"Review" - Wuben D1 - 1100 Lumens - 18650 powerbank battery
41 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 15 hours 43 min ago
Hi BLF!
This is my review (video + written) of the Wuben D1 flashlight!
The flashlight was sent by Wuben for review with no other compensation than keeping the flashlight and accessories. Thanks Cindy and Wuben!
The light is not yet on sale. I will add the link later on, when it is available.
I will do my review in an unbiased way, as I normally do, being it gifted or bought! Beer
VIDEO OVERVIEW
As usual I made some mistakes on the review (namely about the flashlight parts – see comments and see the written review below) and eventually others, but here it is!
NOTE: the video was done without the support of an User Manual, which I received later (digitally). So the information on the written part will be more accurate and complete.
GENERAL SPECIFICATIONS
Body Colour: Black
Material: Aluminium
Emitters: Osram P9 (Cool White) Cree XP-L Hi 6500K
Optic: Textured / Clear TIR
Battery: 18650 (eventually CR123a)
Switch: Electronic Side Switch
Max runtime: 150h
Max beam distance: 130m
Max output: 1100 lumens
Candela: 4200cd
Waterproofness: IP68 (2 m underwater for 1h)
Impact resistance: 1.5m
Low Voltage Warning: Yes (detailed below)
Reverse Polarity Protection: Yes (but not specified)
PACKAGE: Flashlight and Accessories
First it has to be mentioned that the packaging I received from Wuben is a “sample”, which is not the final version packaging. Therefore, this box will be different from the one in the retail version.
I received a black cardboard box with foam inside that acts as cushion for the flashlight and accessories. Inside I found: Wuben D1 flashlight, an unbranded USB-C rechargeable/powerbank 18650 3400mAh battery, a USB to USB-C charging cable, a Wuben branded lanyard, and 2 spare o-rings.
As I mentioned before, there was no User Manual; it was sent to me later, by e-mail, by Cindy from Wuben. The manual will also be included in the retail version.
Wuben D1 Flashlight
Looking at the D1 flashlight, what can be said?
- compact 18650 sized flashlight (between a Skilhunt M200 and a Olight Warrior Mini)
- great knurling pattern on the battery tube that provides good grip, along with the pocket clip
- magnetic tailcap (eventually removable)
- dual direction, but non-reversible, pocket clip on the head (in a specific groove)
- textured & clean TIR Optic, similar to the one used in the Wuben H3 (and also similar to the Fenix E20 V2.0)
- doesn’t seem to use a glass lens
- eventually uses an OSRAM P8 or P9 LED (cool white) Cree XP-L HI 6500K
- can be disassembled in 3 parts (head, non-reversible tube, tailcap)
- takes button top and flat top batteries, because it has a spring on the driver (+more on this later)
- rubber cover on the e-switch, with transparent W, to allow seeing the inner indicator LED
- threads are triangular, unlike the normally squared/trapezoidal threads from Wuben
- stainless steel bezel
- springs are not as thick as seen in other lights but are strong, specially the one in the tail
- great black matte anodizing, typical from Wuben as well
- “engravings”: D1 and HOT in the head; logotype and battery polarity in the tube; serial number, CE and others on the tailcap
- the tailcap has a lanyard hole
Some points I can also focus now about its use and looks:
- the Wuben logotype + the battery polarity indication engraved on the tube are not aligned with the switch, being this an aesthetical issue more than of use (see the flashlight’s 1st photo);
- the switch button protrudes a little bit, which is enough to locate it with the thumb, even if the clip – which stays in the opposite side – is not being used. Also it makes a “click” when pressed and responds well to the clicking and pressing actions;
- light feels well in the hand, and is versatile, capable of being easily operated by thumb or index finger;
- the magnetic tailcap is not as strong as, for example, the TO50R, but it does stick well to flat and even round surface, and it holds the flashlight in place without issues;
- the lighted switch can be activated (fainting) or deactivated, acting as location led, which is bright enough to locate the flashlight in the dark but dim enough so that it doesn’t bother night vision;
- the pocket clip allows deep carry, with the head up, and that way it can also be used in a cap as headlamp; while using it in the other direction, it doesn’t allow deep carry, but can still be clipped in a bag, shoe, or other place. The retention is not the strongest (unlike on the Wuben E05, which has the same type of clip, but that is a smaller and lighter flashlight).
