You already carry some well known and reputable brands although Fasttech very often doesn’t have the complete lines and the latest models. You could post the new arrivals of these good quality flashlights as well as check on brands carried on other platforms as per Lux-Perpetua’s suggestion. You could also reintroduce Lumintop if that is possible. Hopefully you could have products to post here that are of interest to the flashlight enthusiast community as many you currently post are not.
Perhaps you could take a look at the forum(s) to see what flashlights members are interested in.
I agree with the first comment. Rusty Joe’s is an example of some products that are very different then a lot of the weird cheap stuff I see.
That’s not to dogpile on, I just had an order at about $100 for 2 lights from this thread. But please don’t make me unsubscribe because of really low quality stuff that even the MOST budget enthusiasts are not interested in buying.
The Fenix HM50R V2.0 is a rechargeable multipurpose headlamp. One 16340 rechargeable Li-ion battery is included to power it. This headlamp is power-packed throwing a 700 lumens beam to a maximum distance of 115 meters. The HM50R V2.0 is outstanding with its solid construction and lightweight size, plus it is detachable to be used as a mini flashlight. This rechargeable headlamp combines white and red lights, comes with a USB Type C charging cable and features an IP68 rating, all of which make the Fenix HM50R V2.0 perfect for camping, hiking or working in rigged environments.
Detachable structure - can be used as a flashlight.
Lockout function avoids accidental activation.
Premium type HAIII hard-anodized anti-abrasive finish.
This is exactly the problem (see red highlighted quote above). Giveways should have no strings attached. Personally, I find campaigns like these a bit shady, especially in combination with a giveaway. If you want to encourage customers to buy more items, offer volume discounts ("buy 2 get 3").
From the BLF rules applying to commercial sellers:
When someone is informed that they are breaking the rules, they can immediately stop breaking the rules, or they can come up with a lame rationalization.
Fenix HP25R V2.0 LED Headlamp Work Light
1*Luminus SST40+1*Cree XP-G3 S4+1*Everlight 2835 LED / 10-mode / 1600LM / white & red light / 1*21700/1*18650 / USB rechargeable
The Fenix HP25R V2.0 is a rechargeable work headlamp that provides an ultra-long runtime of 400 hours on low mode. Powered by its included 5000mAh Li-ion battery, this headlamp can deliver a max output of 1600 lumens. There is a separate battery case located on the headlamp’s rear; this unique battery case includes a USB Type-C charging port for easy and fast charging. 60° tilt mechanism allows you to direct light where needed and the lockout function avoids accidental activation. For all-night exploring or work demands, the Fenix HP25R V2.0 headlamp never fails you.
1600 lumens spotlight and 400 lumens floodlight.
One Luminus SST40 white light LED, one Cree XP-G3 S4 neutral white LED and one Everlight 2835 red light LED; with a lifespan of 50,000 hours.
Included a Fenix ARB-L21-5000 Li-ion battery, compatible with a 18650 Li-ion battery.
Separately controlled dual switch for easy and fast operation.
USB Type C charging port for easy and fast charging.
60’ tilt mechanism directs the beam where needed.
Hello again Fasttech. Also in your new arrivals you show the On The Road U16. Your listing describes it as being powered by by a 16340 or CR123A battery and having 4 XHP50.2 emitters with output of 2300lm. If these are correct specifications this is a very unusual and phenomenal flashlight. Can you confirm?.
I would say that it is a mistake and that the “4” refers to the the 4 “nucleous” that the XHP50.2 led has! Also, in such small light, there is no space for 4 of that leds, as far as I can tell
In the pictures you can see that the lights are triples and not quads lol.
Fasttech i would email the manufacturer and tell them off, i know the description is copy and pasted to Fasttech store from what the manufacturer specs. How can a manufacturer get it so wrong? Now you have to go and fix up 3 separate listings sigh!
Sorry, you are right! I thought that you were referring to the question above about the U16!
You are right, something is wrong, the photo or the description I bet on the description!
