I finally found the button on the top of the page at sunlikelamp.com to show English text and selected the 18+18, 4000k & 2700K, with soldered LEDs, but the add to cart button does not work.
I did disable all my add blocking on that site, but it still doesn’t work. Tried a different browser and it still doesn’t work.
I wonder if I could just purchase the bare PCBs and solder my own E21As onto it. Looks like the pads might actually be compatible albeit a bit larger. I’d like to do something with a larger CCT range; possibly down to 2200K or even 2000K.
When I click the Add To Cart button, that button moves down, away from my mouse pointer, and I have to continue holding down my mouse button and move the pointer so it’s on top of the Add To Cart button, then release the mouse button.
Now I’m waiting for an email with Paypal instructions. I’m not clear on the total amount to pay and which currency to select.
Sorry if this is an obvious answer to most people here…
But does this board & LED component include the driver as well, such that all one needs to do is desolder the original component and solder in this replacement? No thermal paste required?
This is a replacement board for the BLF LT1 lantern, to be used directly with the original driver. So a little thermal paste can’t do harm although without it it will likely be fine too.
Edit: oh, maybe you refer to those square boards that Lampman just posted, I know nothing about those :person_facepalming:
Thanks. Yeah, got it that it’s an LT1 replacement board… just wasn’t sure the extent of the task involved. I do have some thermal paste lying around from a CPU replacement that I never ended up doing (determined it was too obsolete). I’m totally fine with soldering wires… just haven’t made any thermal paste applications. I know with CPU’s it’s really tricky to do right, as you don’t want any air bubbles. So, was just hoping this LT1 board replacement was only a matter of soldering a few wires.
As far as thermal paste goes, here we’re not dealing with the high wattages of CPUs and everything squishes down so air bubbles aren’t a problem. You just squirt a little bit of thermal paste on and push the board down.
I have a question about the option on the sunlikelamp website: “soldering LEDs (low-temperature paste 138°)”
Do we need to select this in order to get the LED’s we order soldered on?
If I order an extra board without LED’s, is there a reason to select this (for example, will I be able to skip applying my own solder paste)?
It looks to me like it should work.
It looks like the solder pads on this LT1 board will be about 2mm tall, with a 0.5mm gap between them. This is larger than the E21A needs and should not cause any issues with shorting, as long as they line up right during the reflow.
E21A’s are supposed to be more difficult to reflow than most emitters, though.
I think you need to select that to get your LEDs soldered on. You can probably get them on the tape if you don’t select it. If you’re soldering your own LEDs on, you need to apply your own solder paste since solder paste typically has an expiration time (once applied on the board) of a few hours due to the flux evaporating.
