RD6018 RD6018W 60V 18A power supply is published
RD6012W feedback
have a look at my Super DIY power supply
https://www.aliexpress.com/item/4001053200176.html
RD6018W feedback
the product is good, need prepare the AC power cable by yourself
https://www.aliexpress.com/item/1005001488070904.html
RD6018W order suggestion
when making order, you can click the coupon option to get more discount, for example, you order RD6018W, you can use 6 USD coupon, if you order whole set, you can get 10 USD off at least
https://www.aliexpress.com/item/1005002058172206.html
Is “RD6018WS800 1000W68V” here the same as the other link in the thread but with the 1000W power supply? Will the 1000W supply provide the full 18A maximum of the RD6018 (at 55.5V obviously)?
if AC is 220V , it can let RD6018 output 60v/18a
good power supply, still need a AC power cable
https://aliexpress.com/item/1005001488070904.html
RD6018W feedback
order suggestion assembled , works
RD6018W feedback
after checking the accuracy in volts and amps, it exceeds my expectations. very precise measured with 5 1/2 digit multimeter
RD6018W feedback
it arrives, but the post in Chile is slow
RD6018W feedback
It has quality, let's see how long it will last
RD6012 feedback
The parcel arrived in 5 days, the product is of high quality!
RD6018W feedback
100% recommended
RD6018W feedback
Fast delivery, all as in the description. Waiting for the rest of the details. Thank you seller!
RD6018W feedback
Apparently quality product. Still to test, I'm going to buy the PSU now. Shipping very fast
RD6018W feedback
Good price, good working. The assembly is very simple, it takes about 20 minutes.
RD6018W feedback
I do not connect the load now, but it is ok
RD6012W feedback
Great DC power supply, all is work well. The shipment is very fast. I appreciate d. Thank you seller.
https://aliexpress.com/item/4001053200176.html
hello, I find that some customers feedback, they use the red terminal to charge battery, the green terminal is for battery charging, it has reverse protection and auto cut off function
DPS5015 feedback
Delivery in about three weeks in a prefabricated parcel. Works well as described. no matter how hard the delivery guys tried to destroy the parcel, all came intact!!!the seller put the gift of two crocodiles. this store recommend it
https://www.aliexpress.com/item/32702714880.html
DPS5005 feedback
Great product and seller. I received the goods in Yekaterinburg on the 5th day after ordering. Everything matches the description. Super packaging, excellent functionality and workmanship of the device. Thank you and recommend the seller!
https://www.aliexpress.com/item/1000004290003.html
