11000 lumens Flashlight Sofirn Q8 Pro, deals for Amazon.us!
Yes just topped off with my miboxer. I switched to advanced ui and turbo seemed substantially longer. Ill check it out tomorrow and then calibrate and redo. I have no idea if switching ui should do anything but it seemed to.
Edit. Did recalibrate and change step down temp and it holds turbo significantly longer.
Requesting Q8 Pro code please. Thanks!
Has anyone seen someone shave the emitters in this q8 pro, or other 6500k xhp50.2s?
Code for the Q8Pro please.
I’d like the code for the Q8Pro please.
PM sent, please check it out!
PM sent, pease check it out! Thanks!
I’d like a code for the Q8 pro please.
PM sent! Thank you!
Can I have the code for the Q8 Pro please? It looks awesome.
Q8 pro code please
Will the code work on amazon.co.uk?
I’m sorry the code is not works for Amazon.uk. And Q8 Pro will be in stock on Amazon.uk soon.
PM sent! Please check it out. Thanks!
Code for Q8 Pro please. Thanks!
Can I please have the code as I can order from Amazon.com too
PM sent! Please check it out. Thank you!
PM sent! Please check it out!
Code for the Q8 Pro please. Was just looking at this today!
PM sent, please check it out! Thanks!
Hi I would like the q8 pro code. Thanks.
