300) !https://scontent-mxp1-1.xx.fbcdn.net/v/t39.30808-6/p526x296/231041918_4640077149337682_2260073758895492725_n.jpg?_nc_cat=106&ccb=1-3&_nc_sid_nc=1-3&_nc_sid&NC=730e14&_nc_ohc -mxp1-1.xx&oh=617f6fc2c39ea1048e5c8e05f4c30dff&oe=610FC58E! [/quote]
SBT90.2 LED imo.
[quote=Fetro]
[quote=SKILHUNT] Faremmo un semplice sondaggio per il fratello dell'M300, il nuovo modello M400. Verrà utilizzata la batteria 21700. Abbiamo opzioni difficili da fare una scelta. 1. Usa LED CREE XHP70, 4000 lumen 2. Usa Luminus SST70 LED, 3000 lumen o altre buone opzioni che consigliare. Fascio più diffuso o fascio più focalizzato? Hai davvero bisogno del tuo aiuto e facci sapere come ne pensi? (L'immagine è M300) !https://scontent-mxp1-1.xx.fbcdn.net/v/t39.30808-6/p526x296/231041918_4640077149337682_2260073758895492725_n.jpg?_nc_cat=106&ccb=1-3&_nc_sid_nc=1-3&NC=nc_s 730e14&_nc_ohc -mxp1-1.xx&oh=617f6fc2c39ea1048e5c8e05f4c30dff&oe=610FC58E! [/quote]
SBT90.2 LED imo.
[/Citazione]
...or quad SFT40.
If other emitters won’t be considered then i’d vote for SST70 and swap emitter with Nichia B35AM in that case.
But again OP reflector instead of artifact SMO. Or even TIR
That’s very promising. A cool white with no bluish, greenish, or yellowish tinges should be more suitable for long throw than a warm tint.
