update
I went softroading, dropped tire pressure by 13psi, and had a great time.
I used the Avid Cube inflator, on battery power to air up 3 of the tires. They took about 4 minutes each. The battery was showing 1 bar remaining. I decided to use the cig lighter cord for the last tire (with car motor running). It also worked great.
It was 60F outside, and the pump did not feel like it was overheated. Im quite impressed and happy to own the unit.
There were a couple of glitches.
- The unit kept shutting off after a couple of seconds. I learned that was caused by my failure to push the pump conne ction far enought onto the tire valve stem.
3. On the 3rd tire, the hose blew off the valve stem clamp on the pump. This started blowing the air out of the tire really fast. But, I was there watching.
Managed to push the air hose back onto the fitting, and completed inflating the 3rd and 4th tires without drama.
When I got home, I plugged the airpump into its charging cord and it took about 6 hours for the charge indicator to turn green.
Im keeping the little Avid Cube pump…
Recommended
