Some people like that tail/side switch function - I don't see it. Anduril has the same tail switch tactical feature but with the ability to turn it off on the side switch, thus keeping the switch LED ON. I rushed into this one just for the unique color. A better choice would be the SC31 Pro in blue or green with the SST-40 here, or the FC11 w/LH351D but just in black here.
Received mine yesterday. Fast shipping, just a week from China to UK.
Was expecting it to give greater range than Convoy S2+ SST40, but the difference is only marginal. Has a narrower beam, due to the deeper reflector and de-domed nature, which gives a few yards advantage. Perhaps in larger form factor torches the difference between sst40 and sft40 will be more apparent.
Nice light though. My only criticism is that the side button led only stays on for 5 secs to show battery status, so it is hard to find button in dark to change modes.
I agree with Tom E and Artie that the 2 flaws with this light are its tail switch which is not necessary & it’s length. That’s why I have 4 SP31P’s, they just WORK. It’s a bit of a shame as the beam, color and feel in hand is great on the FC12. It’s just damn annoying having the fumble with it to turn it on. These things could easily be changed to make it a great light, I really like the new emitter and reflector that’s used. Anyway I stole the clip off the Wurkkos and put it on my short tube SP31P so all is not lost. Would I recommend this light to a flashaholic… probably not.
Here is a pic of the Wurkos FC-12 next to some other single cell 18650 lights. We have Olight Warrior Mini, SP31-P long/short tube, FC-12, Olight Baton-II, Lumintop FW4A.
Yea, but the mass isn't in the best place for cooling, for sure. It doesn't need a deep reflector and doesn't need a massive style tail switch - tail switch's can be done shorter.
can a driver reprogram make the e-switch a power switch? that’d solve my issues w/ the host. I’m not mentioning these issues to the 2 ladies that like the light. ignorance is bliss.
Hhmm, you mean like what regular Anduril or Anduril 2 do? With these, like most e-switch firmware, they shut power off to the LED and put the system into a low power standby which is typically in the range of 20-30 uA. A click though "wakes" it up from standby mode.
If the MCU treated the e-switch like full power shutoff, then there would be no way to wake it back up via the e-switch. You may still have some parasitic drain as well from the driver components, not the MCU itself.