Being a relatively small flashlight, it is not a complete lightweight flashlight, revealing to be sturdy enough despite thinner than, as example, the TO46R. I didn’t make beating test, but it felt to the ground more than once, made a small chip, but kept working well!
Accessories
About the included accessories, I’ll start from the lanyard.
It is similar the ones that Wuben normally includes in their packages, black and white, Wuben branded, and its with adjustable .
In the D1 it can be attached to the flashlight tailcap, or to the pocket clip, in different places:
As for the User Manual, I’ll present some screenshots from the digital document sent by Cindy.
It is well written, has information in different languages (13 to be more specific), but lacks some information or specifications:
1 – doesn’t specify about Reverse Polarity Protection
2 – isn’t clear about if this D1 flashlight can use 2xCr123a batteries (see the Battery Recommended part), which I think is important
3 – doesn’t specify the working voltage
4 – doesn’t mention the type of LED
(click to see full image)
The charging cable included in this package is not a simple USB to USB-C cable: it also has an extra USB port on the side where another USB cable can be attached to use the battery as powerbank.
Last but not least, the included battery itself.
It arrived with a blue plastic protection on the – pole to avoid discharge or accidental activation.
It is a 3400mAh 18650 battery, rechargeable through a USB-C cable. Although unbranded this is supposed to have the reference of Wuben ABT3400T. It has a slightly raised button top, it is longer than other protected batteries I have (due to the charging port).
Around the button top it has inner indicator leds: when charging it will blink red, when charged it will be a constant red, and when the flashlight is used as powerbank, there will be a constant blue light.
I am not sure if the battery will have some kind of warning when it is almost discharged, and this is not specified in the User Manual.
It is also mentioned that the total charging time should be 4 hours, at 5V/1A. Discharge rate while used as powerbank is also 5V/1A .
It arrived charge up to 3.41V, I used a charging cable to charge and left it there for a while, and it finished at 4.14V. I didn’t use a charger yet to see which is the finishing voltage.
When placed in the flashlight it protrudes out of the tube dimensions, specially when compared to an unprotected flat top battery.
NOTES:
- the manual states that it is recommended to use a battery with protection circuit and not an unprocted one
- it also states – although not completely clear (for me) – that CR123a (3V) battery can be used with caution. I assume that it can take 2 x CR123a 3V batteries, making a total of 6V
- last, it states that RCR123 and 18350 batteries shall not be used (I assume when used in pairs, as that would make 8.4V instead of 6V.
LOW VOLTAGE WARNING
As mentioned before, its is not stated if the included battery has any kind of information about it’s level.
Despite this, the Wuben D1 has a way to indicate when the battery needs to be charged (or eventually replaced, in case one is using CR123a batteries)
This is the User Manual diagram, which is general and not specific for one or the other type of batteries that can be used.
- 5s constant blue when the voltage level is above 90%
- 5s blinking blue when voltage is between 90 and 40%
- 5s constant red when the voltage level is between 40 and 15%
- constinuous blinking red when the voltage level is below 15%
I didn’t have any drained battery to check how low the battery needs to be to activate the constant or the blinking red indications. Will post later when I have that information.
USER INTERFACE and OUTPUT vs RUNTIME
USER INTERFACE
The Wuben D1 interface is similar to the Wuben E12R that I reviewed some time ago.
It has 4 regular modes: Moon > Low > Medium > High
It also has 2 blinking modes: Strobe and SOS
It has memory for the last used regular mode.
From OFF
*Press & hold – enters Low
*1 click – turns ON
*2 clicks – enters Stobe
- a) another 2 clicks enters SOS; another 2 clicks enters Strobe; …
*3 clicks – activates/deactivates the W switch LED indicator
*4 clicks – locks/unlocks the flashlight:
- a) while locking the light blinks 3 times
- b) after unlocking, the light turns ON in Moon level
- c) if the switch is pressed while locked, the switch will blink 3 times
From ON
*Press & hold – advances in the sequence Moon > L > M > H > Moon >…
*1 click – turns OFF
*2 clicks (if in Moon, Low or Medium) – enters High
- a) when in High, 1 click turns OFF
- b) when in High, 2 clicks enters Strobe
*2 clicks (if in High) – enters Strobe
- a) another 2 clicks enters SOS; another 2 clicks enters Strobe; ….
- b) when in Strobe or SOS, 1 click enters High
NOTE: if the power is disconnected physically while the flashlight is locked, when reconnecting power, the lock-out will be lost.
