What do you prefer on our M400 new model (21700 type)?
Your beamshot doesn’t show noticeable green… must be a different batch?
My only experience with SST70 at this time is from a Sofirn SD05 (which previously came in XHP50.2, and later became SST70)
Following pictures are from “screengrab” from my beamshot comparison video of SD05 (XHP50.2) vs SD05 (SST70), so the images are a bit blurry, but the color comparison between XHP50.2 vs SST70 should be noticeable…
SD05 (XHP50.2 cool-white) [left] vs SD05 [SST70) [right]
SD05 both on HIGH brightness = colors look pretty OK (not ‘greenish’ just basing on the image)
SDO5 both on MEDIUM brightness = the SST70 starts to show “greenish”
SD05 both on LOW brightness = SST70 is more throwy than XHP50.2 and there’s still the “greenish” hue compared to the XHP50.2
Can I know what driver will be used for this M400?
It will be nice to contact loneoceans to make a Lume X1 driver for this new flashlight. It looks like it will be good match for the LED:
<< Lume X1: 40W Single-Cell Boost Driver with Anduril2 and UDR >> | BudgetLightForum.com
The Lumx X1 driver looks nice, :+1: but we already made M400 driver.
Does the M400 driver include a true sublumen(Moon) mode?
Now is 1~2 lumen, any suggestion?
Its too high, 0,3-0,5Lm would be much better.
Why need it such low ? Use for ?
Is the driver for 6V or 12V LED?
And sub-lumen moonlight is what the majority of users are going to want. The idea is to have a minimal amount of light to be able to see and be discreet and not hurt night-adapted eyes. Very important feature to most of us.
Beside sub-lumen, OP reflector or TIR would be apreciTed since this one won’t be a thrower…
If it’s a floody beam, 1-2lm shouldn’t hurt night-vision, as intensity is less, being more spread-out.
If it’s throwy, just the opposite.
And sublumen should then be more properly be called “firefly” instead of “moonlight”.
Me, I prefer moonlight over firefly, as I’m mostly looking for stuff on the floor or just walking in pitch-blackness, vs checking a map or watchface.
In my GTmicro, which runs Narsim and is about as throwy as you can get, I configged “moonlight” (shortcut press’n’hold from off) to 1, the lowest, and a fractional-second longer for “floor”. So I can choose between firefly and moonlight depending how long I press from off.
So maybe something like that… press’n’hold shortcut can take you to firefly first (eg, 1sec) and jump to moonlight after (eg, 1½sec).
Not disturbing others sleeping, keeping dark adaptation for eyes, reading maps, looking inside bag at night or other close-up tasks where even 1-2lm can be harsh and too bright. The <1lm modes on the M150 and H04 is one of their best features and something that makes them really stand out from many other competing lights at similar price.
Some situations require a better preservation of night vision.
Here’s a UI idea on managing it.
Activate moonlight.
Click, Click+HOLD — shifts moonlight to next intensity. 0.3 lm, 0.5 lm, 1 lm, and 2 lm are the levels. After 2lm, intensity resets back to 0.3 lm. Whatever intensity you had set your moonlight, it will be recalled anytime moonlight is activated. Another idea would be if you do click, click+hold and continue holding, for each 2 seconds it steps up to the next intensity until 2 lm, then resets after that.
Does that sound feasible?
Any news on M400 release date and / or final specs? :smiley:
The brand new XHP70.3 HI 4000k 90CRI would be sweet.
Any news?
M400 needs a recessed button switch that is easy to find in class complete darkness. The M300 switch is so small and very difficult to locate in the dark.
Warm to neutral white options with high CRI.
Basically anything in the 4000K-5000K range with a CRI over 90. Nothing noticeably green or pink.
The nicest light I’ve personally seen has come from the 4500K GT FC40 in the Acebeam E70, followed by the 5000K LH351Ds in the Sofirn SP36.
I still haven’t seen a 519A or B35AM in person, but I hear they’re excellent as well.
XHP70.3 HI 4000K or 5000K with an option of a beaded/ pebbled lens for those who are interested.
As others wrote, XHP70.3 HD or HI which has much less tint shift than the XHP70.2. 80 or 90 CRI would be nice.
From XHP35 to XHP70...
I 'd go with Nichia B35AR
