What's your favorite UI design on flashlights?
32 posts / 0 new
xtarflashlight
xtarflashlight's picture
Last seen: 4 days 46 min ago
As the E-switches can work without interrupting the light being on, it allows for fancier UI than physical switches. It seems many people prefer the good e-switch UI. For example, Click on; Click off; Hold the switch to change modes, normally cycle from lowest to highest, then back round again to low; Shortcut to turbo with double click; Shortcut to moonlight with holding the switch from off; 3 or 4 clicks to lock/unlock the light… And there are also other users telling they like tail switches for turning on/off with modes controlled by either rotary ring or separate switch. A good UI is easy to use. How about your preference, what the user interface and controls do you like? We appreciate your kind comments and suggestions on this!
Edited by: sb56637 on 12/10/2021 - 07:22
Bort
Bort's picture
Last seen: 15 min 48 sec ago
Anduril 2 would be great.
I would like the ability to set custom modes.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
sp5it
sp5it's picture
Last seen: 13 min 19 sec ago
On/off and mode change with magnetic ring.
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
raccoon city
raccoon city's picture
Last seen: 10 min 19 sec ago
Something like Anduril 1 or 2.  :BEER:
Vimespolly
Last seen: 6 hours 1 min ago
For lamps and lights that you have time to set up I like lots of different options but for the torch I carry for work I want max output first every time I turn it on no modes or modes to get in the way.
TIFisher
Last seen: 2 days 7 hours ago
Kind of echoing @Vimespolly, it’s subjective and mission dependant for me. Multi-switch lights are a hard pass in my consideration.
Tactical = tail switch (mechanical forward) and one mode (high).
Work = mechanical forward clicky tail switch and 3-4 modes.
General EDC = e-switch (position relevant depending on form factor) and I’m really partial to Anduril 1 firmware.
dave1010
dave1010's picture
Last seen: 9 hours 48 min ago
Exactly this. To expand on that…
  • Moonlight and turbo shouldn’t be in mode memory
  • Double click from turbo back to normal modes (eg high)
  • Hold from moonlight to get to low
  • Moonlight should be 1 lumen at most for most lights
nvanlaar
nvanlaar's picture
Last seen: 1 week 3 days ago
I prefer Andruil or Zebralight’s UI.
You can quickly get to any mode without too many clicks IMO. Admittedly, it’s a little strange at first, but I quickly took to it.
“Facts don’t care about your feelings.”
~Ben Shapiro
texas shooter
Last seen: 1 hour 32 min ago
For a work light I prefer a mechanical forward clicky tail switch with a few modes. Or a mechanical forward clicky tail switch for on/off only and an electronic side switch for modes selection with memory. 3-5 brightness levels, double tap turbo, triple tap strobe.
For a toy light electronic switch with Anduril and an anodized tail threads for lock out.
CollectEverything
CollectEverything's picture
Last seen: 3 days 7 hours ago
Well, I like Anduril…once it is configured.
I wish there was a desktop application for configuring Anduril rather than having to mess around clicking that one button through various “menus”.
Here is how I would like it to work:
1. there would be visual elements like a double-slider for configuring max and min ramp.
2. There could be text fields to define the lumen levels of steps in stepped mode.
3. You could also disable group/modes you will never use via a checkbox system so you never have to cycle through them.
4. Modes could have a drag-and-drop interface letting you change the order that modes appear in a group.
5. After making these changes, you flash the application-generated config file directly to the flashlight.
Obviously this would be for enthusiasts only but I think it would be fantastic.
Collection: TN42, TN40S, Catapult V6, SP36 BLF, sc700d, sc64c LE, D4V2 CuZn, D4V2 CuTi, D4V2 Al x2, KR4 Al x2
Wishlist: Acebeam K75, Zebralight sc600w mk IV plus, Convoy M3-C
Lightbringer
Lightbringer's picture
Last seen: 1 hour 23 min ago
I still like Narsim, like on my Q8s and GTmicros.
Simple ramping without going crazy.
skinny_tie
skinny_tie's picture
Last seen: 3 weeks 4 days ago
My favourite UI is Anduril 2.
If Anduril isn’t an option I like an Olight Baton style UI, but replacing the strobe with a battery check and changing the lockout to 4 clicks would be an improvement.
I would be happy with the UI xtarflashlight described, but the addition of a battery check with 3 clicks from off (leaving 4 clicks for lockout) would make it even better.
stephenk
stephenk's picture
Last seen: 1 day 4 hours ago
There isn’t one perfect UI, it depends on the purpose of the light:
My favourite for general use – Convoy’s Biscotti/12-Group – easy to use, programmable, mode memory can be on/off, mode memory includes strobe, but shame about the alternating frequency strobe (should be constant frequency).
My favourite for light painting photography – Ryu’s Lightworks UI on Light Painting Paradise LightPainter.