CONSIDERATIONS: Despite there are some things I don’t like in this UI, I do like the possibility to access the lowest level (Moon) from OFF, and the 1 click for ON/OFF.
At the same time, I am not fan of:
- 2 clicks from OFF to Strobe
- 2 clicks from High to Strobe
- not having direct access to HIGH from OFF
OUTPUT vs RUNTIME
The User Manual presents the relation between these 2 parameters (and other information).
I did a small 6minutes test to check the drop in output. Although I cannot say how many lumens the flashlight produces , I can tell that during the first 45seconds, the output decreased substantially when in High. After that , it was stable throughout the rest of the (small test I did).
My guess, seeing the information from Wuben, is that the max level will be around 1100 lumens, then decreases to a lower output maintained during 30 minutes and then decreases again to a lower output (eventually 400 lumens or below) for 2.5 hours.
About heat produced, during these 6 minutes the light didn’t get warm above 35ºC.
Don’t take this as an official statement or scientific test. It was made with a luxmeter and IR thermometer, but didn’t meet any parameter other than illustrate how the flashlight behaves.
In any case, the lower level to which the “High” dropped, is plenty for outdoor illumination even if not for long range.
FLASHLIGHT COMPARISON
Taking a look how the D1 compares to other flashlights in terms of size:
Vs TO46R
Vs T050R
Vs E05 (old version)
Vs Gecko E61
Vs H3
Vs Convoy S2+ 18500
Vs Olight Warrior Mini
Vs Lumintop FW3A
BEAMSHOTS
The Wuben D1 doesn’t present PWM in any of the modes.
Similarly to the recently reviewed Wuben H3 headlamp the TIR installed in the D1 and the LED it has below produce a more floody beam, although there is a marked hotspot, without noticeable tint shifts (which is probably due to the textured edges of the TIR optic).
I think the LEDs used in these 2 Wuben lights are different, because on the H3 there is a more visible transition between the hotspot and the spill, a more pronounced corona. This seems to be a larger LED, eventually.
Also the hotspot on the D1 seems more “roundish” than the “squarish” of the H3.
I hope to have some outdoor beamshots soon. Meanwhile here are some indoor ones and some tint comparison between some flashlights.
The Wuben D1 is on the left side Wink
Vs Olight Warrior Mini (SST40 + TIR)
Vs Wuben H3 (Osram P8 + textured/clear TIR)
Vs Enogear SS (Luxeon V2 3000K + pebbled TIR)
Vs Wuben TO50R (Samsung LH351D 5000K + quad TIR)
About CRI the Wuben D1 (left) is probably 70CRI and the TO50R (right) is 90CRI.
OVERALL APPRECIATION
I will write here what I wrote to Cindy from Wuben, as part of my feedback for them.
My general appreciation is pretty good, namely:
1 – Good ergonomics of the flashlight, that fits well in the hand and provides good gripping due to the body knurling
2 – Really great anodizing and fit & finish, flawless Wink
3 – The magnetic tail is very handy, and is a big plus in this light too
4 – I do like the type of beam – although it is not “common” – specially because it doesn’t have any tint shifts (yellows or greens)
5 – The battery that serves as powerbank is a great idea and I find it very useful too
6 – I like the “click ON / click OFF” and also the “press & hold” to access the lowest mode
7 – I like the stability of the HIGH mode, even if it drops during the initial ~45seconds
8 – Overall performance seems to be really good, as Wuben usually does Wink
As this is a sample, I would like to make some suggestions for final product improvements:
1 – Align the Wuben logotype/battery polarity engravings in the tube with the switch button when the tube is all tighted in;
2 – Include a User Manual (I know you will do it to provide data about the light Wink )
3 – I would like that the pocket clip could also be used from the tail towards the head, allowing it to be deep carry, of course
4 – The User Interface: I think it would be preferable for users to have a double click to Turbo from ON and OFF, and always have a triple click for strobe, either from ON or OFF (I know this would imply changing the clicks for the breathing switch and the lock-out, but this is the most critical point to me in this and in other recent lights, as the E12R)
And this is it. The rest you’ve read it above Silly
Leave your questions or comments if you want to and stay tunned for the outdoor beamshots very soon (I hope) . :THUMBS-UP
Edited by: MascaratumB on 08/04/2021 - 07:14
MascaratumB
Changed OP to include both the video review and the written review too!
