I have ended up with one of the D4V2’s with 219B’s and Hanks CC driver. I really hate the low end, if I go below 3/150 there is an odd shutoff and delay turning on and the LEDs start low and increase to the proper level. Hank did not find it a problem the the lowest usable setting is 3/150, I find it unacceptable and will be the last light I every buy with that driver. Moon levels are critical to my night vision in the house, to much and I can’t see for about 30 seconds and 3/150 is to much!
Does this or will this address this issue? This light will never see full brightness, I doubt. My D4V2 with SST20’s is actually much dimmer than the 219B light. I hate that, it will lead to me not using it often.
Nope, there’s not much I can do about that. The regulation circuit is running way below its optimal level, and it takes a while to stabilize when things are that low… especially if the driver is hot from being on a high mode.
However, I did add something to make it turn on faster during hold-from-off for moon. It now pulses a higher level for a few milliseconds to “jump start” the regulation circuit and make it wake up sooner. Before adding this, when I needed moon in the middle of the night, the process was:
Aim light so I can see the aux LEDs.
Hold button until aux LEDs turn off.
Release button, and wait while moon warms up.
Now it’s more like other lights, where I can just hold the button and then let go as soon as I see light. It starts significantly faster.
Fixing it properly would require hardware changes, like adding a lower power channel which is more stable for these extra-low modes… but that hasn’t happened, so I tried to at least reduce the issue in firmware.
Due to hardware variability though, some lights will have steady output on moon, and some will have visible flickering. There’s nothing the firmware can do about that. And some lights will start a bit slowly on moon still, while others might have a bit of a “pre-flash”, because the jump-start thing isn’t one-size-fits-all. The jump start could potentially be configurable, but it’ll still start slower after the light was on turbo.
As for this dynamic PWM thing, it mostly just squishes the bottom end of the ramp downward to provide extra precision and smoother ramping for low modes. The results are something like this:
Before: (old KR4 firmware, 2020)
1/150: 0.2 lm
2/150: 0.25 lm
3/150: 2.5 lm (default floor)
4/150: 2.5 lm
5/150: 4.2 lm
6/150: 5.9 lm
7/150: 7.6 lm
120: ~1700 lm
150: ~4000 lm
After:
1/150: 0.20 lm
2/150: 0.30 lm
3/150: 0.45 lm
4/150: 0.65 lm
5/150: 0.90 lm
6/150: 1.20 lm
7/150: 1.55 lm
11/150: ~2.5 lm (default floor)
130: ~1700 lm
150: ~4000 lm
As a side effect, it’s also finally more feasible to include moon in the stepped ramping mode, because the levels are actually spaced pretty close to visually-linear near the bottom. I’m getting pretty good results with a ramp from 1 to 130 in 8 steps.
Anyway, this change improves somethings, but it doesn’t eliminate the driver’s slow stabilization time at low modes. Much like how a human eye takes a while to adapt to darkness after seeing a bright light, the regulation circuit takes a while to adapt to very low power levels after it was burning bright. It’s slow when used at ~0.2% power or lower, especially after coming down from something bright.
Yes, that’s exactly what it’s doing now. It was 10-bit before, which was audible on some lights… but 8-bit is a high enough pitch to make it generally inaudible.
The exact numbers might vary over time as I refine the ramp calculator… but for now, it starts out like this on the DD FET + linear 5A model:
0/16383, 0%
1/16383, 0.006%
1/11750, 0.009%
2/14690, 0.017%
2/9183, 0.021%
3/12439, 0.024%
4/13615, 0.029%
5/13955, 0.035%
6/13877, 0.043%
7/13560, 0.051%
8/13093, 0.061%
9/12529, 0.072%
11/13291, 0.083%
12/12513, 0.096%
14/12756, 0.11%
… but before it went like this:
0/1023: 0%
0/1023: 0%
1/1023: 0.1%
1/1023: 0.1%
2/1023: 0.2%
The real-world numbers are a little more tricky than that, because zero isn’t actually zero… Sending the driver a “zero” signal actually produces about 0.011% of the maximum output. And there’s other error and approximation involved too. The ramp calculator tries to account for that stuff by factoring it into the calculation model, and the model isn’t perfect. But it seems to get close enough for a useful result.
The code running on the attiny chip is simple and easy. The hard part is making the ramp calculator’s model accurate enough to generate a good table of values.
There’s nothing I can do about the driver’s analog noise floor. It’s a property of the hardware. It can flicker randomly by +/- 0.2 lm, so increasing the digital PWM resolution beyond that is mostly pointless. What I did here is increase the digital resolution as far as the analog properties of the driver allow… and it turns out that’s about 12 or 13 bits.
… and then it decreases resolution smoothly to about 8 bits, as it gets brighter. Because higher modes just don’t need to be very precise. A difference of 0.3 lm is very visible when going from 0.3 to 0.6 lm, but it’s completely imperceptible when going from 1000.3 to 1000.6 lm. So it prioritizes precision for low modes, and speed for high modes.
May I please also ask, there used to only be one 219 firmware for each light, to cover both 219c and 219b emitters. Now there seem to be both 219 and 219b. What is the difference and need for there to be 2?
Edit: I just flashed the nonFET to my E21A KR4. I noticed that the SOS mode is not there (not sure if it was before, just compared to some diagram I have).
If the lights are really making noise I’d worry about the parts shaking themselves loose, particularly the inductor. Sometimes people glop elastomer over those to damp the vibrations, I think.
Anyway, this is great work, using these clever software methods to get the best from the limited hardware. I hope that the hardware can also keep improving.
The kr4-219 build uses 60% FET, while the kr4-219b version is 50% FET. Hank was experimenting with different levels when he started carrying 219B as an emitter option. I’m not sure which one he uses, or if it’s both. If it’s just one though, I’ll probably remove the other one.
This is a normal property of lights which use high-amplitude PWM to adjust brightness. It’s nothing to worry about; just an aesthetic inconvenience. On some lights, sound comes from a tail spring, on some it comes from other parts, and on some it’s not even coming from the torch itself. Rapid thermal expansion and contraction can be heard, even from nearby objects, thanks to the photoacoustic effect. Someone around here actually made a pillow play a song from Star Wars, using only high-intensity light pulses. The same could be done with an infrared laser, to turn arbitrary objects into makeshift speakers from a distance.
Thank you for the explanation. That is very useful to know.
I have modded a couple of Hank’s lights to Nichia 219b a long time ago and they have worked perfectly for a long time. I am sure I am not the only one. I would appreciate it if you kept the 60% FET version available regardless of whether Hank prefers the 50% or 60% FET.
I'm on Win 10 running chrome, but also verified they don't wrk for me in Edge. If I "view source" the links in the html source works fine. She hosts them on her http://toykeeper.net/ website.
It’s because of the mixed content policy of Chrome. The images don’t use TLS, but BLF does. In Firefox I just get a warning. Not sure if this is due to a setting or extension.
Yeah, sorry about that. It’s complicated, and I haven’t had a lot of time or energy lately since I’m dealing with some health issues. So I don’t end up with a lot of productive time I can use for flashlights or server maintenance. Have mostly had to use that time for seeing doctors, learning medical stuff, and basic life tasks which are now a lot harder than they should be.
But if I get a day or two to work on it, I really need to add https to my site(s).
One option might be using a free proxy that provides HTTPS termination like Cloudflare. It’s normally simple to set up (if you’re willing to hand over your DNS to them). As with anything like this it has pros and cons and may not fit your needs. If it does then it can be a 10 minute job.
As others have said, health is more important though.
