Yes, only black color now, will update purple on Amazon de when more stock ready
the length was for a longer throwing based on SFT40, Our initial idea is that a deeper cup can have a longer distance and it has a USB interface
FC12 Amazon EU reviews invited now
Right, like andruil
I'm hoping it will be as easy mod upgrade to a driver running Anduril 2 with the tactical switch support. All that means for Anduril 2 is that a power switch ON turns the LED on to the last used level instead of leaving the LED off, as it does normally. I got a couple modded lights with an e-switch and a power switch running like this, and for me it works pretty well.
Just wish Wurkkos made this light this way, out of the box.
I was sort of hoping I could put my usb dongle to use and flash the existing driver. Please let me know if you find a suitable driver. It will be cold out before I have time to take it apart myself.
Mine arrived in NJ 3 days ago, so it says, but no movement since. Once I get it, will take a look.
Good luck - mine spent 3 days in NJ then went to indiana, then back over to NY.
Why this light is not 21700?
Same story with IF25A. Does not have mechanical swich on tailcap.
Where can I find those reviews?
Is Amazon NL also possible to order from?
Should be here tomorrow - came in to the local P.O. about 2 hours too late for a Saturday delivery...
Agree with you here. Only reason is to keep width and length down for EDC, but then again the design is not optimized for small size.
Too early for reviews, and they didn't have a preview release for reviewers, I guess. Dunno about Amazon NL.
this is a new release model, not have many reviews now, there are some reviews on facebook wurkkos group
I received mine last Friday and tested it over the weekend. I will post a short summary when I’m back home.
Great light all around.
Looking forward to it. My first torch seems te be either the FC11 Ir the FC12
Make the FC11 with a deeper reflector from the FC12 without a rear derailleur!
Poor Dog Eyes
It’s an honor to be the first, thank you
Yes, when use SFT40, a deeper reflector will be needed, the poor is the length longer