Wink
MascaratumB
As with the H3 headlamp, yesterday I took a change to go outside and test the Wuben D1, see how the beam behaves outdoor.
And as with the H3, I also got impressed! Specially with the type of beam of the D1.
If on the one hand it is quite floody, on the other hand has a defined narrow beam in the center, due to the type of TIR it has.
Below I show some comparison photos and also some beamshots from it.
Comparison with the Odepro TM30 (that has XML2 and a deep slightly orange peel reflector), on the right:
Some beamshots with the 4 levels, at different distances. It reached more than 100m, although I wasn’t able to see much more than that due to the moist weather at night.
Some glam photos, that will magnetize you Silly
Thumbs Up
Scallywag
Scallywag's picture
I think it’s a gimmick that Wuben is marketing the powerbank functionality of the battery.
To begin with, I don’t like nonstandard batteries. I also really don’t want a powerbank that also has exposed + and – contacts of an 18650 laying around. But the fact that it’s part of the marketing of the light is just ridiculous to me.
MascaratumB
Hum, so far Wuben is not advertising the light as such because it is not out yet.
I did put that info on the title of the thread.
If you think is is misleading or distracting, I may change it, but the package is supposed to include such cell anyway…
So far I didn’t see or received any info that the light will be adverstised with such emphasis.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 30 min ago
I wanna know where you got the Wuben tablecloth… LOL
Is the battery standard size, or overly long? I’ve got 18650s that are slightly long and still fit easily into most lights, and some that are rather long and limited to only a few lights with enough length inside to fit. My E05 has a monstrously long come-with 14500 that only fits the E05 and no other lights, but regular cells can still fit with its long-enough springs.
So… will the cell fit other lights, and can the light take regular 18650s (even unprotected flat-tops)?
MascaratumB
Ahah, the “tablecloth” is a neck gaiter Silly They sent me one some time ago with a flashlight for review (I guess it was the E19). Since then I try to use it on these reviews Wink
About the battery size, as I put above, it is a bit longer than the normal “protected” cells, even the Wuben ones, which are long already.
I can tell that the D1 takes smaller batteries – unprotected, flat top – as the Sony VTC6 or the Sanyo NCR18650GA. But I didn’t try the ABT3400T cell on many other lights, though.
I can tell that it fits the Nitefox UT20 (whose cell is just slightly smaller), but I don’t have other “un-modded” flashlights on me in which I can try it.
I would say that it will fit a Wuben TO46R, a Zanflare F1, but I am not sure how well it will fit in Convoy S2+, as example.
I’ll check it next week and will let you know here Thumbs Up
And yes, that 14500 cell is almost only suitable for the E05 (eventually to the Skilhunt M150, but without certainties). Tired
bts
Last seen: 10 months 3 weeks ago
Looks like a cool light. Any idea what’s the price and when it will be available?
Yea, I hope Wuben listen to your feedback regarding this:
1 – Align the Wuben logotype/battery polarity engravings in the tube with the switch button when the tube is all tighted in.
4 – The User Interface: I think it would be preferable for users to have a double click to Turbo from ON and OFF, and always have a triple click for strobe, either from ON or OFF.
Smile
Better to hv it and not need it than to need it and not hv it.
MascaratumB
Smile
Yup, I hope so, that they can “change/correct” those aspects. However, I wouldn’t put much faith on changing the UI, this seems to be their standard UI recently.
As for the price and date of release, I didn’t get any information on that. I assume it won’t take long to be released, but can’t tell about an exact “time”.
I’ve been testing and using it during the last days and yes, it is a responsive and reliable light so far. I have some “habits” from other lights that sometimes I use in this one (double click to turbo Silly ) and ends up not doing what I want. But apart from that, it seems a solid flashlight Wink
Lightbringer
Wait a sec… by “fainting”, do you mean the lit switch is one of those “breathing” ones, that glows dimmer and brighter over a few seconds?
Gotta say, I HATE those, to the point where that’s an instant dealbreaker for me if always on. They’re just creepy.
I’d rather turn the damned thing off completely (eg, the original SC31) than have a creepy “breathing” light shining on me all night. And if I gotta keep it off, what’s the point?
I fail to see what’s wrong with either just a constant very dim light (best if RED than blue or any other color), or a beacon type, a quick blip every now and again.
MascaratumB
Yes, by fainting I mean that “breathing” button Wink
It can be enabled/disabled, of course, but it acts that way.