My favourite for headlamps – UI on Nitecore HC65 – direct access to pretty much any useful mode with one button.
peg matite
peg matite's picture
Last seen: 1 hour 11 min ago
Thumbs Up
wle
wle's picture
Last seen: 4 hours 40 min ago
anduril is pretty good
anduril 2 is probably better
both of them have a lot of config options, which are good to have but may be too much for the noob, or someone who prefers simplicity to changeability
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
AlexGT
AlexGT's picture
Last seen: 1 day 6 hours ago
I like Anduril/Narsil and also magnetic ring like the ThruNite TN-31 or the AceBeam K70, K60
Tangra
Last seen: 1 week 1 day ago
Acebeam L19 has superb Tactical UI.
Chronovore
Last seen: 1 day 16 min ago
Nope. I prefer a mechanical switch. I like the Convoy lights with Biscotti. I mostly use 1%, 10%, 35%, 100% with mode memory turned off.
My only complaint is that the 12 groups don’t offer every arrangement I might want for a given light. I’d love to be able to plug in a USB or something and use an extremely simple, user-friendly, idiot-proof program to tell it that I want X% on mode 1, Y% on mode 2, etc.
Even better is the ring control on one of my Sofirn lights. It has low, medium, and high. I just turn to what I want. It’s the closest thing to an old-school hardware control with no guess work and easy access for even the dimmest bulbs among us. Silly
Kwispelhond
Kwispelhond's picture
Last seen: 13 hours 42 min ago
I’m can live with most UI’s as long as they’re well thought out, I like Anduril but also still enjoy the older Bistro lights like the A6 BLF SE and the X5 BLF, but sometimes a simple 3 to 5 mode layout is more than enough. I have no lights with a magnetic ring myself but would like it a lot, seem like a great idea.
What I think important myself:
- I like memory to be on/off by choice.
- no stupid click-combinations or to much different use of clicks for simple operation, think K.I.S.S. and just don’t overdo
- If it has moonlight it should be direct accessible from off or it is worthless.
- When using electronic switches the light needs a mechanic lock-out (twist of the tailcap or head)
- Much more important than all the above, give me NW, WW and hi-CRI options, I won’t buy angry-blue no matter how smart the UI is
zoulas
zoulas's picture
Last seen: 7 hours 33 min ago
I don’t think Anduril is the answer. I think in 10 years, Anduril will only be mentioned in the BLF archives.
My prediction is that touch OLED screens will end up on the larger lights, and virtually all lights will be programable via computer whether wirelessly or with a USB cable. They will have a simple web UI. At that point, you will be able to have 1000’s of settings because it will be easy to manage.
The stage is all set at his point. The technology is there, once prices drop a bit more, some Chinese manufacturer will jump on it.
Unheard
Unheard's picture
Last seen: 1 hour 2 min ago
This.
Except I don’t need a switch for on/off, but it doesn’t hurt.
Smile, you cannot kill them all.
CollectEverything
Hmm OLED screens on lights seems like a really bad idea to me. Seems like that would really limit your impact resistance, moisture resistance, and temperature tolerances.
Tangra
Imalent has models with screen.
Bort
Bort's picture
Giving it some thought a light with 4 modes and the ability to select them would be grand.
Lets say i can pick a percent for each one in the UI and it saves it. And preferably saves it even with no battery so i don’t have to reprogram it each time i remove the battery for charging.
CollectEverything
They aren’t exactly known for their reliability around here either Big Smile
xevious
xevious's picture
Last seen: 19 hours 58 min ago
Frankly, it’s a pain having to remember the UI of each e-switch light you own, when your collection of lights goes beyond a handful of unique UI’s. In a perfect world, you have one UI that’s workable for most applications. You can customize it as you want. Simple or Advanced, and then other options set as needed. Everything predictable. As such, I’d be totally happy if every single e-switch light I own had Anduril.
I don’t even touch my NarsilM lights anymore. Anduril is so close but superior IMHO.
draver
Last seen: 3 weeks 2 days ago
I agree. I have gone to the point of buying about 8 new lights with Anduril to make my EDC, home, car and travel lights consistent. They are all configured exactly the same and so I don’t have to figure out How Does This One Work? whenever I need illumination. I did cheat a little and kept my Gladius and Tiny Monster for nostalgias sake. All others are going to Good Will in a big bag.
xevious
xevious's picture
I hear you. Out of curiosity, which Nitecore Tiny Monster do you have?
draver
It is labeled TM 26 and rated at 3800 lumens if that helps. I don’t even remember when I bought it but it was new at the time. About $265 as I recall.
Bort
Bort's picture
I wish i could do this, a simple unified UI for all my lights would kick ass.
xevious
xevious's picture
OK. Thanks. Yeah, this flashlight came out in 2013… so it’s 8 years old now. The TM28 (nearly same design, more output) is still made and selling for $399 at full retail. The old TM26 occasionally appears for sale used, anywhere from $120 ~ $200. Because I mentally “earmarked” it, I had considered maybe getting one, but there hasn’t been much enthusiasm for it in recent years. Seems the 4 separate reflectors design is being phased out as TM39 is back to one reflector. UI design-wise, the TM26/28 seems decent. I don’t know how hard it is to change emitters, but if one could get an old TM26 for about $100 and install more efficient & tint-friendly emitters, it could be a worthwhile endeavor.
Topic locked
