I think you need to select that to get your LEDs soldered on. You can probably get them on the tape if you don’t select it. If you’re soldering your own LEDs on, you need to apply your own solder paste since solder paste typically has an expiration time (once applied on the board) of a few hours due to the flux evaporating.
Just placed an order for 1 full up board.
Oops - wai’tn on PP instructions.
I just send it by email :money_mouth_face:
I have a question about the option on the sunlikelamp website: “soldering LEDs (low-temperature paste 138°)”
Do we need to select this in order to get the LED’s we order soldered on?
If I order an extra board without LED’s, is there a reason to select this (for example, will I be able to skip applying my own solder paste)?
It mean that I will solder it by myself. If you need just leds with pcb separately, do not choose it
iamlucky13:I have a question about the option on the sunlikelamp website: “soldering LEDs (low-temperature paste 138°)”
Thanks for clarifying.
Wow. Missed this project until now. Really wish the bottom end CCT was 2200k or less. 2000-3500 would be just right IMO.
I ordered an unpopulated board too, to use whatever interesting leds that can be found
JaredM:Wow. Missed this project until now. Really wish the bottom end CCT was 2200k or less. 2000-3500 would be just right IMO.
Ah, the joy of reflowed emitter skills… :sunglasses:
djozz: JaredM:Wow. Missed this project until now. Really wish the bottom end CCT was 2200k or less. 2000-3500 would be just right IMO.
The first thing that I learned myself when I started the hobby. But I know the feeling, I have that when someone mentions to just flash the newest Anduril to solve a problem (I have little computer skills, and no windows computer).
On a related note, does anyone know where I could source E21a emitters to use on the LT1 board? Clemence’s site is still under construction and Hank doesn’t have bare emitters listed on his store. Going to need a bunch of them to populate several of these boards.
Tom E:Just placed an order for 1 full up board.
Oops - wai'tn on PP instructions.
K, PP payment made.
Rayoui:On a related note, does anyone know where I could source E21a emitters to use on the LT1 board? Clemence’s site is still under construction and Hank doesn’t have bare emitters listed on his store. Going to need a bunch of them to populate several of these boards.
Already tried there. You can add to cart but can’t actually purchase anything.
Sunnysunsun: Rayoui:On a related note, does anyone know where I could source E21a emitters to use on the LT1 board? Clemence’s site is still under construction and Hank doesn’t have bare emitters listed on his store. Going to need a bunch of them to populate several of these boards.
Have you tried email contact? The last time I was there the checkout page told the user to contact them. There is an email on their contact page. I would try contacting clemence thru the email.
I did get that message, but I’m also waiting for Clemence to fulfill an outstanding order that I paid for over a year ago, which is part of the reason I was hoping there is another source for E21A. Unfortunately it looks like there isn’t, unless I want to order and entire reel.
Oh. Covid hit Indonesia quite hard
It will be interesting to see what impact the LT1’s opaque white lens will have on red emitters. Has anyone tested this yet to confirm?
The diffuser should be color neutral, so the red should remain red.
I seem to recall somebody sharing an emitter swap in an LT1 to replace the CW LED’s with photo red XP-E2’s, but I can’t find it now.
Diffusers mainly lower the blue region of the spectrum, relative to the rest, red gets out relatively easy.
Rayoui, Cutter sells some E21A leds, nothing loose though, all mounted on mcpcb’s
email me for emitter sales
cheers
