This is a replacement board for the BLF LT1 lantern, to be used directly with the original driver. So a little thermal paste can’t do harm although without it it will likely be fine too.
Edit: oh, maybe you refer to those square boards that Lampman just posted, I know nothing about those :person_facepalming:
Thanks. Yeah, got it that it’s an LT1 replacement board… just wasn’t sure the extent of the task involved. I do have some thermal paste lying around from a CPU replacement that I never ended up doing (determined it was too obsolete). I’m totally fine with soldering wires… just haven’t made any thermal paste applications. I know with CPU’s it’s really tricky to do right, as you don’t want any air bubbles. So, was just hoping this LT1 board replacement was only a matter of soldering a few wires.
As far as thermal paste goes, here we’re not dealing with the high wattages of CPUs and everything squishes down so air bubbles aren’t a problem. You just squirt a little bit of thermal paste on and push the board down.
I have a question about the option on the sunlikelamp website: “soldering LEDs (low-temperature paste 138°)”
Do we need to select this in order to get the LED’s we order soldered on?
If I order an extra board without LED’s, is there a reason to select this (for example, will I be able to skip applying my own solder paste)?
It looks to me like it should work.
It looks like the solder pads on this LT1 board will be about 2mm tall, with a 0.5mm gap between them. This is larger than the E21A needs and should not cause any issues with shorting, as long as they line up right during the reflow.
E21A’s are supposed to be more difficult to reflow than most emitters, though.
I think you need to select that to get your LEDs soldered on. You can probably get them on the tape if you don’t select it. If you’re soldering your own LEDs on, you need to apply your own solder paste since solder paste typically has an expiration time (once applied on the board) of a few hours due to the flux evaporating.
The first thing that I learned myself when I started the hobby. But I know the feeling, I have that when someone mentions to just flash the newest Anduril to solve a problem (I have little computer skills, and no windows computer).
On a related note, does anyone know where I could source E21a emitters to use on the LT1 board? Clemence’s site is still under construction and Hank doesn’t have bare emitters listed on his store. Going to need a bunch of them to populate several of these boards.
Have you tried email contact? The last time I was there the checkout page told the user to contact them. There is an email on their contact page. I would try contacting clemence thru the email.
I did get that message, but I’m also waiting for Clemence to fulfill an outstanding order that I paid for over a year ago, which is part of the reason I was hoping there is another source for E21A. Unfortunately it looks like there isn’t, unless I want to order and entire reel.