I prefer the blue instead of green (as the E12R has), but I agree that a red indicator light would be better.
Well, but for that you can try the GT Nano, whose light is red and so dim that it is almost unnoticeable Big Smile
G0OSE
G0OSE's picture
Last seen: 3 days 3 hours ago
Good review MrB Thumbs Up thanks. I like your reviews because they are thorough – some reviews just do the same thing over and over with very little useful info, you on the other hand delve into things much deeper. I don’t care for videos just shining it down a path etc with no commentary or photo’s.
MascaratumB
Thanks for your words G0OSE Wink
My drive in the reviews is to show what the flashlight does while being used for the purposes it was built, and also to show how it behaves, knowing that different people have different tastes and needs!
I can’t go deeper in some technical aspects such as lumens or candela measurements, so I try to compare how it looks like along with others and also how it performs in my “eye-measurement” Wink
I’m glad it is helpful and that the hours invested are appreciated Blushing
Thanks again Beer Thumbs Up
MascaratumB
I asked Cindy from Wuben about 2 things: when will the light be available, and what is the price range!
I paste below her reply Wink
Quote:
1) If there is no accident, D1 flashlight will be available in May. Pre-sale will start in late April and I will send you the link once it is available on our website.
2) The price of D1 flashlight is $56.99 but it will be lower if you order the light during pre-sale period.
When the link is available, I’ll post it here and udpate OP too! Thumbs Up Beer
derfyled
derfyled's picture
Last seen: 5 days 5 hours ago
Great review ! Thumbs Up
I think I like everything about this light except the 6500K part.
Do you know if they plan to release other tints or even better, an high CRI version ?
Also, have you tried to access the led ? How easy is it ?
MascaratumB
Thanks for your words derfyled Wink
Hum, I am not sure if it is a 6500K, I would say between 5000 and 6000K instead.
But tonight I can compare it with a cooler tint so that we can see that.
I wasn’t able to reach the LED. Yesterday I tried again but I don’t have the appropriate tools on hand to do it, so I may try it later.
I am not sure if the bezel is press fit or if it is glued because I wasn’t able to take it out. But I when I am able to do it, I’ll post it here Wink
As far as I know, and looking to Wuben’s line of work, I wouldn’t count much on a High CRI version. If one can reach the led, it can be replaced by a 3535 footprint led, though!
TMaxxJJ did it on the Wuben H3 headlamp, here: https://budgetlightforum.com/comment/1753288#comment-1753288
Wink
MascaratumB
As promised I made some comparison beamshots between the Wuben D1 and some other flashlights in the range of 5000K to 6500K.
Here are the “results”:
From Left to Right, Vs:
Convoy S2+ XML2 U2-1A 65000K
Jaxman E3 Nichia 219C 5700K
Olight Warrior Mini SST40 ????K
Wuben D1 Osram P9 Cree XP-L HI 6500K (where th big toothpick is Big Smile )
Wuben TO50R 4x Samsung LH351D 5000K
Wuben TO46R 3x XP-G3 5000K
FW3A 3x XP-L HI 3D 5000K
Convoy S6 3x Luxeon V 4000K
Convoy S2+ 3x Luxeon V2 3000K
It is definitely a bit cooler than some 5000K leds, but it is not as cool as the 6500K ones! It person, while taking this photo, it seemed “pure” white against the surface I was using!
The photo may be a bit tricky in some aspects but I guess they show more or less where the Wuben D1 is in terms of tint Wink
Hope it helps Thumbs Up
Hank33
Hank33's picture
Last seen: 7 months 1 week ago
Wuben D1 Osram P9 (where th big toothpick is Big Smile )
Where did you pick up the Luxeon V2 for your Convoy S2+ 3x Luxeon V2 3000K? The tint looks quite nice. Smile
MascaratumB
It is, indeed, a pleasant tint and it was a “grail” mod I wanted to do for a while (detailed here: https://budgetlightforum.com/comment/1741697#comment-1741697) .
I picked it at https://led4power.com/ last year. Some weeks ago I bought another, and it arrived today Wink
Specific link: https://led4power.com/product/3x-luxeon-v2-3000k-4000k-5000k-70cri-led-o...
derfyled
derfyled's picture
Thank you MascaratumB for this great comparison shot. Indeed, it does not seem to be 6500K but closer to 5000K. Still too cool for me but I’m a tint snob…
Something I really, really, really like about this light (and might have to buy it just because of this feature) is the lighted switch. I love being able to reach my flashlight on my night table or tent pocket in pitch dark. I hope Wuben will put this feature on all their new lights.
