11000 lumens Flashlight Sofirn Q8 Pro, deals for Amazon.us!
Hi, it’s $23.99 with the battery on our website.
I would a q8 pro code!
PM sent!Thank you!
Thank you!
How is this possible? I just received mine and turbo lasts about 25 seconds and then after 2 minutes max the light has dropped down to so dim its pretty much unusable.
Edit- Switched to advanced UI and run time seemed substantially better. Ill calibrate now and should be good.
Would love to see this model using the SFT-40
I am interested in getting this light. Did you fully charged your batteries? With 11000 lumen, it will be pulling a lot of current.
Yes just topped off with my miboxer. I switched to advanced ui and turbo seemed substantially longer. Ill check it out tomorrow and then calibrate and redo. I have no idea if switching ui should do anything but it seemed to.
Edit. Did recalibrate and change step down temp and it holds turbo significantly longer.
Requesting Q8 Pro code please. Thanks!
Has anyone seen someone shave the emitters in this q8 pro, or other 6500k xhp50.2s?
Code for the Q8Pro please.
I’d like the code for the Q8Pro please.
PM sent, please check it out!
PM sent, pease check it out! Thanks!
I’d like a code for the Q8 pro please.
PM sent! Thank you!
Can I have the code for the Q8 Pro please? It looks awesome.
Q8 pro code please
Will the code work on amazon.co.uk?
I’m sorry the code is not works for Amazon.uk. And Q8 Pro will be in stock on Amazon.uk soon.
PM sent! Please check it out. Thanks!
