I have a question about the option on the sunlikelamp website: “soldering LEDs (low-temperature paste 138°)”
Do we need to select this in order to get the LED’s we order soldered on?
If I order an extra board without LED’s, is there a reason to select this (for example, will I be able to skip applying my own solder paste)?
It looks to me like it should work.
It looks like the solder pads on this LT1 board will be about 2mm tall, with a 0.5mm gap between them. This is larger than the E21A needs and should not cause any issues with shorting, as long as they line up right during the reflow.
E21A’s are supposed to be more difficult to reflow than most emitters, though.
I think you need to select that to get your LEDs soldered on. You can probably get them on the tape if you don’t select it. If you’re soldering your own LEDs on, you need to apply your own solder paste since solder paste typically has an expiration time (once applied on the board) of a few hours due to the flux evaporating.
The first thing that I learned myself when I started the hobby. But I know the feeling, I have that when someone mentions to just flash the newest Anduril to solve a problem (I have little computer skills, and no windows computer).
On a related note, does anyone know where I could source E21a emitters to use on the LT1 board? Clemence’s site is still under construction and Hank doesn’t have bare emitters listed on his store. Going to need a bunch of them to populate several of these boards.
Have you tried email contact? The last time I was there the checkout page told the user to contact them. There is an email on their contact page. I would try contacting clemence thru the email.
I did get that message, but I’m also waiting for Clemence to fulfill an outstanding order that I paid for over a year ago, which is part of the reason I was hoping there is another source for E21A. Unfortunately it looks like there isn’t, unless I want to order and entire reel.