MascaratumB
You’re welcome and I’m glad it helped perceiving where it “locates” itself in the spectrum Wink
About the lighted switch, I get what you say, it is easier to locate the flashlight in the dark in a much better way! They also have it in other lights (E12R comes to mind, and others eventually).
As Lightbringer mentioned, I too preferred a different colour on the led indicator (red) but the fact is that it works as it is Wink
derfyled
derfyled's picture
The lighted switch is in my opinion the only thing missing on the T050R to make it perfect. I don’t know if you like it as much as I do but what a fantastic wall of light, pur high CRI joy…
MascaratumB
Yup, probably one of the best lights I have too Wink
That is a “beast” of a light! I am afraid of using it more giving it is almost a “premium” light, but whenever needed, it comes out of the “light-box” Wink
And yes, an indicator LED could be good on it! Using a 21700, any parasitic drain would still make no harm on it!
BTW, I am not sure if Wuben uses the led indicator on the C3 and the C5 as well!
MascaratumB
After checking Unheard’s thread reviewing the D1 I changed the information about the LED : it is a Cree XP-L HI 6500K instead of an Osram P8 or P9 as I initially suspected.
Thanks Unheard for the correct information Beer
TheFlasher
Last seen: 23 hours 20 min ago
Very interested in this light, but would require me to swap in an 2700K 80+ CRI to be happy with it. Does disassembly seem feasible to do this?
MascaratumB
So far I wasn’t able to remove the bezel and I am afraid that when I do that I will damage the host a little bit. Maybe I don’t have the proper tools for it or the skills, but it is really stuck Tired
If or when I can do that I will post it here referring to the method to retrieve it!
Unheard
Unheard's picture
Last seen: 3 hours 48 min ago
Tried and failed, too. I fear it needs heat, but optics and electronic components are close to the bezel. I think I’ll live with it. It’s ok outside. Actually I’m happy about every single candle I can squeeze out of it.
Smile, you cannot kill them all.
MascaratumB
Thanks for telling your experience Unheard Wink
Yeah, I suspect some heat would be needed, despite I also think that it can be some pressure downside up! But for that I’d probably need to remove the driver and that may not turn good Tired
MascaratumB
I did it Crown
I disassembled the head! Evil
So, it is not glued, but pressed. I used the tools in the photo below.
The work-knife is quite tough so I used the “baton” method around bezel, starting on one side and making the diameter tryin to push the knife edge in. After a while, it started opening a gap and then I used the knife to press the bezel towards the top. And it poped-up! Wink
Structure:
  • bezel,
  • white o-ring,
  • optic/reflector (single piece as far as I can tell),
  • black thick o-ring,
  • copper DTP MCPCB star with around 1.2-1.5mm thickness and
  • gray thermal paste below.
  • EDIT: there is also a screw in the shelf to prevent the MCPCB from rotating
As Unheard has mentioned and confirmed before, this has a XP-L HI emitter.
As far as I can tell, a 3535 led seems to fit below, but careful if you want to try a XP-L HD, that has a larger dome.
Some notes:
  1. the optic/reflector has a slightly flat area on the side that allows to “disengage” it from the bezel, and I used pointy tweezers in that area to pull it out
  2. the bezel is somewhat “ridged” (not sure if the expression is correct) and those ridges leave a mark in the head structure, meaning that it was pressed into the head. Or the head already those grooves and the bezel fits into them… I guess the first theory is more suitable in this case.
Note that the bezel and the head have some marks because I used pliers and other tools before, unsuccessfully Sad
Any questions, let me know Wink
And good luck in case you folks try to disassemble it! Thumbs Up Beer
Unheard
Unheard's picture
Well done Thumbs Up
If ano scratches are visible, a sharpie/edding hopefully helps. Do you have an idea what LED you’ll reflow?
MascaratumB
Unheard wrote:
Well done Thumbs Up
Thank you Wink
Hum, the scratch on the optic does not interfere with the beam, and the scratches of the host…well, I’ll say it adds personality Silly
As for the led to reflow I don’t have many options around me so a Luxeon V2 may be the candidate! I don’t know the tint yet Facepalm
The optic sits really over the led, I can see the marks in mine, so it needs to be a carefull operation Wink
