Well crap.
Thanks!
Hi Simon.
I’m looking to buy my first high CRI flashlight and I have a few questions:
1. Is the CRI of the R9080 the same for all colour temperatures? (3000k, 3500k, 4500k)
2. How many lumens does the R9080 produce in a s2+ host?
3. Is the s2+ R9080 available with an OP reflector ?
Thank you for your time and keep up your good work!
Hi all, do we know the BBL measure for GT-FC40 3000-3200K?
I’d very much like to know this, too.
Simon can you post spectrum test of sw35 sw45k Leds on total darkness?
The new S21C will came with E-switch and regulated Constant Current Buck driver (no pwm)with ramping?
ok ,sw35 and sw45k
Simon, it’s possible to post these tests for GT FC40 in the future?
Hi Simon.
3. Is the s2+ R9080 available with an OP reflector ?Thank you for your time and keep up your good work!
1.all R9080
2.About 500LM. This is only calculated according to the official data sheet, not using the integrating sphere test, for reference only.
3.default SMO ,pls note if you need OP
lazerEagle:Hi all, do we know the BBL measure for GT-FC40 3000-3200K?
Duv 0.00273
Ra=91.3
R9=66
R12=70
Any change for M21A/B with TIR optic?
Sofirn already launch IF25A.
thanks for the spectrum tests!
sw35
D200
R9 82
duv –0.0039
sw45k
D220
R9 92
duv –0.0064
that sw45k is VERY magenta, and its a D220, not D200… win win
thanks also for showing the sw35 has excellent negative duv, and it is D200, not D180… win win
Thanks Simon!
I’m going to order a s2+ SW45K OP reflector. I’m super exited to try a high CRI flashlight!
Pilotboy:Hi Simon.
1.all R9080
Simon. Thank you for the color data on the emitters! 219Bs look wonderful!
What is the restock time on the SFT40?
Yes, I appreciate the work and effort you do for us Simon
I have a question?, may I reserve a s21c tint mix or do you think you have enough 219b’s to last until the design is complete
i have ordered the MCPCB and TIR lens ,next work is driver design.
The reply I got is that normal supply will be resumed at the end of September.
I tried to design S21C on the basis of S21B, but the appearance is ugly. Now S21C is slightly modified on the basis of S12. S21C is the basic version of multi-lens flashlight. In the future, I will launch S21D with direct charging function, or more Functional S21E….
ch1ir:Yes, I appreciate the work and effort you do for us Simon I have a question?, may I reserve a s21c tint mix or do you think you have enough 219b’s to last until the design is complete
Which version will get Anduril firmware? :)
Hopefully none since Simon makes lights that are tools and not toys with a fancy gimmick ui.
Oh no… I missed the 2nd batch for a M21B. This seems like a long wait from now… :weary:
JaredM:Simon. Thank you for the color data on the emitters! 219Bs look wonderful!
